Question about General Electric GE SmartWater Household Water Filtration System - GNWH38F
I have a 35 gal tank. i need to add a solution to it. the solution calls for a 1 part solution to 100 parts water ratio. how much solution do i add to 35 gal
    Novelist:
  • 145 Answers
The solution you have should be more specific with units but I don't believe the units will matter. 1 part solution to 100 parts water, would mean to me that if you have 100 gallons of water you would add 1 gallon of solution...but you don't have 100 gallons you have 35, so take 1/100th of 35 and that gives you .35 parts solution. Adding just between a quarter and a half of a gallon (closer to the half) will be perfect for your amount of water.
Posted on Jul 13, 2010
Rheemglas fury model # 41V50 the approx. 5 gal pressure tank above the water heater is corroded and leaking. how difficult to replace and what is the name of the tank
1) If tank is connected with single pipe to cold water line, then it could be expansion tank.
Add a comment with photo so I can see.
http://www.fixya.com/support/r6568559-post_photograph_fixya_questions_answers
2) Take photo to plumbing supply store.
Expansion tanks unscrew from pipe. Simply install it and it has internal pressure bladder.
Has to install on cold water line.
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Apr 10, 2011 | Rheem 50 Gallon FVR NATGAS Water Heater...
Can you send me a manuel identifying all parts and how they work
You posted under electric water heater.
Tank-type electric water heater is a simple appliance that I find fascinating.
1) I do not have specific manual that explains the parts, nor have I seen one.
However, following links give resourceful do-it-yourselfer full information how electric tank type water heater works, and how parts work together, and what the sequence of operation is, and how to troubleshoot and repair typical tank-type electric water heater.
http://www.whirlpoolwaterheaters.com/learn_more/HowWaterHeatersWork.aspx
http://waterheatertimer.org/How-it-works.html
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
http://waterheatertimer.org/How-water-heater-thermostat-works.html
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html
2) If you are strictly looking for a pdf file that explains parts: Here's how I make pdf files to post on Internet:
You can copy content from links above, and paste into ordinary Office document.
Download CuteWriter for free, and then 'print' your Office document and select CuteWriter as the printer, and it will make a pdf manual.
Make manual as long or short as desired, and CuteWriter will space pages correctly.
Post your manual on your website for free, and then add a comment to this thread and include web location of your manual so others have free access to your work.
Add a comment for more free help.
Mar 23, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
How do I fill water heater
Once the hot and cold pipes are connected to water heater, then open bathtub spout on hot side, turn water on so tank begins to fill.
After tub spout is running full stream without air, then water heater is full and it is safe to turn on the heater.
Turning on gas water heater before tank is full can damage tank.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Turning on electric heater before tank is full will burn out elements. Replace elements.
Mar 19, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Have an atwood 10 gal water heater that leaks but I can't find the leak. The lines are dry. Have a lot of water in interior under the bathroom tile.
Also open cover and check if element is leaking. Elements frequently leak at rubber seal.
Next suspect is rusted-out tank that is leaking through a thin-place in the tank.
Otherwise there are not many other places to check if pipes are dry, especially with the Atwood 10 gallon.
I suggest replacement.
http://waterheatertimer.org/Water-heater-is-leaking.html
Mar 01, 2011 | RTO Atwood Water Heater - 6 Gal LP
80 gal Whirl Pool electric water heater. Does it have 1 thermostat or 2?
There are two ways to tell:
1) See if tank has 2 removable panels on side.
2) Look at label on side of tank for upper and lower element wattage.
http://waterheatertimer.org/Figure-Volts-Amps-Watts-for-water-heater.html
http://waterheatertimer.org/How-electric-water-heater-works.html
http://waterheatertimer.org/DIY.html
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on water heater or any do-it-yourself project.
Feb 14, 2011 | Whirlpool Water Heaters
Rheem 49 gal model 81V400B - hot water lasting only 5-10 minutes then takes an hour to heat back up.
Ordinary tank-type electric water heaters are fully repairable by homeowner.
A) Basic info on Rheem
Rheem electric water heater website:
http://www.rheem.com/products/tank_water_heaters/electric_water_heaters/
Find age of Rheem: look 2nd and 3rd digit of serial number, for example 06 is 2006
B) Water heater has some hot water.
That says certain things: upper element is working, water heater electricity is working, reset button is not tripped, and heater is not experiencing run-away overheating event.
C) That leaves 4 suspects that cause lower amount of hot water.
1) TP valve is running hot water out of tank -or- leaking faucet is running hot water out of tank.
Check for leaks
http://waterheatertimer.org/How-to-replace-TP-valve.html
2) Lower element is burned out.
Test lower element using inexpensive multi-meter from Home Depot.
http://waterheatertimer.org/How-to-test-water-heater-element.html
Replace element with same wattage shown on label, and clean out sediment:
http://waterheatertimer.org/How-to-clean-sediment-out-of-electric-water-heater.html
2) Upper or lower thermostat is bad.
Replace both thermostats for about $25.
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
3) Burned or shorted wire located between upper and lower sections of tank.
Turn off power. Open covers on side of tank. Remove insulation. Inspect parts for signs of high heat and burning. Especially check lower element. Tighten any loose wires. Replace part that shows signs of burning.
Put insulation and cover back over thermostats so cooler outside temperature doesn't cause thermostat to misread tank temperature.
Feb 03, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
I have a Rheem model number is 81V52D and I think I need to check the thermostat. Do I need to drain the unit in order to check the thermostat?
No you do not need to drain water heater when checking or replacing thermostats:
Water heater is drained when replacing elements or cleaning sediment out of tank.
Also look at following links: These links can teach you everything about fixing ordinary tank-type electric water heater using generic parts from hardware store.
http://waterheatertimer.org/How-to-replace-element-and-clean-sediment-out-of-electric-water-heater.html
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Jan 20, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Hello, I have a Rheem 81V52D 50 gal. residential water heater. I had the upper element short out. I replaced both the upper & lower elements with the 4500 watt 230v. My problem now is that the upper...
It's probably bad upper or lower thermostat.
BUT... new element could also be shorted.
OR ... original tank is rated 1500 watt elements look at label on side of tank.
I always replace both thermostats to save time.
Lower thermostat costs $10 at Lowes.
For a price, expert speaks with you over phone while you work on heater or any do-it-yourself project.
Jan 16, 2011 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
General Electric GE SmartWater Household Water Filtration System - GNWH38F Logo
56 people viewed this question
Top General Electric Water Heaters Experts
Paul Carew
Donni Steen
Are you a General Electric Water Heater Expert? Answer questions, earn points and help others
