Question about Dell UltraSharp 1901FP 19" Flat Panel LCD Monitor
No sound main menu volume frozen?
I have no sound, monitors main menu volume is frozen. everything else checks out. HELP
  • 180 Answers
Is the power light indicates ok.
Posted on Apr 20, 2008
Volume too low
are you using the monitor's volume or are you using speakers? If its monitor volume, I would say go into the main menu of the monitor by pressing the menu button. Then go to the volume setting and raise the level. If the volume level is already on the highest, you may want to consider using another solution to monitor sound, such as speakers or headphones connected to your computer.
Oct 18, 2012 | ASUS Vw223t 22" Widescreen LCDFlat Panel...
How do you rest a thunderbolt
First, try this:
From the main home screen, tap menu
Tap Settings, then Privacy
Tap Factory data reset
Tap Reset phone
Enter your password if required, then tap Erase everything to confirm
If that doesn't work, or if your phone is frozen:
Turn the power off. If your HTC ThunderBolt is frozen, pull the battery out and reinsert it
Hold the Volume Down button
Press and hold the Power button until the device turns on
You are now presented with a menu that allows for Fastboot, Recovery, Clear Storage, and Simlock
Select Clear Storage by pressing the Volume Down button
Press and release the Power button
Now simply confirm your decision: Volume Up for YES and Volume Down for NO
All data including third-party applications will be deleted from the HTC ThunderBolt. Once the wipe is complete, the phone will reboot to its factory fresh state.
Sep 06, 2012 | HTC Thunderbolt (8 GB) Smartphone
Monitors not audible with Behringer 1680S
Assuming you're trying to power the monitors from this unit as well as the mains.....Confirm that the amp switch is in the middle position which splits the internal amps....one for main and one for monitors. Output A would power the monitors.... B would power the mains.
Aug 26, 2012 | Behringer PMP1680S Europower 10-Channel...
I can not answer the phone if an unknown person rings
If you have tried a power cycle, and this does not help, you may have only one option left than to do a master reset.
First, try this:
  1. From the main home screen, tap menu
  2. Tap Settings, then Privacy
  3. Tap Factory data reset
  4. Tap Reset phone
  5. Enter your password if required, then tap Erase everything to confirm
  1. Turn the power off. If your Motorola DEFY is frozen, pull the battery out and reinsert it
  2. Hold the Volume Down button
  3. Press and hold the Power button until the device turns on
  4. You are now presented with a menu that allows for Fastbook, Recovery, Clear Storage, and Simlock
  5. Select Clear Storage by pressing the Volume Down button
  6. Press and release the Power button
  7. Now simply confirm your decision: Volume Up for YES and Volume Downfor NO
Feb 28, 2011 | Motorola Mobility Defy Cell Phone
The volume menu on my hp w2207 monitor keeps popping up and the volume on that menu auto-decreases down to 0. This does not bother me because the volume still works fin, since i dont use the monitor to...
Sounds like one of the buttons on the monitor is sticking physically. Try:
  • checking the buttons for dirt that might be holding it in
  • cleaning the buttons with a soft brush
Apr 15, 2010 | HP 22" Widescreen Flat Panel TFT LCD HD...
My volume menu from monitor pops up, volume auto-decreases
Was something spilled on the volume key? Sounds like it is stuck... you can use a fine toothpick and plain water to "scrub" around the key, there may be some buildup that inhitbits the key from "unpressing".
Hope this helps!
-- RT
Sep 02, 2009 | HP w2207 Monitor
No Sound
Have you tried checking if the volume control is locked?
To unlock it, you have to press the < > and the menu button simultaneously to unlock it.
Aug 04, 2009 | Hannspree 22" widescreen LCD Flat Panel HD...
TomTom won't talk any more!
Maybe you accidently turn OFF or reduced the sound volume. Tap the screen to go to MAIN MENU, then tap the CHANGE PREFERENCES, you might find a speaker's icon with words TURN ON SOUND. Tap it. If still not working, check Volume Preferences to set the volume level of sound.
Hope it might help
May 29, 2009 | Tomtom ONE GPS Receiver
Acer speaker?
There are two possible problems here. (1). The volume control on your monitor is turned down. With the button on the front of your monitor, find the menu/option button, and look for volume control (2) The volume coming out of your computer is low. Double click on the speaker at the bottom right of your screen, located on the start bar. Use the sliders to change the volume. This should fixya up.
Good Luck!
Dec 12, 2008 | Computers & Internet
No speaker volume
Hey Mate, being honest weve sold alot of TFT monitors and most are hard to hear with all the volumes turned up, only thing you can try are. turn volume up to max on the monitors menu, also double click on the little speaker icon on the bottom right hand corner of the screen and a volume menu appears turn up WAV, & the main one on the left. if you are not getting any sound at all check you have the audio cable from the monitor plugged into the green connection on the back of the pc. Afraid thats the only options to get it louder or buy a set of speakers to get the sound louder. All the best John
Mar 03, 2007 | Daewoo F227B Monitor
Dell UltraSharp 1901FP 19" Flat Panel LCD Monitor Logo
80 people viewed this question
Alun Cox
