Question about Cycling
Tyre leaks air how to fix it - Cycling
  • rsood Jul 20, 2010
    it looks like a slow leak from the valve of a bike tyre
  • 503 Answers
The position of the valve will not have any bearing on the speed of the leak - the pressure inside the tire will dictate that. Check the valve core - the inner workings of the stem. Make certain that is is tightly screwed in (clockwise). Also if you can remove the tire, check for a nail or a puncture hole - a cup of soapy water (dish soap) is all you need - mix it thick. Pour it on the suspect area and look for bubbles - they will be small based on the amount of air you are losing each week. Also check around the perimiter of the rim (the bead). Allloy wheels are notorious for leaking around the bead - particularly if it has been bent.
Please post your feedback and Vote if the problem resolved as per your satisfaction.
Posted on Jul 20, 2010
  • rsood Jul 21, 2010
    how do i Check the valve core
  • Monika Arora
    Monika Arora Jul 21, 2010
    Please check it clockwise that it is closed tight or not.......
    President:
  • 1,099 Answers
you can get this by yourself, just follows the following steps...
Finding a tire leak can help stop a gradual reduction of air pressure in your tires from a slow leak, that could leave you stranded with an unexpected flat tire. Follow these suggestions to find minor tire leaks that could cause major problems.
Tools and Materials:
  • Tire pressure gauge
  • Large magnifying glass
  • Bright yellow or white china marker
  • Powered air compressor
  • Spray bottle with dish detergent or other cleaner
  • Handheld vise grips
  • Tire reamer
  • Tread plugs and plug inserter
Step 1: Check the Air Pressure of Your Tires
You may have a tire with a slow leak without realizing it. Use a reliable tire inflation pressure gauge to check the air pressure of all 4 tires regularly. If you notice that one is always lower than the others, you may have a slow leak.
  • Sanyade Akinwale
    Sanyade Akinwale Jul 20, 2010
    THIS IS THE CONTINUATION OF THE SOLUTION
    Remove the low-pressure or flat tire from your car and replace it temporarily with your vehicle's spare tire.
    Step 2: Inspect the Tire
    Examine the entire tread, sidewalls and bead of the tire. Look through the magnifying glass for any cuts, cracks, splits or objects embedded in the tread that have caused punctures. Circle any likely trouble spots with a bright yellow or white china marker, a kind of oil marker that adheres well to rubber.
    Step 3: Re-inflate the Tire
    Use your air compressor, or go to a service station with an air pump, and fill the tire to just over 30 psi. Confirm the pressure with your tire pressure gauge. It should hold for the few minutes the leak test will take. Listen for the high-pitched hiss of air leaving the tire at any of the trouble spots you marked. If you can narrow down which it is, mark an arrow at that spot.
    Step 4: Spray on the Bubbles
    Use any kind of spray cleaner, window cleaner or make your own from a few drops of dish detergent mixed with water in a spray bottle. Spray around the tire tread 1/6 of the circumference at a time. When you see bubbles come up out of the tire anywhere, you have found your leak. Circle the locations - there may be more than one - with your china marker.
    Step 5: Plug the Tire and Take It In for Service
    If the problem is a tiny hole, smaller than 1/4 inch across, you can do a temporary repair with a tire plug. Remove the object that created the puncture with the vise grips, create a smooth, uniform hole with the tire reamer and insert the tire plug. Redraw a circle around it with the china marker. If the tire's tread and sidewalls are in good condition, take the tire to a tire service center for an interior patch. If the tire's tread indicators are showing, or if the sidewalls are damaged along with the tread puncture, discard it and buy a good-quality replacement tire, either new or pre-owned. Have the tire center install the new tire, put it on in place of your spare, and drive home.
    Check your tire pressure monthly during the year, and weekly in spring and fall, to catch slow leaks.
    Good luck and hope this helpout...
Can i use the fix-a-flat with more than one car
what ever is a 'fixd" to start with
Sep 25, 2017 | Cars & Trucks
How to Patch a Bicycle Tube?
buy a new tube.
