Question about Hoover U6616-900 WindTunnel Bagless Upright Vacuum
Vacuum cleaner smell
Our Hoover WindTunnel has recently started emitting a bad odor when we use it. We recently bought a new house, and the previous owners had dogs, but the carpet was professionally cleaned before we moved in. I have replaced all of the filters and belts to no avail. At this point, I have to remove and rinse off all of the filters after every time I use the vacuum to prevent stinking up the entire house. Any suggestions?
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 310 Answers
Http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=40540&thid=528723
Posted by lcw1 on Apr 20, 2008
Our Hoover Windtunnel has recently started emitting a bad odor when we use it. We recently bought a new house, and the previous owners had dogs, but the carpet was professionally cleaned before we moved in. I have replaced all of the filters and belts to no avail. At this point, I have to remove and rinse off all of the filters after every time I use the vacuum to prevent stinking up the entire house. Any suggestions?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
Hoover U6616-900 Windtunnel Bagless Upright
I think you are right, if it is not the switch then it would be the motor. Does it smell bad like a burning smell? If so it is definitely the motor and then @ that point you may want to get an estimate for motor replacement, and keep in mind of what you spent on the vacuum versus what the cost of repair might be. My own rule of thumb is if it cost more than ½ of the price I paid for it then you have to decide – do I want to pay the repaired cost for the vacuum or do I want to purchase a new one. Just a suggestion... You may want to check with your local vac dealer. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Don – The Vac Man
Go Ahead. Use Us.
Posted on May 07, 2008
Smelled burned wire, then motor just slowly died. Upright Windtunnel 2.1 bagged
I suspect it's the motor you smelled and not a wire. To find out for sure, you can either remove the motor and smell it (bad odor means bad motor) or take it to a repair shop and let the repair tech check it out.
Jan 26, 2011 | Hoover U6630-900 WindTunnel Bagless...
I have a windtunnel vacum cleaner. When I
It might be a slipping rubber belt, is the brush roller moving when you look underneath? If it's a self propelled machine there might be another slipping belt. Friction from fast rubbing rubber can smell like it is burning.
Jan 16, 2010 | Hoover Company Wind Tunnel U53019 Upright...
I have a Hoover Elite Rewind vacuum. Actually,this is my second one. However, after about 4 months of use, it emits a "sour" smell when I'm using it. I empty the cannister before each use and clean out the...
does it smell like an electrical burning odor? could very possibly be the motor going bad already. ive seen it happen. but if not try freshwave odor absorbing pearls. i carry it in my store and we do have shipping. Truly the only thing you should use to get rid of odors in a bagless vacuum, it wont clog your filters
Jan 03, 2010 | Hoover U5507900 Elite Rewind Bagless...
Hi I have model u64330-900 hoover windtunnel. It
It sounds like your vacuums belt is stretched and worn. You'll need to replace it. Below is a link to a website that gives instructions with pictures on how to change the belt. You should be able to get a replacement belt at any department store or vacuum retailer.
I hope this helps you.
http://www.info-vacuum-cleaner.com/hoover-vac-belt.php
Sep 24, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
I've had the Hoover Windtunnel for a couple years now. Its starting to smell when you vacuum. Why and how do I fix it???
I was experiencing the same problem right after changing the belt for the first time, as my Hoover is just a few months old. I am assuming what you are smelling is burnt rubber, like your belt, right? Well, if you have changed your belt recently, make sure you are using the right one. If you're not using Hoover's authentic belts and you're buying it from Wal-Mart, make sure it's the correct one, otherwise it won't work right and/or it will give off a burnt rubber smell. One other thing you could try doing first, is raising the carpet height adjustment up a notch or two. If you have it too low and your beater-bar/brush roll has to work too hard, it will start to smell also.Good luck!
Aug 07, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover Vacuum Cleaner Bad Smell
change filters. the filter inside the unit and the one on the side needs to be changed once a yr. (these are not to be washed, only the side filter if foam can be washed ). also flat belt change every 6 months and the v-belt once a yr.
Jul 19, 2009 | Hoover U6616-900 WindTunnel Bagless...
Hoover Bagless WindTunnel vacuum cleaner.
very easy. you have clog. take the brush off look where the hole is thats where the clog is. it might be in there you might have to take the housing off of the motor
May 08, 2009 | Hoover U5753-900 WindTunnel Bagless...
Hoover S3639 Windtunnel Vacuum not on after burning smell
how old is it ?maybe the motor went south.take the cover off and see if you see any burn marks ,maybe you can narrow down the burnig smell.i don't charge people for helping i just enjoy helping.314-628-9153
Apr 03, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover Model u5453-900 brush roller don't spin
Have you checked the  belt on your Hoover? It could need replacing.
When you say bottom of your cleaner to make it smell better, what are you referring to? It could be the hose or bag. If a bag is odorous try some bicarbonate of soda in the bag so that neutralizes the odors contained.
Another option is to clean out the hose. This can be down with many wet wipes or similar cleaning wipes pushed down the hose at one end and pulled out the other. Its a tricky maintenance issue but one which can be done if you have patience! Filters should also be replaced to ensure the vacuum is clean.
Alternatively if the hose comes off easily, lay the entire assembly in a bath and allow it lay flat in water with washing powder. The only problem with this is that you will need to let it dry for a day or two before the hose is completely dry.
Mar 30, 2008 | Hoover U5453-900 WindTunnel Supreme Bagged...
Hoover U6616-900 WindTunnel Bagless Upright Vacuum Logo
455 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
