Question about Toshiba Televison & Video
Dvd combo d-vr18dtkb no longer allows me use the dubbing process as when I press dubbing the red symbol appears on the screen. Also the DVD menu in the set up setting is not avialable as an option.
SOURCE: Zenith XBV443 DVD Player / VCR Combo - Set Clock Manualy
I have the Zenith xbv613 model DVD/VCR player and also need to change the clock set up. For the xbv613 I had to switch the player to VCR. The menu button did not bring the clock set up in DVD. When I switched to VCR and hit the menu button the clock set up showed, where I used to right arrow button to change the time. Hope this helps.
Posted on Oct 27, 2008
SOURCE: FINALIZING DVD+R DUBBED FROM VHS TAPES
The manual gives you incorrect info.
To FINALIZE disk:
1. Press [HOME] button;
2. select [SETUP].
3. Scroll down to DVD ICON and SELECT
4. Select [FINALIZE]
Perfect Answer provided by "petoNOVY" - THIS ANSWER ALSO APPLIES TO ZENITH XBR616 - I struggled for 2 years to find it!!! THANKS!!!
Posted on May 15, 2009
SOURCE: LG DVD/VCR Recorder Combo RC195 will not finalize DVD after dubbing
It seems that it won't finalise because the disc is full. If you stop before the "Disk is Full" warning at two hours you should be able finalise, but, the disk still won't be recognised. DVD+R seems to work OK.
Personally with LG, Life's NOT Good.
Posted on Dec 13, 2009
  • 56 Answers
SOURCE: Just got this Toshiba DVR620KU and need to record
Good one!
Sounds like you are doing everything right. Only things I can think of are:
- Make sure the disc is a blank one.
- Try a different disc.
- Make sure the tape you are trying to dub is not encoded with Macrovision copyguarding. If it is a home-made recording then you are OK, but a factory recording on a store bought tape may cause some difficulties.
If you are still having troubles try a complete 15 minute reset by unplugging from the power source.
Posted on Apr 22, 2010
  • 61 Answers
SOURCE: D-VR18DTKB - When dubbing from
Get sycronized because you're going to have to stop the video player and the CD you are dubbing onto at the exact second or have a glitch in it. I used to do weddings and other video services and used two sometimes three cameras. If I were you I could edit my video before I downloaded it to a master copy unless of course you have a hi-tech CD recorder with a built in dubbing feature. I didn't but one of my cameras did. I would make a rough video mixing different scenes from different cameras and get the scenes and angles where I wanted them in the video. When it looked right I usually edited music over it or narrated it, didn't have a CD player more less a recorder back then. If you are using a camera or a video recorder that will fade in and out use that feature to do your editing. It works perfect and looks good, If it fades in different colors use a color that kinda reflects on the previous scene or that will set up the next scene. When you get your tape like you want it burn it on to a DVD!. this will make a good master disk. I am going out on a limb and assuming that you are using video tape to do this, but if your using CD's the same principle applies. It can be a lot of fun and when you get good at it and get a computer with the right software you can move heads and add and replace people. If you have access to a computer you can download software for free that will let you do a professional of a rough CD to your master and it will do most of the work. Remember, if you copy a second generation Cd you can get pretty good quality but the more it's copied the more quality it looses. Good luck and have fun; dhgill
Posted on Aug 27, 2011
Lost manual for DVD Recorder/VCR ZV450MW8 Need instructions to copy DVD Disk to VDD Disk or e-mail manual
To dub a DVD, first press Setup on the remote. Then select Recording (use the Up/Down arrows and then press OK). Navigate to and select Dubbing Mode. Select the direction for the duplication. Then press Setup to leave the Setup menu. Then press DVD to ensure that the unit is ready to play the DVD. (Press VCR if you are dubbing a video tape.) Then Press Play to advance to the section that you wish to duplicate, if needed, and then press Pause. (Press Pause a bit early; the dubbing process will lose about 5 seconds.) Now, press the other Mode button (VCR if recording to tape, DVD if recording to DVD). Next press D.Dubbing on the recorder or the remote. (The button is to the right of the Channel Up/Down buttons on the recorder. It's near the bottom left on the remote.) Press Stop when the section to be duplicated has been played in its entirety.
The Magnavox ZV450MW8 was manufactured by Funai with the Magnavox name. Thus Funai Service has the manual available: http://www.funaiservice.com/manual2012_search2.php . The direct link is http://www.funaiservice.com/manuals/MAGNAVOX/ZV450MW8/ZV450MW8.pdf . The directions for dubbing a DVD to VCR or vice versa start on page 48. Note: copy protected items cannot be duplicated.
I hope this helps.
Dec 10, 2014 | Televison & Video
How do you record dvd to vhs and from vhs to dvd
For VHS to DVD, put the tape to dub in the VHS slot and a blank DVD in the DVD tray. Make sure the DVD is compatible with the DVD recorder (see the recommended disc list) and is unfinalized if you are using a R/W disc. Close the tray. Set the unit to VCR mode with the DVD/VCR button. Advance the tape to the place that you want the recording to start. Then press the Dubbing button (either on the remote or the unit itself). Select the recording mode (SP, LP etc), highlight Dubbing then press Enter or Dubbing. Press Stop to interrupt the recording.
For DVD to VHS, put a blank tape in the VCR (make sure the protection tab has not been broken off) and the DVD to duplicate in the DVD tray and close the tray. Put the unit in DVD mode by pressing the DVD/VCR button. Find the point at which you want to start recording the DVD. Again press Dubbing and set up the recording mode and highlight Dubbing and press Enter or Dubbing.
Note that copyprotected content can not be recorded.
