Question about Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer
Having trouble getting old blade off my ryobi brush clearing attachment. Whats the trick?
    Sniper:
  • 56 Answers
Is definitely a left hand thread on the bolt...your machine came with a small rod to hold the head while loosening or tightening the nut which holds the blade....there is a hole and a slot in the machines head to insert the rod....if you've lost it you can probably use a small piece of drill rod about 5/16 diameter or a drill bit to hold it ...turn nut in clockwise direction and it will probably come loose....good luck !!! ;-D
Posted on Jul 16, 2010
  • 120 Answers
Most lekely has left hand threads and nomaly is a small hole near the head to insert a pin into to hold it from turning...hope this helps
Posted on Jul 12, 2010
Whats the diffence between a star whole and a round hole on a lawn mower blade
It may be the way the blade was made to attach to the spindle. You will have to clean away debris with a wire brush when you remove the blade to see for sure.
May 01, 2017 | Garden
I purchased an 8 inch heavy-duty brushcutter blade for my Ryobi 30 cc four cycle powerhead how do I attach it to the string trimmer head
You can't use the blade on most string trimmers unless you have a brush cutter style then you would unscrew the trimmer string head and attach the blade with the adapter that came with the unit.
Oct 23, 2014 | Garden
I THINK IVE BURNT THE BRUSHES OUT ON MY RYOBI ETS 1825,FOLDING TABLE SAW, SERIAL NO 06011539 HOW CAN I CHANGE THEM. OR FIND OUT WHATS WRONG, THE MOTOR STARTED TO SMOKE ? REGARDS NJ
You can change the brushes easy enough but I don't think that is the problem. The brushes are a standard size, can be bought at any hardware store. Just pull the caps off and remove the brush, slide in the new one, all set. But,,, I have a feeling the motor went kapooie, The brushes usually don't smoke, but a burned out field or armature will. Check the motor to make sure it spins free with the belt off, or the blade off if it is direct drive, then do the brush change, if that doesn't do it, you will have to take out the armature and have it checked for ground, and then check for loose wires, burned rotor, and if that checks out then the field is shot. One of the 3. But it could be a bearing. Hope this helps.
Jul 24, 2010 | Saws
14'' Sears craftsman bandsaw blade slips off, not much power
It sounds to me like the blade has stretched which the do in changing temperatures.
Try replacing the blade before you give up altogether. i was having the same problem with a Ryobi Blade would come off whenever i tried to cut a pice of 3 ply. I eventually replaced the blade and all ny troubles evaporated.
Aug 29, 2009 | Saws
How to change blades on an old Ryobi 380mm cut off mitre saw?
most of these saws have a push/lock tab on back side of motor housing that pins the shaft for blade change. if you cant find, use a 4/4 wood block to wedge old blade so you can loosen bolt.. hope this helps....chris
Jun 18, 2009 | Saws
Ryobi 775r edger blade does not turn. Motor runs
Have you made sure the drive shaft cable is tuning and is properly installed and that there is no debris or dirt stopping the blade from turning?
Jun 13, 2009 | Ryobi Garden
Have a ryobi rlt 30 cd and the spool wont spin fast enough
hgffggkgjgjgbTry taping the bottom on a hard surface;HARD!;;;;;;;bjjjjjjkjjjjm4454541joojojojlj That did the trick for me for some reason it doesn't grab and it gets lose were it won't spin fast bearly cutting a blade of grass.
Apr 21, 2009 | Ryobi 15" Electric Factory Reconditioned...
My skilsaw5150 still won't run.
OK I went to a Bosch website to find a breakdown and it could be a couple things. First unplug tool and do you have a volt ohms meter or continuity tester. If so start by checking cord from the plug to the switch and then depress switch and go to brush holders. You might have to remove brushes so it doesn't read across both of them How bad were the brushes you removed, were they burnt looking and if so try and look at the commutator to see any noticable discolored com bars. When you installed the new brushes it is also a possibility that they were sticking in the brush tubes and make sure that the holder pushes into the field connections properly. Let me know if you are still having trouble
Mar 31, 2009 | Blade 24- Irwin 7-1/4" X 24t Classic...
How to for Belt replacement and solution to suction loss
You say it lost its suction, then you also say this is plenty of suction power, seems you cant figure out the prob. Try cleaning the fan on the suction blower. The blades can get chocked with dust which will give you a reduced suction.
Jan 05, 2008 | Vacuums
Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer Logo
145 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
