Question about GE (PSS26MSRSS) Side by Side Refrigerator
Where do I connect the water line to on my GE bottom freezer?
There is a black tube running from the bottom left corner going across to a point about 3 ft from the base. This would seem to be where I connect but I'm unsure about cutting into this tube.
  • GE Master
  • 8,220 Answers
You connect you water line to the water valve.
DO NOT CUT MY HOSES. LOL
PSS SERVICE MANUAL
Posted on Jul 12, 2010
Water is freezing in the bottom drawer GEProfile bottom drawer freezer and leaking water on floor
Sounds like your drain tube is blocked in the freezer for the defrost water. The drain tube is in the back left or right corner and will have a drain trough under the cooling coils tilting towards it. That trough will probably have ice built up all over it. Once the ice is out you may need to force hot water down the drain tube. I use to use a turkey baster with a rubber hose on it to force the hot water down the drain tube. Its clear when you put water in the trough top and it goes down the tube freely to the drain pan under the refrigerator.
Feb 28, 2015 | GE Profile PDS22MHR Bottom Freezer...
Water & ice in bottom of freezer
Most likely cause is a blocked defrost drain line. The freezer has a defrost cycle which turns on a heating element below the evaporator to clear any built up frost or ice. This defrosted water should then drain through a plastic line to below the unit. Check for drained water in the drip pan or plastic moulded container over the compressor. If it is completely dry then follow the blocked drain line, clear it. If further assistance is required please provide details of What brand and Model your unit is? Hope this helps.
Feb 14, 2014 | GE Refrigerators
Have a GE hot point HSS25GFTABB, removed doors to put inside house after a move and the ice maker works, but when you fill with water, it runs down the line dripping at the bottom of left door
Inspect the line crefully at the bottom of the door where it connects to the cabinet supply. The line may have been damaged when and if the doors were removed.
HOPEFULLY it is a small nick in the tubing casuing the water leak, and not the line inside the freezer door as the water line is foamed into the door and the entire door would have to be replaced to resolve an internal leak.
The coupler at the door connection is a push-lock syle coupler and to seperate the line you need to press the white collar into the blue barrel connector to relese the tension.
Jun 14, 2010 | GE 25.0 Cu. Ft. Side-by-Side Refrigerator...
No water will come out of the door
At the bottom of the freezer door ( remove the kick plate ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , or , I have heard using an air tank will blow the ice out of the line in the door . If no water comes from the line under the refrig , while activating the pad , then replace the water valve , behind the refrig , the piece the wall water line connects to on the refrig . GE has a dispensor heater pt. # WR41X10173 to stop this freezing and it comes with instructions .
May 25, 2010 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Water running out of tube from fridge into bottom of freezer door that leads up to water dispenser ?
Is the water leaking from the bottom of the freezer door ? ( new door ) line is not replaceable inside the door .
Is the water leaking from the tubing at the connector ( about 6" from the bottom of the freezer door ) ( remove both lines from the connector , cut off about 1" of each tube and reinstall into the connector )
To access , remove the kickplate by either removing 1 screw on each side or just pull off ( held on by clips ) .
Apr 17, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
The bottom of my refrigerator fills with water beneath the storage bins. It is a top freezer model.
Remove the food and the ice maker from the freezer ( if equiped ) . Remove the rear freezer panel . Using a hair dryer , start in the middle , below the coils , defrosting , until you see the drain hole . Use hot water to help defrost the hole . Once water starts going thru the hole , use a small hose inserted into the hole , and blow thru , to remove any unseen debris in the drain line .
Apr 17, 2010 | GE Profile 21.6 cu. ft. Top Freezer...
Water running out bottom of freezer
That's exactly what it it. Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Aug 27, 2009 | Kenmore 53642 / 53644 Side by Side...
Water line connectors/tubing? GE Monogram Refrigerator
go to your local appliance parts dealer , they should be able to get the parts you need
May 19, 2009 | GE Monogram ZISS420NRSS 42" Built-In...
GE Side by Side, water leak inside freezer door
you will need to [possibly replace the solinoid valves on the backdside of the refrigerator
Jan 28, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
No water flow
turn the freezer side to zero fridge side will zero also . click for water it should work . just worked for me no water for 1month replaced the filter and everything.
Dec 06, 2008 | GE GSH25JSRSS Stainless Steel Side by Side...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
46 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
