Question about Acer AL1916B 19" LCD Monitor
Acer AL1916 monitor powering off
Once in a while or often when I'm working on something, my lcd will just blank out & go to the Acer logo once or multiple times to the logo & then back to its normal state. It happens at any time & not because of any application. It gets bugging cause sometimes I'm doing something important & I'm not sure whether it will come back.
Now tell me all the issues or solutions you can think of & I'll narrow it down. I used to work as a computer tech. a while ago but this problem puzzles me. Thinking its an inverter board is not enough for me to rip it open unless someone can make sure of it.
Thanks in advance guys ......
Greg
  • 180 Answers
Try checkin the inverter board.
Posted on Apr 20, 2008
How to change monitor aspect ratio for acer AL1916
The aspect ratio is expressed as two numbers separated by a colon (x:y). and they actually represent the relation between width and height of (in your case) your monitor.
Did you mean to change the resolution of your monitor? Could you please explain your problem in more detail? What is it exactly you want to achieve?
Oct 22, 2013 | Acer AL1916 A (Black, Silver) 19 inch LCD...
ACER LCD monitor has no power.
It is probably the inverter which powers the backlight. It should say inverter right on it.
Feb 08, 2010 | Acer AL1916B 19" LCD Monitor
Acer al1916 lcd flat panel display turns on but no picture.
yeah, it's fixed, answer already posted, just typing this to stop the site from notifying me...
Dec 15, 2009 | Acer AL1916B 19" LCD Monitor
Acer al1916 monitor, yellow picture
If your menu button is not working then you cant to do anything. I adviced to you pls check it from service center.
Oct 15, 2009 | Acer AL1916W 19" LCD Monitor
Acer lcd monitor ''no signal''
It is screen resolution problem.
when you power up the computer press F8 key thene nter in enable vga mode then go to diaply property and set screnn resolution to 1024*768 thenh apply and ok.
Jul 12, 2009 | Acer AL1916W 19" LCD Monitor
Acer LCD Monitor only displays "acer" logo
You are correct, it could be a power surge that has caused it.
Try this..
Unplug the monitor from the wall.
Remove all the video connections at the monitor end.
Wait 10 minutes then plug the monitor back into the wall (do not connect the video leads)
Turn it on and see if it goes past the ACER logo now. If so, replace the video cables and try the computer.
If not, then one of these will apply and a tech will be required..
  1. The internal bios has been corrupted.
  2. The power supply inside the monitor may have issues preventing the video board from starting correctly. This could be as simple as a few failing capacitors.
Number 2 is the most likely cause with an Acer monitor though. Any local tech will be able to correct it fairly cheaply, but phone around for quotes..they can vary a lot.
Jun 03, 2008 | Acer X193W LCD Monitor
Acer al1916 monitor goes black
You probably have a few dodgy caps on the power board inside. It's an easy fix if you are confident around electronics.
If not, pop it off to your local TV repair shop and have it taken care of now before it gets expensive with a complete failure.
Hope it helps =)
Apr 09, 2008 | Acer AL1916W 19" LCD Monitor
Monitor won't turn on.
it something that is defect in the power mian board. Try to seach any buldging capacitor. that might have problem you.
Nov 23, 2007 | Acer AL1916B 19" LCD Monitor
Acer AL1916B 19" LCD Monitor Logo
162 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