Pull out tube
Pump air in to it
put under water
notice were are leaks from
using a bicycle patch kit
sand tyre around hole
glue patch over hole
wait for glue to set
check no nails, glass embedded in tyre first before you
put tube back inside tyre
put tyre back on wheel
https://www.youtube.com/watch?v=x5x7GIc0e6g
https://www.youtube.com/watch?v=WG7Y1eSDsNA
Oct 20, 2016 | Cycling
In 4 months we have pumped the tyres up every 2 weeks after losing 10 psi. Tyres and wheels are good cond. Are the sensors to blame
Are these the original tires? I had the same problem with a BMW years ago with my first set of replacement tires. Turned out the wheels were porous, and the air was leaking through the wheels. We needed to put tubes in the tires. If all 4 are going down at the same rate, that may be it.
Oct 06, 2015 | 2007 BMW X3 2.0D
Spar keeps losing air can't find any leaks
Enjoy some videos about leak and slow leak detectin in a tyre. If you don't have the equipment to do it or find it too hard, take it to some competent repair service. If is is losing air, they MUST find it.
How to Find Leak in Your Tire
how to dianose slow leak in car tire
Fixing slow tire leak
How to find leak in tire
Aug 14, 2015 | Cars & Trucks
Tires, read details please.
The legal answer here is to replace the tyres as decaying rubber is the first cause of blow out and accident
Putting tubes in tubeless tyres is creating a problem and causes overheating of the tyre case and tube as air is caught between the case and the tube and this causes friction as the tyre rotates on the road
Using an air leak preventative here is a waste of money because as you have stated there is no air leak
Mar 06, 2015 | Cars & Trucks
After I pumped my tire the air escapes is there a cover for the valve after I am done pumping or not ?
You may have a puncture you would find and fix this the same as a bike tyre. Pump it up take out the inner tube find where the air is leaking from (sometimes submerging in water helps as you can see air bubbles coming from hole) then fix with a puncture repair kit
Sep 28, 2014 | Bugaboo Frog Baby Gear
My 22" rim has a tiny hole in it. It keeps leaking air. HELP?
Rims are normally all one piece and any air leakage is around the valve stem at the rim. Qualified tyre shops always make it a habit of replacing this stem each time a tyre is removed or replaced as they tend to rot in the rim and leak. If it is a manufacturing fault seek a replacement under warranty as it prove not fit for the purpose.
Dec 14, 2013 | Cars & Trucks
The rear tyre of my fz16 fails to maintain air pressure due to the damage of the rear rim.in near future i would like to change the rim as well as the tyre.as to maintain a high mileage i would like to...
Don't change tyre sizes. This is a bike with 112mph top speed. The tyre was designed for that bike. Buy the tire size that fits it. In most cases rims can be repaired. Cracks can be filled and machined back to spec. If it is a tubeless tire, removing the tire from the rim, soaping it and refitting it will often stop the air leak.
Dec 20, 2017 | Cars & Trucks
Warning light on my car dashboard won't go off
The light doesn't go out after you top up the air pressure in the tyres.There is a reset button, that you should press, and that will reset the tyre pressure
Usually it is in between the front seats, about where the handbreak is.
Find the button, press it and hold it down for a couple of seconds, and that will make the warning light go off.
May 08, 2012 | Skoda Roomster Cars & Trucks
Ive just brought a new tyre for the front of my gsx600f and it needs inflating every 3/4 days. if its the valve how can i fix this also is it likely that this could have happened when the tyre was changed
yes it could have happend then, check and see if the tyre is on the rim properly,is the bead on the rim all the way round ?, check the valve for leaks with some water or some dish soap you will see bubbles where the leak is.
the valve core can be replaced easily with a valve core tool from an auto accs store, if the bead is not straight deflate the tyre and reseat the bead by turning the tyre on the rim
Jan 16, 2010 | 1991 Suzuki GSX 600 F (Katana)
Cycling Logo
22 people viewed this question
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
