Question about Kenmore 400 6942 Dryer
Pully fell off is there a diagram to show where it goes and how to put it back on?
  • 78 Answers
You can possibly call sears and get a letter manual on this dryer thats your best bet,
Posted on Jul 12, 2010
Bolt fell out engine pully on gt235
put some loctite on it and drive it back in., maybe the shaft is worn.
Jun 28, 2017 | Cars & Trucks
Mechanism that snaps the presser foot on and off fell apart, need a diagram to show how to put the little black plastic part back on and where the black spring that fell out goes
Assuming you have all the parts, the spring goes inside the little hole in the back of the mechanism.
You then position the lever behind it, line it up with the bar that holds the lever, and put the lever pin back in.
This is very tedious, and can be frustrating. You might consider paying for a new one.
Apr 10, 2013 | Dual Sew 3400 Mechanical Sewing Machine
How do I put the drive belt back on my yard man automatic riding lawn mower?
The v side of the belt goes in the v of the pullies and the flat side of the belt rides on the flat pullies. It looks like the flat idle pully is bent out of alinement. The one showing in video with no belt on it that is the last pully the belt runs on before returning to engine. The belt comes from the engine to a spring loaded flat pully, to v pully on right of mower ,to v pully on left, to flat idle pully // that looks to be bent // then back to engine. Put belt on all pullies saving the spring loaded pully for last.
Apr 09, 2013 | Garden
Want to fit fan belt cant find the proper way
You have to find the tension pully. using a 3/8 socket wrench. not the socke but the actual wrench. place the square end of the wrench into the notch on the pully and either push or pull (depends on the v-belt system) and it should move. place your v-belt around the pully's according to the diagram under your hood leaving your tension pully to be the last one the belt goes on. Move that tension pully as mentioned above and place it the belt on the pully. The diagram under the hood should also show you where that tension pully is located.
Oct 04, 2010 | Ford Fusion Cars & Trucks
Diagram of pullies and belts on 86 toyota mr2
If you are talking the a/c pulley and alternator pulley, I am pretty sure the belts are different sizes (different number of ribs in the belt). So, you can just look carefully at the ribs and put the right belt on the right pully. from memory, the A/C belt goes on first and all the pullies towards the front of the car are used for that belt. The Alternator belt goes on next, and all the pullies from the crank shaft toward the back of the car (from the crank pulley) go to that. I could have those reversed, but the ribs on the belt will show you for sure. have fun!
Mar 06, 2010 | 1986 Toyota MR2
Need a heater core diagram for a 91 mazda b2200
The only thing to do is get a diagram from the MAZDA dealer parts dept. "A few parts fell out" is way to vague to help you.
Dec 30, 2009 | 1991 Mazda B-Series
Need diagram for instaalling serpentine belt on 1989 chevy s10 2.5 engine belt broke and no diagram
Picture is for the carbureted model but has the same patter as my fuel injected model. It's actually pretty easy to see how it goes. If the pully has groves then the grove side of the belt will fit right in it prefectly. If it's smooth then the back side of the belt with run along it. To loosen the belt tensioner do two things. first in the picture below you will see in the top middle you will see the tensioner. The back of the belt runs along it. You will notice that it looks like a solid peice. loosen the top slighty with i believe a 15mm. After that connect to the pully attached to it and pull back to the passenger side until you can slid the belt off the alternator. put back on in reverse order. really really simple once you do it. good luck
Oct 11, 2009 | 1989 Chevrolet S-10 Blazer
Drive pully fell off
Which DRIVE PULLY FELL OFF?.. Tell you what, Go to www.hmaservice.com and register( Vehicle by VIN). Afterward, you have access to shop manuals, service bulletins, wiring diagrams, etc. about your vehicle.
Aug 03, 2009 | 2003 Hyundai Santa Fe
I own a ford focus 2006 the belt fell off I'm not sure which one and a need to be able to put it back on.
well, the belt does not just fall off. If the belt has come off it's because one of the pullys have failed.there is only 1 belt on that car, there should be a diagram under the hood that says "drive belt routing"
You need to release tension on the tensioner pully with a serpentine belt tool or a long 3/8" breaker bar. rout the belt according to the diagram, then re apply the tension
May 17, 2009 | 2006 Ford Focus
Serpentine belt came off need to know how it goes back on
this is hard to exsplain without showing you a photo ,but i will try. first get the belt around the engine crankshaft which is the pully closest to the bottom and center of the engine. when standing in front of engine start to lead the belt to the right and connect to power steering pump then up to generator, next thare is going to be a smooth pully not groved like the others to the left,put the smooth side of the belt on bottom of this pully and continue left to the ac/compressor go around ac/compressor andstraight down to the belt tensioner , and then right over to the water pump which has a smooth pully not grooved. remember the smooth pullys will always carry the smooth side of the belt and the grooved pullys the grooved side of belt. the belt tensioner will half to be released by a serpantine belt tensioner tool sold at your local auto parts store. these instructions is for 3.8 liter engine, if you have a 4.6 liter engine it will be different, so repost stating that you have a 4.6 if this dont help
Dec 22, 2008 | 1997 Mercury Cougar XR7
Kenmore 400 6942 Dryer Logo
78 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