The manual for this recorder is on the right side of the page here: http://www.lg.com/us/tv-audio-video/video/LG-dvd-recorder-RC897T.jsp . See page 48 for the screen captures of setting the recording mode part of the dubbing procedure.
I hope this helps.
Mar 19, 2011 | LG RC897T DVD Recorder/VCR Combo
I would like to make a copy from my video tape to a DVD How do I do it?
Turn on the TV and set it to the video source to be able to easily see the menus as you set up the dubbing process. Put the source tape you want to record in the VCR. (Copy protected tapes will not be dubbed.) If you want to avoid dubbing from the DVD to the VHS tape, remove the erase protection tab from the cassette. Put a compatible recordable disc (non-finalized disc, unprotected disc) in the recorder and make sure there is sufficient available capacity on the disc.
Press Rec Mode/Speed to set the speed (SP, LP, SLP, or XP). Press DVD/VCR and set the unit to VCR mode. Confirm the mode with the indicator light on the unit. Press Dubbing and the mode should switch to DVD automatically. Select Yes (with the left/right arrows) and press Enter to start the duplication. The unit should indicate the VCR playback, dub and DVD recording are in progress. Press Stop to halt the dubbing process or it will stop when the unit reached the end of the tape or the disc is full.
The dubbing button is only on the remote control; if your original remote isn't working make sure that your replacement remote has the feature. Remotes.com often has exact or substitute remotes with the matching features. Search just by the model number not the brand.
BTW: the manual is available here: http://www.managemylife.com/mmh/owner_manuals/26967/SANSUI-DVD-VCR-Combo-L0311311?brand_name_search=sansui+VRDVD4005 .
I hope this helps.
Nov 11, 2010 | Sansui VRDVD4005 DVD Player/VCR
Using a Sylvania DVR90VF, how can I record from a VHS tape to a DVD?
OK here's what the user manual has to say on it!
PS If you need the user manual I will E-Mail on request.
Prepare for the recording on the DVDRW/ R disc or the videotape. Make sure:• Insert a recordable disc and a videotape with a record tab.
Note for recording to a disc:
• Make sure that the disc is recordable.
Hit [SETUP].
Easy Setting Menu or Advanced Setting Menu will appear. If Advanced Setting Menu is displayed,
proceed to step 3.
Using [
K / L], select “Advanced Setting Menu”.
Hit [ENTER].
Using [
K / L], select “Recording”. Hit [ENTER].
Recording menu will appear.
Using [
K / L], select “Dubbing Mode”. Hit
[ENTER].
Option window will appear.
Recording
Auto Chapter 10 minutes
Timer Programming
DVD-RW Recording Format Video mode
Auto Finalize
Dubbing Mode VCR DVD
VCR DVD
Recording
Timer Programming
Auto Finalize
DVD
VCR
DVD-RW DVD-R
VR
DVD-RW
Video
Note
For VCR to DVD duplication:
• After starting VCR to DVD duplication, the picture may be distorted because of the auto tracking function. This is not a malfunction.
5
Using [
K / L], select “VCR DVD”. Hit [ENTER].
6
Hit [SETUP] to exit.
Make sure to select a recording speed using [REC SPEED].
7
Hit [PLAY
B].Then hit [PAUSE F] at the point you
wish to start recording.
• Since it takes about a few seconds before the actual dubbing begins, please allow extra 5 seconds
when selecting the starting point.
8
Hit [DUBBING].
VCR to DVD duplication will start.
9
Hit [STOP
C] to stop the
recording.
When you turn off the unit after setting the Dubbing Mode to DVD VCR, the setting will be set to VCR DVD automatically.
• Dubbing Mode is available only if the videotape or disc is not copy protected.
• You cannot change the output mode during VCR to DVD or DVD to VCR duplication.
• The playback sound mode is followed by the setting of VCR playback sound mode on page 77. Set the playback sound mode to which you wish to record to the DVD.
May 12, 2010 | Televison & Video
Dubbing to dvd no longer works, no error code
Apparently the disc I was using had something wrong with it, but not until I was almost 4 hours into dubbing something over. Changed the disc and started over and it works fine now. I guess with all the problems I had with the Emerson unit, I figured this one was about to buy the farm as well. Sorry to bother anyone.
Jan 04, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Lg dvdcombo region codes
I have just hacked an LG 32LG4000 combo tv/dvd. To open up the dvd to multi region, turn on the tv & press the menu/set up button. Next, navigate to the lock symbol but do not open the sub menu. Press 0 seven times. Exit out of the menu, and your 'on board' dvd player will play dvd's from any region!
Nov 28, 2008 | LG 32LG40 32 in. LCD HDTV
No Instruction Manual
1. Insert a blank DVD disc in the DVD deck and
close the disc tray.
2. Insert the VHS video tape you wish to copy into
the VCR deck.
3. Find the place on the VHS tape from which you
want to start dubbing using the PLAY, FF, REW
and PAUSE functions. For best results, pause
playback at the point from which you want to
record.
4. Press the DUBBING button on the Remote
Control or DUB on the front panel.
The Dubbing menu appears.
5. Use the arrow keys to select the desired Record
Mode: EP, LP, SP or XP.
6. Select [Dubbing] then press ENTER or DUBBING
to start copying.
7. To stop dubbing at any other time, press STOP (x).
Dubbing will stop automatically when the VHS tape ends.
Mar 01, 2008 | Insignia IS-DVD1001 DVD Recorder/VCR
Dvd/vcr combo,vcr is fine ,but dvd no picture,or sound,disc reads.
Hi There is an I/P button on your player's remote control. Power your player on then press the I/P button on your remote control.
Aug 16, 2006 | Apex Digital ADV3800 DVD Player/VCR
Televison & Video Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
