Question about Invacare Stratos Compact Aerosol Compressor
The medicine is not coming out of pipe, air supply blowing, but not pumping the needed meds...
Is there any medicine that can make you out of the pain completely that is caused by neuropathy?
My advise is to check with your doctor before taking any type of medicine or pain killers. Depending what meds you are on you don't want to mix meds. I am not saying this is no good but seek advice before mixing anything.
Dec 22, 2016 | Computers & Internet
How Multi-med card useful for seniors?
Seniors are the fasted growing segment of our population. Seniors have problems of confusion and also because of bad memories they forget to take the prescribed medicines. Luckily, Mutil-med card is a pill organizer that helps seniors to take the medicine in a right way.
Sep 10, 2016 | Medical
How to buy ivf meds online?
Shouldn't these be prescription only? You are taking a big risk with online meds.
Nov 06, 2014 | Exercise & Fitness
There is air coming through the tube but when i hook up the medicine thing and the mask nothing comes out
blockage in the tube a
medicine chamber is not properly fixed and leakage from medicine chamber
mouth piece connecting to the medicine chamber is not prperly fixed
Mar 03, 2011 | Health & Beauty
Vapour does not come out of Omron NEC28 nebulizer
You'll read a lot about making sure that the filter is clean and that the medicine cup is cleaned and that hard water can effect the operation of the nebulizer. However, the problem is most likely in the pump. Even though the pump is running, it is not pushing enough air into the medicine cup. You may even feel air coming out of the tube. When unrestricted, the air will come out, but, once restricted by the medicine cup, the air may not be fast enough to nebulize the liquid. If you want to confirm this, take the tube and hold it to the end of a bike pump, if, while pumpung, you successfully see mist, then you know for sure.
Fixing the pump is not too difficult. Over time, the chamber where the air is compressed becomes dry and, just like a dry bike pump, the air escapes from the chamber due to poor seals. The pump is pretty simple. Make sure it is unplugged from power and remove the screws holding the housing together. Inside you will see the motor, a fan, a power switch and the intake and outtake tubes. Follow the outtake tube to the pump. The junction where the tubes meet the pump is the location of the air chamber. You may need to remove the screws that secure the tubes to the chamber. Once apart, take some grease and lightly coat all of the interior surfaces of the chamber. When finished, reassemble and you're good to go!
Apr 19, 2009 | Health & Beauty
Omron nebulizer will not mist. All tubing is intact. What to do?
Mar 23, 2009 | Omron Healthcare Omron NE-C25 COMP-Air...
Very little mist coming out
Jan 25, 2009 | Mabis CompMist Compressor Nebulizer
Invacare Stratos Compact Aerosol Compressor Logo
74 people viewed this question
Top Invacare Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
gnshome
Level 1 Expert
Are you an Invacare Health and Beauty Expert? Answer questions, earn points and help others
