Question about Panasonic TC-21S80RQ TV
My tc-21p3 does not start, i check the b+ its too low.
Procom heater will not stayon
check the milivolt reading with a tester or replace the powerpile/pilot assembly
Sep 30, 2016 | Procom Heating & Cooling
Wall heater will not stay on.
Clean out pilot sounds like it is too small to heat tc
06 scion tc ac compressor not working
check the freeon level. it is probably to low. buy a a/c kit refill and youll be chillin
Mar 11, 2013 | 2005 Scion tC
I'm getting really low mpg on my Scion tC 2006
clogged air filter, proper air in tires, wrong octain for car? who knows, it could be all of this
Feb 19, 2013 | 2006 Scion tC
Heater only blows cold air 2006 scion tc
only cold air? check antifreeze level add if low.. also check vacuum controls for operation..god luck..
Jan 25, 2013 | 2006 Scion tC
Resetting an air conditioning system in a scion tc 05
Hello.... First the bad news... Air Conditioning systems do not have a reset. Now the good news... The system could have shutdown due to low fluid... There is a pressure sensing switch in the line that respond to the "Low Fluid" condition.The reason it does that is so that the compressor does not get damaged and cause all sorts of other problems...
The fix... If it has shutdown due to low fluid the system needs to be serviced and it will start working as good as new... Take it to a repair shop with the proper equipment..
Hope this helps.....
Mar 26, 2010 | 2007 Scion tC Coupe
Sir when i start my phone nokia3110 its blink 3 time then off
1. This 'Blinking Screen' problem is due to the low battery in your mobile!
2. Charge your mobile for atleast 6-7 hours as needed.
3. Now, turn on and check it!
please rate this advice if it helps....tc! :)
Jan 19, 2010 | Nokia 3110 Cellular Phone
E brake light on 2005 scion tc will not go off
The same light will come on when your brake fluid level is low in your master cylinder. If its low, just add brake fluid. Then check you front brake pads. The may need replacing soon. (thats why the fluid is low)
Jan 12, 2009 | 2005 Scion tC
Televison & Video Logo
32 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
