Question about Amcor AMC12000 Portable Air Conditioner
Amcor AMC12000E Air Conditioner doesn't cool
I have an Amcor AMC12000E Air conditioner which has just stopped cooling the air. The filters are clean and the tank was emptied recently. A couple of days ago, when set on 'auto', the air-cooling began to come on and go off immediately. Now the it doesn't come on at all, though everything else seems to work.
Thanks for any help
  • 423 Answers
SOURCE: I am looking for an exhaust hose kit for Amcor portable air condi
While you may find a kit specific for your portable air conditioner, it would be far easier and faster to simply measure the diameter across the exhaust port on the back of the unit. In US measurement, it may be 4 inch or 5 inch across.
Go to a hardware store (a quaint local one or a Home Depot if you must.) They will have a kit (for clothes dryers) that will most likely include the flexible tubing and two clamps. They also will have separate/bulk flexible tubing and clamps available.
Depending on how permanent the air conditioner installation is, the same hardware store will have exhaust outlets that can go through the wall and probably fit into a partially opened window.
Please post back here with further questions or clarifications on your problem.
Good Luck!
Posted on May 08, 2009
SOURCE: Duo-Therm air conditioner/thermostat problems
The solution was to purchase and install a new thermostat. Works perfectly now.
Posted on Jun 02, 2009
  • 92 Answers
SOURCE: Display says emergency tank full, air conditioner doesn't work
there is a tab on the tank,make sure it depresses it when yur reinstall tank
Posted on Jun 25, 2009
  • 22 Answers
SOURCE: amcor af11000e air conditioner. The fan runs, but
it is either the capacitor or it has no freon you can replace cap but not add freon not worth it. you should return it if you can
Posted on Aug 07, 2009
  • 59 Answers
SOURCE: replacement parts Amcor AmcorAire UCHW-H12AF2
Amcoraire USA went bankrupt in 2010. Bought out by Pridiom group. Service Dept 1-201-266-8234 or 1-201-562-9777
Posted on Jan 29, 2011
Amcor KF9000E portable air conditioner manual
My amcor kf9000e has stopped blowing cool air. What could be wrong with it?
May 18, 2012 | Amcor AF9000E Portable Air Conditioner
No cooling and no air going out the exhaust
COULD BE THE motor froze. Usually the same shaft does the cool side and the hot side does either fan spin freely. Have to admit oil usually doesn't fix it longterm
May 15, 2012 | Amcor ALTL-12000E Portable Air Conditioner
I HAVE AN AMCOR MODEL MF8000E AND IT DOSNT COOL BELOW 70 AND I SET THE TEMPERATURE TO COOL @ 65 WHY? THE FILTERS ARE DIRTY
If your filter is dirty you need to clean it or change it. Also check the condenser it might also be dirty and needs cleaning. When was the last time you changed your filter?
Jul 20, 2011 | Amcor MF8000E Air Conditioner
The unit does not blow cold air any more. Inside is sometimes hotter than outside. will be 85 inside but 80 outside. Have thoroughly cleaned filters, but no change. "comp" light is on
Hi, The compressor has gone bad and it will cost more to replace it then the unit is worth... buy another unit and buy anything BUT an Amcor unit... they are junk!!
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Jul 12, 2011 | Amcor AF9000E Portable Air Conditioner
Fan works, cooling doesn't
check your condensor for dirt and any resets
Apr 08, 2010 | Amcor PLM-14000E Portable Air Conditioner
Ive got an amcor air conditioner, will it blow hot air aswell as cold,
If it blows hot and cool air, it means that you aircon is
not having an isolation of the evaporator and condenser
air. Please have a technician repair the air leak. Hot air from the condenser must be separated from the cool air
of the evaporator. Hope this will help you.
Jan 04, 2010 | Amcor PLM-14000E Portable Air Conditioner
E4 message no cool air. Heat is fine, fan and
If the fan inside works , the unit is probably low in refrigerant , or the filter is clogh with dirt.
Sep 27, 2009 | AmcorAire UCHW-H12AF2 Split System Air...
Amcor AMC12000 Portable Air Conditioner Logo
51 people viewed this question
Top Amcor Heating & Cooling Experts
AJMAL KHAN
Michael Youngman
Michael Youngman
Are you an Amcor Heating and Cooling Expert? Answer questions, earn points and help others
