Question about RIM BlackBerry Pearl 8100
Having a problem getting the field coil assy. out of the main housing.Oster clipper model "A5" Is there a trick to that ? Thanks ...Bob
    Problem Solver:
This is a hair clipper not a phone. Thanks anyway...Bob
Posted on Apr 21, 2008
Oster A5 clippers work briefly then "pull" hair
Lever arm worn, blade blunt, or loss of movement inside the gearbox. It is possible to have a 'bad' sharpen.
Aug 03, 2012 | Oster Golden A5 Single-Speed Clippers
I have oster 6550 series a clippers, i installed new blades but they hardly clip any hair, when I loosen the tension the blades "move quicker" but vibrate with a loud noise
the tension should be pre set from the factory, if its more than one blade your having problems with then its likely there is a problem with the clippers.
Mar 04, 2011 | Oster Golden A5 2-Speed Universal Motor...
I am having trouble getting the replacement blade back on my Oster A-5. I doesn't seem to want to "click" into place? Any hints?
the clipper must be running when you try to fit a blade, if its all pf your blades your having trouble with then the problem is with your clippers, its possible the black latch which you need to depress to release a blade is bocken, loock at the end and make sure there is a hook which catches the blade, look at the picture.
Nov 13, 2010 | Oster Golden A5 2-Speed Universal Motor...
I have an Oster A5 2-speed. I took it in to have the cord and some parts replaced one was the housing. Now the housing gets so hot I can hardly hold it. The blades do not get hot. Help.
It is just part of how Oster clippers are. You can try to alternate blades, and spray them with Kool Lube, but they just get warm.
In the event that you would like to sell them or be rid of them, I use their parts to try and fix low income housing clippers.
Jul 01, 2010 | Oster Golden A5 2-Speed Universal Motor...
I have an Oster A5 2-speed. I took it in to have the cord and some parts replaced, one was the housing. Now the housing gets so hot I can hardly hold it. The blades do not get hot. Help.
tricky i should return the clipper to the repair centre with a desciption of the fault, there shouldnt be anything related to the housing problem.
Jun 11, 2010 | Oster Golden A5 2-Speed Universal Motor...
I have a older oster clipper model22 works fine
you should be able to get whatever parts needed and support at clipperparts.com
Jan 30, 2010 | Oster Golden A5 2-Speed Universal Motor...
Run but will not cut
Are you sure you have Andis A5 or did you mean Oster A5 Clipper, if this clipper is A5 Clipper, You need to check the Lever for wear, The front of the Lever show wear on both side, Like white color and is not squad this Lever is worn. Need to replace. This Lever moves the blade side to side fully. if the Lever is worn the blade will not move fully side to side and the cutter blade the smaller blade will stay in the middle with hardly no travel to side to side and will not cut the hair even if you purchase new blades. Also I would like to mention if the Oster Locking Hinge is worn out and don't have the require tension to hold the blade in place the blade will not cut. How do you test the Oster Hinge on a Oster A5 Clipper,
(1) first close the hinge, in close potion with your finger nail try to open the Hinge, if the hinge slightly open or opens loose the Hinge is worn. if the Hinge is good it will not open or move and your nail may just brake your nail.
Many of my customers run into this type of problem, and the problem can be solve easily by checking these parts first.
One more item I would mention here if replace the A5 Hinge make sure you get the A5 Hinge not the Oster 76 Hinge they are driferrent, The A5 Hinge has on the back two wire's sticking out that fit on the Oster Latch for the A5 Hinge, the Oster 76 Hinge would not have these wire's on the back. I recommend replacing the Latch when you replace the Hinge. I hope this helps any body that have a A5 Oster clipper or A Oster 76 Clipper.
I have over 20 years in the repair business of Sharpening & Clipper repair. Mannys Sharpening 323 263-4697
b61c252.jpgOster Hinge
Jun 10, 2009 | Andis Outliner II Hair Trimmer
Oster clipper blades get red hot and won't cut.
see this link, its for the A5. The A5 is the animal version of the 76.
http://www.peasridge.co.uk/clipper-advice/clippers-products-oster-a5.shtml
I dont know what model you have, but if you need schematics for YOUR model see this link.
http://www.clipperrepair.com/parts.htm?brand=8
Jan 10, 2009 | Oster 76076-010 Hair Trimmer
Oster 76 clippers
Here is schematic and instructions for service and repair. The model in the picture is the A5 however it is the animal version of the classic 76.
Oct 10, 2008 | Oster 76076-010 Hair Trimmer
RIM BlackBerry  Pearl  8100 Logo
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
David
Martin Murray
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
