Question about Philips 60P8341 60" Rear Projection Television
Philips 50p8342 my picture shows redish yellowish and the words on the screen shows double and the picture does not come in good
    President:
  • 2,712 Answers
Try this procedure:
Adjust the green & blue CRT screens to match the red. Go into your picture menu adjust, turn color all the way down to a black & white picture. Now adjust each CRT screen so that you end up with a true black & white picture. Then adjust each focus control to get a sharp picture, and adjust each CRT focus one at a time for clarity by covering the other two up. Then go back into picture adjust and turn color half way up, you should see a better picture.
If you cannot get the blue & green to even out to a black & white screen you have other problems such as faulty CRT card on back of tube or it could even be that the video IC is faulty. If this is the case, then you may have to get a competent local technician to check the TV and get the necessary parts replaced.
Hope that helps...Should you have any further questions, please feel free to post them here.
P.S. Before you assign a rating, please make sure that the issue is resolved or you are satisfied. If not, please post back as to what you did, and/or any other questions you may have, and I will try to assist you as best I can. Please do not assign an ‘Inappropriate’ or ‘Thanks for trying’ rating if your issue is not resolved after the first response itself, as sometimes a bit of to and fro dialogue may be necessary before we can find a fix or an answer to your query.
If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! or Helpful rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on Apr 25, 2008
  • Swilin Sampson
    Swilin Sampson May 03, 2008
    Just wanted to inquire if your issue is resolved, or if there is anything
    further I can do to assist you…
    to, or resulted in a fix, please take a moment to close the ticket with a FixYa!
    rating under my solution.
    post them here.
    Cheers!
    IrishDruid
  • Swilin Sampson
    Swilin Sampson May 31, 2008
    P.S. -You can rate this solution with one of
    four votes, if you feel your issue is resolved.
    • "FixYa!"
      - The solution provides great advice on how to solve the problem.
      (Positive Rating)
    • "Helpful"
      - The solution provides useful leads that helps solve the problem.
      (Positive Rating)
    • "Thanks
      for Trying
      " - The solution does not solve the problem but the
      effort is appreciated. (Negative Rating)
    • "Inappropriate"
      - The solution has absolutely nothing to do with the problem.
      (Negative
      Rating)
    If your issue is not still not resolved, do not
    assign a rating just yet. Please post back as to what steps you took, results,
    etc, and I will try to assist you further as best I can.
    IrishDruid
In the inside of the tv set there r 3 color nobes should be blue red and green they r located next to ur bulbs it sounds like to me that u need to adjust this to rest ur pic email me if this works evilmatrix86@hotmail.com
Posted on Jul 06, 2009
The problem with the colors is way better but my screen shows spots or lines example a red line in the middle and other spots on the sides, what can I do
Posted on May 31, 2009
Picture and color seem off. Words appear to be doubled abd blurry. We can't adjust the color because we cant read the words
If your TV looks 3D, warped, or distorted it likely has a convergenge problem.
If however it just looks dull, washed out, redish, greenish, or blueish or if it looks like objects on the screen have halos the fluid in the lens has soured.
You can search google for parts or you can get the parts with repair instructions from sites such as www.TvRepairKits.com
Mar 02, 2011 | Toshiba 50H71 50" Rear Projection...
My Philips tv model50PL9200D/37 has hot spots in the picture.It doesn't matter what picture setting or adjustment it is on.Dark scenes show purple in some places.Light scenes show bright spots especially...
Feb 28, 2011 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
On left half of the screen [ KP51WS510 ], a redish shadow showing
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV2_bing.gif may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 07, 2010 | Sony KP-51WS500 51" Rear Projection...
Red images with green projected to the right with a green halo on upper and lower left corners
This set needs a fluid change. Between the face of the picture tubes and projection lens there is a layer of coolant fluid. The fluid has turned a milky brown color and is degrading the picture. The tubes have to be removed in order to do this properly. I would suggest you contact a repair shop and have them check it out for you as this can be very complicated. Thanks for using fixya and I hope this helps you out.
Nov 04, 2009 | Philips 43P8341 43" Rear Projection...
I have a Panasonic HDTV Projection PT-47WX42 with double imaging.
Projection TV sets have two very common problems listed below.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Nov 17, 2008 | Panasonic PT-47WX42 47" Rear Projection...
Philips 50p8342 problem
I have tv proyection philips model 50p8342, it is blinking red color on the power switch botton four times and then pause then another four time continuosly.
Aug 15, 2008 | Philips 60P8341 60" Rear Projection...
60" Phillips HDTV Rear Projection
You need new convergence ICs two of them numbers STK392-110 they are available at the following link and they provide free installation instructions with pictures as well as free online tech support while you do the repair which takes about an hour. Heres the link.
http://servicemanuals.vstore.ca/
Apr 07, 2008 | Philips Magnavox 9P6034C 60" Rear...
No picture or sound
sounds like the PTV Small Signal Board.
Jul 22, 2007 | Philips 60P8341 60" Rear Projection...
The tvs picture shows doubles and tinting around the people
This sounds like your convergence circuit has failed. There are large convergence amp ic's that will need to be replace and this is not an easy repair and will most likely require a qualified service professional.
May 04, 2007 | Zenith R65W28 65 in. Rear Projection...
Philips 60P8341 60" Rear Projection Television Logo
224 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
