Question about Remington 16" Electric Chain Saw Assembled 3.0 Peak
How do I get a tension screw for my 16" electric oil chain saw?
How do I get another tension screw?
    Champion:
  • 221 Answers
You can go to the following link, enter your model and order direct. Another option is to take the saw to an ACE hardware store. They have almost every imaginable bolt and screw possible and will most likley have one that will work.
http://tinyurl.com/2ecg5ls
Posted on Jul 12, 2010
My chain came off and i can't get the bar back to put the chain back on, help
Hello mingster. Just inside of bar is a screw for adjusting the tension of the chain. The screw hole maybe full of dust & oil. Rotate the screw while holding the chain next to the tip of the bar to determine clockwise or counterclockwise. When adjusting the chain tension don't over tighten.
Sep 01, 2013 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
I have an Remington 3.25 (Peak Hp) 16"/40, 6 cm electric chain saw, And I have just a few questions 1.) Does it take oil/gas or just oil and if so what kind. 2.) How would I tighten the chain, its...
It uses oil only to lubricate the chain. The type of oil in not critical although special chain saw oil is available. If you use anything but chain saw blade oil, make sure that it is a light oil, both in viscosity and in colour because it is a total loss system and dark or dirty oil can become very messy. The chain adjustment is on the body at the end of the blade, it actually moves the blade in or out to set the chain tension. The chain should be tensioned that when it is pulled at the bottom, the guides of the chain should not quite come out of the slot in the blade. If the chain is too tight it overheats the blade and stretches the chain.
Jan 21, 2011 | Remington 16" Electric Chain Saw Assembled...
I JUST BROUGHT A REMINGTON 3.5 ELECTRIC CHAIN SAW USED. I NEED THE PROPPER WAY TO USE IT, OIL IT, AND FIX THE CHAIN WHEN IT LOOSENS.
Don't operate the saw upside down, but it can be run to either side as well as upright. Use regular bar/chain oil for lubrication available from home centers, hardware stores, and saw dealers. To adjust the chain, loosen the side cover nuts (screws) somewhat, and adjust the chain tension screw CW until the chain pulls up to the lower bar edge, yet allows the chain to be pulled by hand. Tighten the mounting and check it often as you use it to prevent the machine from throwing the chain off. Parts for these machines are difficult to find as the company has gone out of business. Make sure to keep the chain sharp and properly filed especially if you are cutting dirty brush and limbs. Hope this helps!
Jun 20, 2010 | Remington 16" Electric Chain Saw
16" Electric Chain Saw: what kind of oil is used for electric chain saw...
I assume you are asking about the oil for the chain. Any good quality "Bar and Chain Oil" will do fine. Do not use motor oil you use in your car engine as it will not properly lube the chain and will result in quicker dulling and early demise of the chain.
You can get the "Bar and Chain Oil" at most hardware stores or Farm Supply stores.
May 17, 2010 | Remington 16" Electric Chain Saw
How do you reassemble the belt tightening screw?
it tensions against the chain bar
Should not have had to remove it to change the chain
There will be a hole in the bar for it to fit in to
Mar 31, 2010 | Remington 16" Electric Chain Saw
Need service manual for Homelite 16'' electric chain saw model UT 41320. Motor runs but chain stopped in middle of second cut.
chain is too tight on the bar or is lacking lubrication oil. loosen up the bar nuts and back off the chain tensioning screw a touch. make sure the bar oil reservoir is full and the chain is receiving oil when its running.
Oct 20, 2009 | Homelite Garden
The chain popped off and I can't get it to fit back on.
Losen the bar mounting nut, then losen the chain tension adjustment screw until the chain can be reinstalled, then tighten the tension screw until the chain just sags 1/8" or so at the center of the bar then retighten the bar mounting nut.
Sep 10, 2009 | Remington 16" Electric Chain Saw
How do you adjust chain tension? I have the 16" Remington electric chain saw, and the chain will not stay tight; it slips off the rear sprocket as soon as I try to use it. I don't feel everything is...
Here is a link to instructions for EL-8 series saws ... http://www.desatech.com/pdf/115499-01_EL8_Series_Chain_Saw_Tension_Adjustment.pdf. For series LNT-2, LNT-3,EL-1, and EL-7 according to the manufacturer... "WARNING: The cutting edges on the chain are sharp. Protective gloves should be used when touching the chain. Unplug the chain saw from the power supply. Allow chain to cool. Loosen the guide bar nuts until they are finger tight. Ensure the adjusting block is in the adjustment hole in the guide bar. Turn the chain tensioning screw clockwise to increase tension. Turn the chain tensioning screw counterclockwise to decrease tension. Check for proper chain adjustment by pulling down on the chain at the bottom center of the guide bar. You should see no more than a ⅛ inch gap between the chain cutting links and the guide bar. The guide (or drive) links should not come out of the guide bar grooves. The chain should rotate freely around the guide bar. If it does not, chain tension should be decreased. When the chain is properly adjusted, tighten the guide bar nuts securely." On the M series if your chain keeps slipping off your sprocket... The Sprocket cover tab (located on the round part of the sprocket cover) isn’t inserted into the saw body tab slot. I hope this helps you!
Jul 01, 2009 | Remington 16" Electric Chain Saw
POULAN CHAIN SAW MODEL 1420 ''Chain came off track
Chain is probably stretched. SAFETY FIRST. Electric saw, make sure power is unplugged. Gas saw, make sure sparkplug wire is removed. Remove the cover where the bar is attached to the saw. U should see an adjustment screw for chain tension and one or more bar lockdown screws. Loosen the lockdown screws and turn the tension adjustment screw to permit the bar to slide back toward the motor. Put the chain back in the bar track all the way around. Adjust the tension screw to tighten chain enough you can't pull it out of the track at any spot. Slide the chain by hand at least one complete revolution feeling for any rough spots. If it moves freely, turn the tension screw enough to tighten the chain properly. Correct tension should allow you to pull the chain appx. 1/16 to 1/8 inch from the bar. Tighten the lockdown screws, replace the cover. Rotate chain by hand a couple of revolutions again to check for smoothness again before starting the saw.
Jun 26, 2009 | Poulan 952801953 Electric Chain Saw
Remington 16" Electric Chain Saw Assembled 3.0 Peak Logo
132 people viewed this question
Top Remington Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Remington Garden Expert? Answer questions, earn points and help others
