Question about Samsung HLN5065W 50" Rear Projection HDTV-Ready Television
Replacin the color wheel in HLN5065
I need some directions on replacing the color wheel in HLN5065
  • Samsung Master
  • 8,457 Answers
U machanically incline?Not hire a tv tech. to this,because,u have to take out many machanical parts,before even can take out the Colors wheel to replaced.Try website like You Tube Type in Samsung colors wheel replacing.U will get a tutoring by some one doing or trying to replaced the colors wheel.
Posted on Jul 12, 2010
Directions and pictures on how to replace the chasis brain box for an Infiniti G35 ABS ctr under dashboard
before replacin try 1st reprogrammin-need to get to a shop that specializes--if u replace new problems can be there that mite be hard to work out
May 03, 2011 | Infiniti G35 Cars & Trucks
I replaced the color wheel in my HLN5065W DLP tv now I dont even get a picture. After 3 times of it restarting itself I get 3 flashing lights on the front of the TV.
THIS IS JUST A SUGGESTION, IF I am right give me a very helpful vote here and a note, check the ribbon cable----color wheel has two cables--one regular and one orange--look at contacts on orange one--they should face the back of the light engine--it is very possible to put the cable in backwards--common issue.
SD TECH
Sep 01, 2010 | Samsung HLN5065W 50" Rear Projection...
Samsung DLP HLN467W
This tv have a colors wheel.Now ur tv colors wheel it dead.The colors wheel is dead,no colors black&white,loud squiling noises,loud motor noises.All indication of the colors wheel is dead,spinning off of is axis,not function anymore.Hire a tv tech.for this.Not machanically incline,don't atemp to change the colors wheel ur selp.
Jul 12, 2010 | Samsung HLN467W 46" Rear Projection HDTV
How to replace the samsung HLN5065 W color wheel. I have replaced the lamp and ballast. there is a clear noise developing that I assume is the color wheel. What all do I need to remove to get at the...
Be sure to label your wirers when disconnecting, it really is easy to change out the color wheel,thats what I had to do to mine another expert on FY did post How to replace Color Wheel see if you can find it they did an excellent job on that Post.Color wheel is located in front of the Lamp, Pull lamp out and use a flash light you will see it. You will also have to pull the chassis out good enough to be albe to reach color wheel .Good Luck with your Repair.
Jun 11, 2010 | Samsung HLN5065W 50" Rear Projection...
NEED SCHEMATIC FOR SAMSUNG DLP HLN5065
What is wrong with your TV ? Call Encompass they might have what you are looking for! 1-800-638-3328 they will have parts for Samsung. I myself own the same TV 5065W just replaced Lamp and Color Wheel.
Sep 29, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung HLN5065 DLP TV - Turns on, have low quality picture
you have a bad color wheel replace it yourself its easy part is 95.00 plus s/h
May 26, 2009 | Samsung HLN5065W 50" Rear Projection...
SAMSUNG HD DLP HLN5065 50" TV
The problem of your DLP TV is a defected color wheel,replaced that so it will works normal again.
Hope it may help you;
Regards,
VOTIT
Sep 22, 2008 | Samsung DLP HL-P5663W 56" TV
Samsung hln5065 picture issue
If all 3 lights are blinking on Samsung DLP it means your lamp is burnt out or has issues. The manual says replace the lamp when all 3 lights are blinking. If you can hear the arc from the ballast the lamp should light if the lamp is operational.A new lamp should solve your problem.
Mar 01, 2008 | Samsung HLN5065W 50" Rear Projection...
Tv repair
If the color is available by itself you may be able to buy it from tritronics on the web. It is not as simple as some may claim to install . Some require the light engine to be sent in to get rebuilt. Make sure you know what you are doing . Having it rebuilt can be costly sometimes avg. between 300.00 to 500.00 if you do it your self . Call a tech if your not sure you can safely disassemble your set.
Feb 27, 2008 | Televison & Video
Buzzing noise in the TV
The Samsung HLN5065 is a DLP TV. Color wheel or fan. Thefan is the last to turn off. That's how you'd check it. Tube
Oct 21, 2006 | Samsung HLN5065W 50" Rear Projection...
Samsung HLN5065W 50" Rear Projection HDTV-Ready Television Logo
174 people viewed this question
Jerry Greenberg
Jerry Greenberg
