Question about Maytag MSD2732GR Side by Side Refrigerator
Ice maker not working
Maytag side by side ref/freezer mod#MSD2732GR, the ece maker is NOT making ice cubes, limit switch is in the down/on position. the water supply is on. the ice and water dispenser is working properly, it just stopped making ice.
    President:
  • 1,070 Answers
Welcome to FixYa
Defraust Freezer-You can also Use Hair Dryer to Melt Ice....
Clean Freezer Using Detergent or Hot Water mixed with Soap...
Unplug it for few hours...and Try agin...
Unplug the ice maker if the raker bar still won't move. It's possible there are some ice cubes lodged in the internal parts of the ice maker that are keeping the fingers from raking ice all the way through to the collection bucket. Melting the ice by turning the ice maker off, or unplugging it, will remove the blockage. This technique can also solve a jam caused by ice blockage in the area where ice is dispensed.
There are four main reasons why the ice maker may not be producing ice: 1. Check to see if the stop arm is in the OFF (up) position. 2. Check to see if the water supply is turned off. 3. The water pressure may be too low. 4. The freezer temperature setting may be too warm.
Why isn't the ice dispenser on my side-by-side refrigerator working?
Start by checking the dispenser to see if there's an ice jam. If there is, break up the ice so it can dispense freely.
Next, make sure the icemaker stop arm is down (the ON position). Then check the lock switch, which prevents the dispenser from working, to be sure it's turned OFF.
If your dispenser still won't dispense, please call an authorized Maytag service Center.
Unplug it for few hours...and Try agin... hope you got an Idea...Thanks for Contacting FixYa
Posted on Jul 12, 2010
Msd2454gr grinds when dispensing ice
if it grinds the ice when set on cubes ice output,remove the ice holder from the freezer and check for a chunk of melted ice blocking the hole to let cubed ice come past the chopper blades,run hot water thru this container till all blockage is melted then dry it out throughly put it in freezer and let it get freezing cold before letting new ice fall into it so you dont have a repeat of the same problem
Aug 12, 2012 | Maytag MSD2732GR Side by Side Refrigerator
Our ice maker is not working. It fills up with water, but the "teeth" dont completely turn causing the ice to pop out. It's like they get stuck in the final step. I recently put in a new...
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking same part needs replaced.The water valve at the bottom rear of fridge
First I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Jul 31, 2011 | Maytag MSD2732GR Side by Side Refrigerator
Our kitchen and pantry were flooded because the icemaker wouldn't shut off. My husband had to unplug the refrigerator to stop the water from pouring out
That is a rare happening but the solution is inside the ice maker itself. Click Here=>MSD2732GR Ice Maker Parts Break Down Part 13 is the Click Here=> 627985 Ice Maker Thermostat and sometimes it is just less expensive to replace the complete Ice Maker=> Ice Maker
Assembly
Simply unplug the ice maker from inside the freezer section rear wall until you can replace the part or ice maker. If you have more questions feel free to ask here or my through my web sites. Thanks, Sea Breezesea_breeze_15.jpg
Appliance 911
Dec 08, 2010 | Maytag MSD2732GR Side by Side Refrigerator
The Ice maker has stopped working.
There are usually 2 small solenoid valves that are used to control water. Both are generally installed at the rear close to the bottom of the fridge. One of the solenoids controls the water flow for drinks and the other is to control water flow to the ice maker. You can determine which is which by tracing the water supply tubes from the freezer compartment to the solenoid or by process of elimination. The latter method requires that you feel for movement (clicking) or heat on the water dispenser solenoid while someone starts to fill a glass with water from the fridge.
Before going any further, make sure that the ice cube detection arm in the freezer is not up. Gently push the arm down if it is. When ice cubes are ready, the ice maker turns on a small heater to break the bond of the ice cubes to the cube mold. The arm is lifted up and out of the way. Then the mechanical fingers wipe or push on the cubes to dislodge them from the ice cube mold and they fall into the container. The arm is then lowered again and rests on top of the ice collected in the container. The position of the arm when resting on the ice cubes determines whether or not any more ice cubes are made.
