Question about Samsung SC-D353 Mini DV Digital Camcorder
LCD screen is clear with horizontal lines - Samsung SC-D353 Mini DV Digital Camcorder
  • 11,896 Answers
It is likely that either there is some cold solder joints, or a bad IC chip
Posted on Jul 12, 2010
Element 55' flat screen
Sounds like T'Con board fault. If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Jul 12, 2016 | Televison & Video
My 42 in phillips LCD flat seen has a black horizontal line toward the bottom how can I fix this.
Samsung LN46B650 Thin Black Horizontal Lines - Forums - CNET
www.cnet.com > Forums > Samsung
CNETI'm experiencing thin black lines from the top of the screen to the bottom. ... by babes808gpa / January 15, 2010 1:42 AM PST ... lines are about 1/4 inch apart from top to bottom of screen. starts on the right and about a 1/3 of the way toward the ...have the exact same problem, my lcd tv has multiple lines are horizontal it ...
Faulty HD- LCD - LED TV - Horizontal Lines STRIPS on the ...
? 3:05
https://www.youtube.com/watch?v=KiqJuMiEiak
Jun 8, 2013 - Uploaded by Sameh Moustafa
Faulty HD- LCD - LED TV - Horizontal Lines STRIPS on the picture SOLVED .... I just have one black line ...
TV Repair Help for Vertical & Horizontal Lines on Your TV ...
? 2:47
https://www.youtube.com/watch?v=b0sI7LB4cZE
Dec 20, 2015 | Televison & Video
Hey I got an IBM T42. It boots fine when its clear but after that it horizontal lines being to appear througout the scree.
Either you can hook up an external monitor or access BIOS setup (Basic Input/Output System) to replicate if the horizontal line appears. This step will check if the problem is with the video card or the LCD.
If you get the horizontal line on the BIOS or never get it on the external monitor, then surely the LCD screen is beginning to fail. You need to reinsert and/or replace the LCD inverter or LCD itself.
However, if you see the horizontal lines on the external monitor but not on the BIOS, try to update the video driver. If this will not resolve the issue, you need to replace the video card or the motherboard of your laptop.
Hope this helps.
Jun 06, 2011 | IBM ThinkPad T30 2366 Notebook
I have amonitor 32 inch when i turn it on i see meany horizontal lines this lines colored how can i solve this proplem pls?
Hello When you get horizontal line, especially colored, it typically means there is a problem internally: either with the LCD inverter (backlight), LCD Circuit board (interprets incoming signal) or the Display panel itself. Sometimes shaking it around can clear up the issue slightly but for the most part it's time to get a new screen. If you have pictures I can verify this is the issue. Any other questions, feel free to ask.
May 13, 2011 | Polaroid Computers & Internet
It has what looks like line in the back ground of screen
Horizontal or vertical? how big is the line? a lot of lcd tv companies had a problem with the tab bonding on the actual lcd screen that may be causing this - you can also check the ribbon cables on the tcon board to make sure htey are seated properly that may clear up the issue.
thanks,
michael
Mar 21, 2011 | LG 42LC2D 42 in. LCD HDTV
I have a Samsung MX20 Camcorder, when I turn the it on the LCD shows a distorted image with horizontal lines no clear image or anywhere near. Any help appreciated this was given over a year ago never used...
The horzontal lines would have to do with the screen unless you see those on the actual video footage on the memory stick.
Fact is I have this cam and know everything about it by experience the issues with these cameras one drop and there basically toast.
Now if there is not horizontal lines on the video itself and the video is clear the issue would be the LCD on the unit.
Let me know and update me with any new information.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Aug 31, 2010 | Samsung SC-MX20 Flash Media/AVC Camcorder
Acer lcd tv screen goes fluro green, only on some pixels not entire picture but rest of screen is not a very clear picture.
my acer lcd 32" tv just recently went of the blink. It has vertical, horizontal lines and fluro green screen. please need some advice...
Dec 30, 2009 | Acer AL1716WAB LCD Monitor
Less than 24 months old. Power up, has 3
sorry to say but your LCD panel is failing, and will have to be replaced sonys panels are expensive
Dec 05, 2009 | Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
Aspire 5600 gets horizontal lines on lcd
The horizontal line means that there is a loss connection in the horizontal projection of the monitor. This can be resolved by fixing the horizontal panel board that gives error. this require quite expert in the LCD troubleshooting. However, if you believe that you can do it, ok you may proceed.
please donot rate me if this not solve the problem. because i need more higher rating. just notify if you need more solution am here to assist. melnavz
Apr 09, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
Samsung SC-D353 Mini DV Digital Camcorder Logo
82 people viewed this question
Top Samsung Video Cameras Experts
302lab
Level 1 Expert
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
