Question about Kenmore 16691 Grill
Hooked up new tank and not getting gas to the burners, tried another tank with same results.
    Champion:
  • 274 Answers
Try replacing the regulator, easy to do and not very expensive, to see if that fixes the problem.
Posted on Jul 12, 2010
Hooked up new bottle,will not get hot,low flame
Turn off burners. Turn off gas. Disconnect regulator from propane tank. Reconnect regulator. Turn on burners Turn off burners. Turn on propane SLOWLY. Turn on burner and ignite.
Aug 18, 2014 | Weber Genesis E-310 Gas Grill
No sound of gas
Tyrn off tank open conrtol knobs to burners , turn off burners turn tank on slowly see if gas comes out now , if not check burners are not blocked or injectors are not blocked
Jul 04, 2012 | Grilling
Brinkman gas grill won't start. Don't hear clicking sound. Hooked up new gas tank, but no success
Victor, are you sure you're getting gas to the burners after installing the new tank? You can try match lighting them to make sure. But, I suspect, that it's the installation of the new tank, that's causing the problem.
To test my theory, tune the tank valve OFF and disconnect the hose from the tank. Wait 5 minutes and reconnect the hose to the tank. Ope the tank valve VERY, VERY SLOWLY (Slow motion, slow). Once the valve is fully open, try lighting the burner that's farthest from the tank first and turn it to high. Did the burner light and does the flame height look correct? If so, light the remaining 3 main burners the same way. Did those burners light and the flame heights looks correct? If, so you solved the problem. Remember to always turn the tank valve ON VERY, VERY SLOWLY.
Hope this helped you solve the problem. Happy Grilling.
Jun 01, 2011 | Brinkmann 810-8410-S Stainless Steel...
There is no gas flow to my burners. I have a new
Try replacing the hose and regulator, easy to do and inexpensive.
Jul 12, 2010 | Uniflame FG2204C Grill
Grill doesnt get hot it burns on low it starving for gas
blocked gas line / reg not working/blocked burner orfice needs cleaning , try these
May 22, 2010 | Char-Broil Advantage 463453306
Burner won't turn on
The first question I have is the flame size good on the 2 burners that did light? If the flames are smaller, then you might just need to turn off the tank and disconnect it, then reconnect it and very slowly turn the tank valve on again. You might have turned the tank valve on too fast causing the excess flow valve to close and only give a trickle of gas through. On the other hand, if the flame size was good on both burners, then your igniter may not be lighting the rear burner, but typically if the other 2 burners light, the 3rd burners lights off the others. Did you try lighting the 3rd burner manually with a lighter to see if it was getting gas? If it lights manually, then the spark igniter may be your problem. It's also possible the rear burner has clogged holes from rust or drippings and is difficult to light. Without seeing it, it's just the process of elimination til it works. Try all those things and see if that gets it going for you. Check out my tips & tricks on gas grill lighting for more detailed info. Click on my user name and scroll down til you find it listed on my profile. Good luck. Douglas
May 15, 2010 | Weber Genesis Silver A Grill
No Gas Getting to Back Burners
sounds like you have debris in the gas regulator,remove the tank and look into hose end to see lf its clear.sometimes just tapping lightly on the reg,will release the debris.u may need to replace hose and regulator to burner assymbly.if this doesnt fix it.
Apr 13, 2010 | Weber Genesis Silver C Grill
I have a 5 burner Patio Range barbecue. I can
you probably need a hose and regulator
Aug 16, 2009 | Grilling
Bruner will not heat past 140 degrees, just bought a new tank
I just got done having the same problem. Disconnect the tank. Let the hose hang there for 5 or more minutes to drain any gas. Reattach the hose to the tank. Turn the knob on top of the tank SLOWLY 1/4 of a turn. Light the first burner on the left. Turn the knob on top of the tank another 1/4 turn. Light the rest of the burners from left to right. Don't open the tank valve any more than 1/2 turn altogether. When you changed tanks and hooked up the hose, the regulator in the hose cut back on the flow when the new blast of gas came through. (Its a safety feature.) So draining out the gas from the hose to reset the regulator and turning on the gas SLOWLY should give you good pressure.
Dec 26, 2007 | Kenmore 16322
Gas BBQ - Won't light
hi Be sure the thermostat or heat dial is set properly. If the appliance has a pilot light, be sure it's working. make sure that you connected the pipeline correctly open the faucet of the tank try to fire it up ? working ? good... NO???? close everything(faucets,plugs...) your new tank that you connected is empty.... it happens.... have a good 1
Apr 06, 2006 | Barbeques Galore Turbo Classic 3-Burner...
Kenmore 16691 Grill Logo
49 people viewed this question
Top Kenmore Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Charles T Nevin
Charles T Nevin
Are you a Kenmore Grilling Expert? Answer questions, earn points and help others