If the arm is hanging down, then ice cube production should be on. The problem may be either a faulty solenoid valve (mentioned above), switch in the ice maker assembly - the detection arm in particular or wiring between.
Jun 18, 2010 | Maytag MFI2568AE Side by Side French Door...
Maytag ice maker makes ice cubes but when its time to eject, either a cube gets stuck in between the rake or it gets frozen up and you hear the gears trying turn. You will see a frozen mess or cubes and...
I would first try turning the temperature down on your freezer before considering buying any parts. Your ice is freezing before it is reaching the position to dump in the bin. Also, if you have any items packed around the area where you ice maker is, try to free up a little space around it. If that does not work I would call the manufacturer, they will be more than happy to walk you through any problems you may be having with there products.
Aug 04, 2009 | Maytag Freezers
Ice maker sprays water...
sounds like the inlet part on the ice maker is froze over or not lined up in the opening of it right or a possibilty that the ice maker is leaking out the water if that is the case the ice maker needs replaced
Jun 07, 2009 | Maytag MSD2732GR Side by Side Refrigerator
Not dispensing ice cubes, only crushed
Yup, do like I did. Clean the caddie of all ice cubes. Place a large water catching tray under the door, and run hot water from the inside where the the caddie holds the ice. You will see large chunks of ice that was freezing up your cube maker. After a couple of glasses of hot water pouring through the caddie, it will defrost and the frozen part will be released. Take off the caddie, and run water through it from your sink. Clearing all ice debris. Replace the caddie. Do not use for 24 hours, and it should run beautifully. Mine did that before it froze up and I cleaned it. You should probably take the caddie off every couple of months and run water through it to keep it clean of frozen debris, make sure its dried off well and put it back, wait overnight. and it should be ok.
This is what I did, hope it helps.
May 30, 2009 | Maytag MSD2732GR Side by Side Refrigerator
Ice maker only makes crushed ice, no cubes I have the same problem... The same switch works fine for the crushed ice and water setting but will not dispense cubed ice. It only gives crushed.
hi.
I slid out the tray, found the lever in the back where the rod went in, pulled it down, reinserted the ice tray, and IT WORKED! At first I thought I broke the lever, because I had to hold it down with a knife while I was inserting the tray, but it just must have been stuck.
chek these sites
http://forum.appliancepartspros.com/refrigerator-freezer-repair/23620-ice-maker-only-makes-crushed-ice-no-cubes.html
There is an opening next to the auger that dispenses the ice. In there there is a lever that must move up and down. It actually seats the metal rod on the bottom of the ice maker and controls cube or crushed. Make sure the lever is down (cube position) when you return the basket to the freezer. I had to hold it down while I slid the rod into the opening. Cubes again. http://www.applianceblog.com/mainforums/showthread.php?t=783
if satisfied plz rate this answer
all the best
regards
May 27, 2009 | GE GSS20IEPWW / GSS20IEPCC Side by Side...
GE Ice Maker that leaks water down the freezer wall
Ice makers have limit switches, thermal temp sensors, heating element and if anything gits out of order with these parts they will begin to do strange things like that. Now if you would like to remove it and have a look at the internal parts you may find the problem. They are a little easy to loose parts so be careful if that's your choice. A series of about six different cycles happen when they fill until the time it empties and begins again. They may cost less if you don't see what wrong to purchase a new ice maker. If you would like more help feel free to ask, Thanks, Sea Breeze
Apr 20, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
make sure the wire rod on the ice maker is in the down position in order for it to make and release the ice
Dec 13, 2008 | Maytag MFD2560HES Bottom Freezer French...
Maytag MSD2732GR Side by Side Refrigerator Logo
264 people viewed this question
Top Maytag Refrigerators Experts
Marvin
Marvin
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
