Question about Sony PlayStation Portable (PSP) Console
Sony playstation tring to down load music from pc to sony playstation using usb
  • 41 Answers
In your memory stick make a folder called MUSIC and stick your music there X:-psp-MUSIC or X:-MUSIC it also has alittle to do with your firmware always mention your firmware when questioning
Posted on Apr 22, 2008
SOURCE:
How to use the usb to down load music from my computer
  1. Insert a Memory Stick into the Memory Stick slot in the left side of the PSP. Depending on how much music you want it to hold, you may need to get a larger one than the stick that came with your system.
  2. Turn on the PSP.
  3. Plug a USB cable into the back of the PSP and into your PC or Mac. The USB cable needs to have a Mini-B connector on one end (this plugs into the PSP), and a standard USB connector on the other (this plugs into the computer).
  4. Scroll to the "Settings" icon on the home menu of your PSP.
  5. Find the "USB Connection" icon in the "Settings" menu. Press the X button. Your PSP will display the words "USB Mode" and your PC or Mac will recognize it as a USB storage device.
  6. If there isn't one already, create a folder called "PSP" on the PSP Memory Stick -- it shows up as "Portable Storage Device" or something similar -- (you can use Windows Explorer on a PC, or Finder on a Mac).
  7. If there isn't one already, create a folder called "MUSIC" inside the "PSP" folder.
  8. Drag and drop image files into the "MUSIC" folder just as you would save files in another folder on your computer.
  9. Disconnect your PSP by first clicking on "Safely Remove Hardware" on the bottom menu bar of a PC, or by "ejecting" the drive on the Mac (drag the icon into the trash). Then unplug the USB cable and press the circle button to return to the home menu.
Nov 28, 2010 | Sony PlayStation Portable (PSP) Slim...
I want know how the download video and music
connect to a pc using a usb cable
press the home button should be little and on the lower left
using the left and right (d-pad) buttons find settings, then the up and down for usb connection
press the x button on your psp
a device driver should pop-up on the pc (pay attention to which driver or port pops up
create a folder and name it psp
within that folder create a music folder (just name it music)
copy your files (mp3) into that folder
press the o button to finish
Nov 25, 2010 | Sony PlayStation Portable (PSP) Console
We've lost PSP manual and need a new one.
Step 1. Connect your PSP to your computer using a USB leab.
Step 2. Goto settings on your PSP and select USB connection
Step 3. Look in "My computer" on your PC or laptop and your PSP will be listed as another drive.
Step 4. Double click the PSP drive (usually E:) and then right click on the window that opens and select "New Folder". Call this new folder "Music"
Step 5. Drag all your MP3 files into this new music folder you created.
Step 6. Press "O" on your PSP to exit USB connection.
Step 7. Select the music menu then scroll down to Memory stick. All your music should be in that folder.
Hope this helps
Aug 01, 2010 | Sony PlayStation Portable (PSP) Console
How to load music from P C to psp
well you need a mini usb cable and the memory card to be inside the psp. then simply plug the usb cable into the pc and usb and open the files. then its as simple as clicking and dragging
Jan 30, 2010 | Sony PlayStation Portable (PSP) Console
I would like to play my ipod through my playstation, is it possible. I have a USb connection but the playstation does not pick it up. Carien SA
i have an 80gb ps3 this is what i done
  1. step 1 Sony PS3
    Turn on your Sony Playstation 3 console and wait for the main menu to come up.
  2. Step 2 Ipod USB connector. Connect your Ipod to your PS3 with the USB cord.
  3. Step 3 Go to the MUSIC icon.
  4. Step 4 Scroll Down to USB Device (Ipod).
  5. Step 5 Press the Triangle button. (If you press X you will not be able to play the songs.)
  6. Step 6 Press the X-button on the "Display All" icon.
  7. Step 7 Scroll down to "Music"
  8. Step 8 Now you can view all of your music and songs and play your Ipod on your PS3! You can create playlists and listen to all of your favorite music from your ipod through your Playstation 3.
Nov 27, 2009 | Sony Playstation 3 (PS3) Console
How can i down load music from computer to sony
plug the usb cable from pc to your player then download your mp3 file. you can use copy and paste also. copy the file from pc and paste to your player.
Apr 01, 2009 | Sony Network Walkman NW-E005 MP3 Player
Downloading music from pc to psp
you have to put hte music in either / is your root of he memory stick /MUSIC or /PSP/MUSC if folder not there create it
Sep 08, 2008 | Sony PlayStation Portable (PSP) Console
How to download music from a computer to psp
Ok put ur psp in to usb mode using a usb cord and connecting it to ur PC on PC the folder should pop up and asks you if you want to open the folder then just in that folder there should be another folder called MUSIC if not make one. then put all of ur mp3 files in there
P.S. It is the same process with putting videos on the psp but the folder should be called VIDEO.
Feb 17, 2008 | Sony PlayStation Portable (PSP) Console
Putting music on PSP!!!
Using a USB connect to your PC , then put your MP3 on music folder. just use compatible USB then go to your psp USB enable.
Feb 10, 2008 | Sony PlayStation Portable (PSP) Console
Sync music to psp
  • Hook USB cable between the PSP and PC
  • On the PSP under Settings, select USB connection
  • Your Vista PC should recognize that the PSP is connected. The PSP should be displaying "USB Mode".
  • On the PC add music to the removable drive that represents your PSP memory stick. Put the music in the Music Folder.
Jan 23, 2008 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
16 people viewed this question
Top Sony Video Game Consoles & Games Experts
shevantha perera
Damen Wong
Damen Wong
Nikki  Mclean
Nikki Mclean
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
