Question about Microwave Ovens
Oven door does not unlock - Microwave Ovens
  • jf0934 Jul 12, 2010
    6f38 speed accubake range oven door does not open when button is pushed (super capacity 465)
  • Microwave Ovens Master
  • 11,800 Answers
The door lock is commanded by a small electromagnet - if there's a fault in it it simply locks the door as a safety measure, if it's a fault in it there might be other faults elsewhere.
To open the door you must dismantle the oven: unplug it from the wall and wait for al least 4 hours, unscrew the bolts from the bottom and the rear that hold the top and side panel attached to the case, from the rear tilt and lift the panel to free it and remove it - now the locking system is directly accessible; using a small sharp object press on the blocking pin and open the door. With the door open test the electromagnet for faults or try to find out why it failed to function - wire interrupted, bad connection, the programmer might be faulty.
Posted on Jul 12, 2010
    President:
  • 1,099 Answers
In most cases this is due to a broken door opening lever or loose or broken door latch / hook parts.
They can only be accessed and examined if the cover is removed from the microwave.
In many over the range models, you can access the door parts by removing the control panel assembly.
Sometimes you may be able to get it open by pushing up gently on the bottom of the door while pushing the button, in case you need to empty it.
ALSO NOTE THAT....
Take a look at the button you push to open the door.
You will need to remove the panel the door button is on and get to the back side.
This is very easy to do after you remove the cabinet.
The button you push to open the door is held in place with four tabs. If one of them tabs break it jams the button.
Hope this helpout ,Good luck...
The oven door won't open. It happened when it wasn't being used. How do I get the door to open?
If it is a self cleaning oven try running it thru the clean cycle to see if the door will unlock at the end of the cycle.
Apr 24, 2017 | In Microwave Ovens
Convection wont work
We could probably help you if you would repost this with the full model number from the tag in the cooking cavity or elsewhere on the oven.
Excellent job on detailing the symptoms though!
Just be sure to include them in your repost, too.
Jun 05, 2013 | KitchenAid Microwave Ovens
How do I unlock the key panel
Opening the door while the oven is cooking will greatly shorten the life of the door switches and lead to failure.
Always hit "Stop" first unless the recipe calls for it.
The instructions for the child lock are in the owner's manual.
To set the lock, press Stop/Clear, then hold the "0" pad for more than four seconds. You will hear two beeps and the display will show "LOCKED".
To unlock, hold the "0" pad for more than four seconds. You will hear two beeps and the display will no longer show "LOCKED".
May 18, 2013 | LG LMVM1935 Convection/Microwave Oven
Oven wont work unlock door meesage keeps flashing door unlocked
The model number would have helped us give you specific advice, but without it we'll give you generic advice and say it may be a door switch issue.
See our help file on door switches here.
Jan 16, 2013 | GE Microwave Ovens
I ordered and received a replacement door for my 2002 spacemaker ge microwave. The lady I spoke with said I would be able to install it myself. I figured there would be directions in the box explaining...
HELLO.
Below is the solution to replace your microwave door.
Unplug the oven from the outlet and/or shut off the gas valve. Open the old door completely and unlock the hinges by pushing the hinge out toward you and down toward the door. Slightly close the door and lift the door up and toward you.
Install the new door. Make sure the wall oven door hinges are aligned to go into the rectangular wall oven slots. Place the hinges into the slots. The hinges should "catch" on the slots comfortably.
Ensure the door is fully opened and push the hinge locks into an upright position. The two hinge locks should rest on top of the two hinges that are inserted in the wall oven slots.
Close the door and open it several times to make sure the door is properly opening and closing. Replug the oven back into the outlet and/or turn the gas valve back on.
Thanks.
Sep 25, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Frigidaire wall oven (door opens with hinges on left) won't unlock after cleaning. Turned current off and back on with no results.
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Dec 24, 2010 | Microwave Ovens
My microwave is locked and i dont know how to unlock it
"Locke" meaning the door? or locked meaning the buttons don't work? If it is the buttons then you have the child lock on. Push and hold the "Start" button for 4 to 5 seconds, and it will unlock.
Mar 12, 2009 | LG LMV2083SW Microwave Oven
How to unlock the microwave
hi,
if there is a key on the pad that says "child lock" press and hold that for 30 seconds or so until it unlocks, if there is no key that says "child lock" try doing that to the "end/stop" key or the "start" key
Mar 30, 2008 | Emerson MW8168B Microwave Oven
Microwave Ovens Logo
23 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
