Question about Sony Computers & Internet
VISUALIZATION ON LCD SCREEN On my laptop Vaio VGN CS 14 G became dim after cleaning the screen with glass cleaningsolution
  • 10,515 Answers
Which cleaning solution you have used?
Thanks!!
Posted on Jul 12, 2010
  • rajendragaur Jul 12, 2010
    Colin glass cleaning solution
  • taran_2005
    taran_2005 Jul 12, 2010
    Thanks for your response!!
    This cleaning solution s ' Never Recommended for LCD and TFT ' It is ONLY recommended for CRT monitors. You should have purchased the LCD cleaning kit rather than Glass cleaning solution.It seems that it might have damaged the screen. These glass cleaning solutions usually affect the coating of the LCD screen. As the damage has already been done, there is no other option than to replace the screen.
    Unfortunately, there is no good news that i could share.
    Let me know,if needed further assistance.
    Hope i helped you.
    Thanks for using ' Fixya ' and have a nice day!!
Sir, i want to my laptop Sony vaio
white screen indicates either:
i. lcd cables gone bad.
ii. the logic board fried.
neither, you should replace the whole lcd.
Oct 10, 2013 | Sony Vaio Vgn-c290 13.3" Lcd Wxga Laptop...
Sony Vaio vgn-fe590p, when starting up the screen lights up, but it is dim and blurry. Could this be the inverter, or the lcd screen is bad?
Start with drivers,http://esupport.sony.com/US/p/model-home.pl?mdl=VGNFE590P&template_id=1&region_id=1&tab=download#/downloadTab . Has it been damaged? Dropped, jarred, etc. It may be the monitor/graphics is going. Hard to say exactly. Is it overheating?
Dec 03, 2012 | Sony VAIO VGN-FE590 Notebook
The display system of the vaio notebook went dim then finally died out.what is the possible problem and solution to the same
Hi akeyow..
Sounds like you have either a bad lcd screen or a bad lcd inverter.
To check to see if the screen is bad, connect the notebook to an external monitor that you know is working...if it works the you will have to replace the lcd screen.
If it doesn't work then the internal lcd inverter, will need replacement.
Both replacements take a better than average skill to replace, maybe best left to the pros...or sometimes you can check out YouTube and some people show you how to do it.
Please take time to rate me
Sony lcd replacement:
http://www.screentekinc.com/Sony_Vaio_VGN-CS_Series_VGN-CS215J~W--14.1-inch--1280x800-wxga-laptop-lcd-screen.shtml
Here is a link to the YouTube webpage for replacement, could not find your model, but I am sure you could use some of the info to replace what you have...
http://www.youtube.com/results?search_query=Sony+VAIO+VGN-CS215J%2FW+screen+replacement&aq=f
Lcd replacement, lcd inverter replacement
Aug 22, 2011 | Sony VAIO VGN-CS215J/W Notebook
My sony laptop vaio cs vgn-cs36's lcd got a straight line on bottom of the screen. what should i do to fix those line? because the line is getting worst now. help me! i bought it last year oct but...
That sounds like you require a new/replacement screen.
Check your date of purchase with a warranty repair in mind.
Do it quickly as it may still be covered.
Jan 08, 2011 | Sony VAIO Notebook
I cant see the bottom part of my pc coz its distorted. Then my screen usually blinks or with some disruptions although the program is not affected. Then there is a noise inside my pc's body everytime i run...
Dear Valued Sony VAIO customers,
Sony has identified a limited number of VGN-CS series computers which may display a horizontal line on the LCD screen.
Applicable Models
  • VGN-CS1xx series
  • VGN-CS2xx series
  • VGN-CS3xx series
Resolution
As part of our commitment to quality, for an additional 24 months beyond the standard limited warranty period, owners of an affected model displaying the symptom may be eligible to receive service for the LCD screen from Sony free of charge.
If you are currently experiencing this issue, please contact us at 1-888-476-6972 to arrange service.
Dec 03, 2010 | Sony VAIO VGN-CS215J/W Notebook
My Sony Vaio VGN-NR498E laptop with Windows Vista recently had some issues. The light in the screen seems to have went out. If you hold a lamp up to the screen you can make out the background of the screen...
A dim laptop lcd screen is either the result of 1) a faulty inverter which is a separate piece from the lcd screen or 2) a burned out backlight which is part of the lcd screen. In the majority of instances, the inverter is the cause of the problem and not the backlight as most people tend to assume and therefore does not require the purchase of a lcd screen.
I have done some research and it seems you can fetch a new inverter for around $59.00
Nov 08, 2010 | Sony VAIO VGN-NR498E/S Notebook PC
My sony vaio screen has some weird lines down the toolbar... everytime they're more, they're almost half the bar and it looks like it has some kind of problem
Try the below link...
Click here for more information
Jan 20, 2010 | Sony VAIO VGN-CS320J Notebook
Sony vaio vgn nr160e laptop - no display (intermittent). Attached monitor shows display fine and laptop works fine. Screen used to flicker intermittently (last few days).
You may have a defective CCFL backlight, it may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight. It could be a faulty inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out, usually the CCFL lamp fails before the inverter.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site: -
www.ladparts.net
Oct 20, 2009 | Sony VAIO VGN-NR160ET Notebook
The screen fades out sometimes and i have to wiggle it to get it back. i have a sony vaio vgn-cr115e
www.ladparts.net
Oct 19, 2009 | Sony VAIO VGN-CR115E/P Laptop
My sony vaio vgn-n365e screen is Dim
The fault could be a faulty CCFL lamp or inverter.
To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Jul 24, 2009 | Sony VAIO PCG-K23 Notebook
Computers & Internet Logo
23 people viewed this question
Top Sony Computers & Internet Experts
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
