Question about Maytag Neptune MDE5500AY Electric Dryer
After running for about 10 minutes it blows the breaker. I have had this dryer ever since they came out and it just started doing this 2 weeks ago. I cleaned out the dryer vent to make sure it was lint free and not clogged up.
  • Maytag Master
  • 8,220 Answers
You might have a problem with lint buildup or a bad blower wheel causing the dryer to overheat. It could also be the heating element is broken and portions off it are welded to the heater chamber causing the heater to come on and blow the breaker. It could just be you have a bad breaker.
NEPTUNE SERVICE MANUAL
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Jul 12, 2010
Dryer blows circuit breaker after running 10-20 minutes.
indicates problem motor , overheating in the wiring or excessive loads in the drier
Jun 07, 2017 | Kenmore Dryers
When pushing the start button the dryer will come on for about 10 minutes and then stop. Then sometimes it doesnt come on at all
If it starts right back up after stopping there is an electrical problem maybe at the motor start switch. If you have to wait for an hour before it will start again then the problem might be that the motor needs to be cleaned of a lint build up.
Oct 23, 2012 | Roper RES7646KQ Electric Dryer
Electric dryer runs for 10 minutes aand kicks out the breaker
You probably have a breaker that cannot take the draw of the dryer. See if a slow blow breaker is available.
Sep 24, 2011 | Dryers
Dryer is blowing breaker after running for 5- 10 minutes took apart and cleaned everything. still having the same problem. How do i fix?
If its running normal and heating it could very well be your breaker is weak and needs replacing.
Sep 21, 2011 | Kenmore Dryers
A few weeks ago our kenmore dryer would only dry for 10 mins or so at a time, finally after about a week it wouldn't come on at all. Had a repair man tell us it was the timer. We ordered a new timer...
it it tried to turn on when you flip the breaker then the problem could be a loose connection more often than not dryers pull allot of amperage and if the wires are loose it will from an arc similar to welding and melt the wires the unit runs only when the wires make full contact.
1. turn your breaker off 2 remove the area where the connections come into the dryer check there if all is good there go to 3 3 check the plug 4 check the wall connector 5 check connections at the breaker
as always follow safety guidelines when working on high voltage this is 220 volts
Best of Luck
Jun 02, 2011 | Kenmore Dryers
The Whirlpool Ultimate II dryer heats up at first and then the heat shuts off after approximately 10 minutes and doesn't come back on. If I let dryer cool for 10 minutes it will do the same thing again.
If the dryer is not drying the clothes then you would need to check for the following things-
Electric Dryer---
1. Inspect the fuses and circuit breakers they may have burned out or tripped. Usually, dryer will still tumble but not create heat if a fuse or a circuit breaker is not working.
2. Check for the amp reading at 240 V, it should have reading of 24, 21 and 3 amp (approx.) for 2 lines and neutral respectively.
3. Heating element may have turned or the connection to the element might be loose. Sometimes a shorted circuit element will keep on blowing the fuse or circuit breaker.
4. Motor wiring shorting to ground.
Hope this helps...
Daniel
Sep 14, 2010 | Dryers
Blowing breaker
hi. I can help you.
Electric dryers use 220 volts or two power lines of 110 volts each. Some components in the dryer need only 110 volts; the heating element requires 220 volts. So it's possible for one part of the dryer to be fine and another part to have a short circuit. Short circuits can be caused by the heating element, the main power cord, or any other part of the internal wiring. To decide where the problem lies, unplug the dryer, then:
  • If the circuit breakers or fuses remain on and/or intact when the dryer is unplugged, it's likely the problem is with the dryer. Contact a qualified appliance repair technician.
  • If the circuit breaker trips or the fuse blows when the dryer is unplugged, it's likely the problem is with the house wiring, fuse box, or circuit box. Contact a qualified electrician.
Jun 22, 2009 | Kenmore 63942 Dryer
Dryer blows breaker after 10 minutes of usage
Check the receptacle, the plug and the cord itself and lastly the terminals where the cord goes into the back of the dryer. Maybe the breakers itself need to be replaced.
Feb 15, 2009 | Maytag MDE9316 Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
32 people viewed this question
Top Maytag Dryers Experts
Marvin
Marvin
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
