Question about Brother MFC-7440N Laser Printer
Clean the corona wire - Brother MFC-7440N Laser Printer
    Problem Solver:
  • 12 Answers
You need to pull out the drum unit and flip it upside down. On your right there will be a small green rectangle that with an arrow that points to another arrow on the drum. Slide the green rectangle all the way to the left and back so it is still pointing at the black rectangle. That is all there is to it.
Posted on Aug 26, 2010
  • lq0901gm Oct 27, 2010
    I have already done this and the error message is still there.
  • ECGREG Oct 27, 2010
    I looked up this error and got the following information from another site. I have not done this with my Brother Printer, but it may work for you.
    "Well I'll give some more advice since I work on these alot. Yeah that blue tab doesnt really do the job. Ive always used a damp Q-tip to clean of the coronas just be carefull not to break it, the corona, and that its not damp enough to drip on the drum and use the dry end to wipe the corona back off and clean off the charge grid underneath once again just be careful not to press to hard becuase of the drum underneath. There is an actaul service note on a few of these machines to check the contacts in side the printer on the right side of where the drum and toner sit. you should see three metal springs sticking out the side and they should all look the same in shape and size. Wouldnt hurt to wipe them off either just be careful not to bend."
    ECGREG
How to clean corona wire on brother 7840W
Corona wires are in the drum cartridge, small screen or grid over them. usually there is a colored slide that you can move back and forth to clean coronas.
Jul 23, 2014 | Brother MFC 7840W Printer
Where do you find corona wires on Brother 7840W printer?
The wire is on the drum (where the toner cartridge fits in). The green or blue piece slide cleans the coroner wire.
Describe your how to clean the corona wire on hplaserjet 3050 Problem
Laserjet 3050 does not use corona wires. HP uses a PCR roller which applies the charge to the drum unit. HP stopped using corona wires on most units years ago. What print problem are you having that makes you think that you need to clean the corona wire?
May 01, 2011 | Office Equipment & Supplies
Copies are black and where is this corona wire? I
Your cartridge has two sections, the drum and the toner section. The corona wire is on the drum section. There should be a blue tab on the top left hand side of your drum unit. Slide this tab across the cartridge one or two times, returning the tab to its original position. There should be an arrow on the blue tab that will match up with an arrow on the drum unit when the tab is in its resting position. Performing this action cleans the corona wire inside the cartridge. If this doesn't fix it you may need to purchase a new drum unit.
Dec 22, 2009 | Brother IntelliFAX 2800 Laser Fax
Black lines through printed pages have cleaned unit and replaced black drum unit.....still have black lines
Clean the charge corona wire/charge corona roller and the charge corona wire gride,and the transfer/separation corona wire/roller.After clean the units and clean the optical section perform the auto image adjust mode.
Sep 28, 2009 | Sharp AR-BC260 Color Copier
How to clean MFC 8820 corona wire of drum
simple solution for cleaning any corona wires Use a lead pencil eraser Gently clean the corona wire, with light even strokes, Best solution (recommended to me by my Copier tech teacher)
Jul 09, 2009 | Brother MFC-8220 Fax
Cleaning the drum unit corona
Message is telling me that the drum is dusty. It says to clean the corona with the wire. I don't know what the corona is and I cannot find a wire that might help me know how to clean the corona
Aug 18, 2008 | Brother Office Equipment & Supplies
Corona wire
I was getting the clean the corona wire problem message even after repeated cleanings.  Before this problem occured the toner light was flashing warning of low toner. When I got the clean the wire pop up the toner light was on all the time indicating the toner was depleated.  So, I thought I would try replacing the toner cartridge and see what happened. I opened the new toner box and noticed on the foil packege specific instructions to clean the corona wire when installing the new toner.  I installed the new toner and cleaned the wire one more time. I then reinstalled the drum and toner assembly into the printer and the clean the corona wire message did not come up again.  The printer now works fine.
Aug 08, 2008 | Brother HL 2140 Laser Printer
Dirty Edges
I'm sorry to tell you, this is likely a drum issue.
You probably need to have a certified engineer examine the machine.
Have you tried speaking with the local service center to see if they have experienced similar issues? It might be free information.
Erik.
May 13, 2008 | Xerox WorkCentre XD120F Laser Printer
Brother MFC-7440N Laser Printer Logo
224 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
