Question about GE WWSE5200B Top Load Washer
Washer making clicking noise when attempting to agitate
My washer is making a clicking noise when attempting to agitate. The lights in my home flicker/dim at the same time. I had a repairman come to the house who adjusted the clutch but the problem persists. He then indicated that it may need a transmission, however my husband thinks there could be an electrical relay problem of some sort. Does anyone know of anything that could cause this problem other than a very expensive transmission?
Thank you,
Rachel
catriver
  • 878 Answers
SOURCE: washer make a clicking noise
Zoobs, you could have something stuck under the agitator. The agitator will pull straight off. Grip it on each side and pull up hard, but don't hit yourself in the face. If that don't work, try slipping a belt under it and pull. Check for something caught under it. Another possibility could be the nylon suspension rod socket supports in the back. They will make a noise during agitation if they are dry. Put a little 3 in 1 oil to quite them down. Take the front panel off and check the pulley and belt, see if anything is out of whack. I also often find the motor support hitting the bottom panel during agitation making noise. Take the front panel off and observe during agitation. See if the support is striking the bottom. If so, just bend the bottom panel down. Catriver..post back.
Posted on Dec 01, 2006
SOURCE: GE Profile Washer
1) Most GE appliances have service manuals. By the manual because it will save you the repair services for the life of the machine. 2) I am not familiar with the GE Profile, so I don't know if it has dial knobs, or control panels. Any way, your problems seem like the timer unit is the problem. If it has dial knobs, the timer costs about US$100 - $150. The control panel circuit probably costs that much. You can buy the service manual and parts from Sears or parts services
Posted on Aug 20, 2007
dididsaythat
  • 291 Answers
SOURCE: Washer agitates, but makes horrible grinding noise. Spins okay.
thanks for posting problem solve :0)
Posted on Sep 03, 2007
  • 1314 Answers
SOURCE: GE Profile Harmony 4.0 -Broken Clutch Coupling
if your under warrenty always call for service repairing it yourself voids your warrenty
Posted on Jan 15, 2008
SOURCE: GE Front Loader
We had our gasket tear as well. Called 6 different online vendors to find this part, WH08X10022, and finally found it at helpfulitem.com. I spoke with Mike who was great in helping me find the part and shipped out very quickly, from Lubbock, TX. to northern Arkansas. Replacement of the part took approximately 30 minutes and now we're back to washing clothes.
I do believe we'll be ordering a spare part just to keep on hand. With four kids, it is quite possible that we'll have it ripped again.
Posted on Feb 27, 2008
Excess noise coming from washer.
check to be sure it is agitating and spinning, if not you need to check the belt if equipped and the agitator. I had a similar problem and had to replace the agitator because it was stripped out. Very simple to do, remove the agitator cap and unbolt. Then reverse to install in what I have done. I have always been able to find part catalogs online that will show you all parts and how they fit together. Just search model and make.
Feb 04, 2014 | Kenmore 2942 400 3.2 cu. ft. Top Load...
Admiral washer model AW20N2V making a clicking sound...
call manufacturer. heard there was a recall... for dangers of fire.
Oct 02, 2012 | Admiral Washer Control Panel Frame 35-5733...
Whirlpool washer WTW5510VQO will fill, spin and drian but won't agitate, just makes a clicking noise.
If this is just clicking then the agitator bearings stuck or something is jamming it.
Jun 05, 2012 | Whirlpool Washing Machines
Drum knock when spin cycle
Hello.
Noises are common when using a two-in-one washer and dryer, as clicking or whirring is part of the cleaning process during the transition to the next cleaning process. The GE Spacesaver washer and dryer combo uses a top-loading washer stacked beneath the front-loading dryer, and uses an agitator that makes noises throughout the spin cycle. Although whirring or clicking is normal, other noises or malfunction indicates a problem with the washer that requires minor troubleshooting. Professional repair is necessary if the washer continues to experience problems during the spin cycle, as there may be a problem with the washer's agitator.
1 Open the washer's door and check the balance of the load's clothes. Clothes that are unevenly distributed around the agitator cause excessive shaking and result in an imbalance during the spin cycle. Reduce the load's size by removing clothing if the washer's drum is overloaded.
2 Push "Start/Pause" to pause the spin cycle and turn the washer's cycle knob to the "Off" position. Turn the knob to "Spin Only" and press "Start/Pause" to reset the cycle.
3 Turn the wrench counterclockwise or clockwise around the unit's legs to adjust the appliance's balance. The legs are adjustable with the help of a wrench to ensure the unit does not shake while in use. An unleveled unit shakes as it spins, and causes excessive squealing or rattling as it attempts to dry the clothes.
4 Touch "Start/Pause" on the front of the washer's control panel and unplug the washer/dryer unit's power cord from the electric oultlet. Wait two minutes and plug the power cord back into the electric outlet. Push "Start/Pause" to resume the spin cycle.
Thanks.
Nov 08, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Agitator Noise of Roper RTW4305VQ
yes this noise is normal.its the dog ears ratcheting in the agitator
Jan 19, 2009 | Roper RAS8244KQ Top Load Washer
Kenmore elite won't agitate properly
Does the bottom of your agitator work correctly? We had the same problem if you pop the cap off the top of your agitator there is a cam in there with 3 dogs that engage the agitator causing it to spin. If the bottom part is agitating correctly then chances are the dogs in the cam assembly are shot. If the bottom is agitating correctly then it is very possible you have something stuck under the bottom section of the agitator. If this is the case remove the top cover (same as before it's just a lid that pops off) inside you will see a 1/2" square use a 1/2" drive ratchet with a 3" or 6" extension unscrew this piece remove the top section of the agitator then the bottom. Once the bottom is out check to make sure all is clear inside the washer. Reassemble in the reverse order making sure the lower section sits all the way down on the splines for the drive mechanism. If neither one of those solve the problem I would suspect you have an issue in the drive train of the washer.
Dec 29, 2008 | Kenmore 24032\24036 Top Load Washer
Maytag top load performa, put clothes in , fill up and now the agitator is noisey, looked under washer belt appears to be loose 2-3 inches in play, should I replace belt,or something else to repair noise...
thats normal tension on the belt if the agitator is making noise the cams within the agitator are worn (loud clicking or popping noise during wash) the agitator will need to be replaced
Dec 15, 2008 | Maytag HAV2558 Top Load Washer
Whirlpool washer fills up; makes LOUD whine/click metal noise
sounds as if you have a bad mootor coupling, part number 285753, easy enough part to change, easier to search on the you tube site for whirlpool motor coupling repair, fo rthe video, then try to explain procedure, but definalty easy enough repair for home owner
Nov 19, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer Clicking/Ticking Noise
Washer is four years old. It makes a loud noise when agitating and now the drum is jammed. What can I do to fix it?
Thanks,
Apr 15, 2008 | Washing Machines
GE WWSE5200B Top Load Washer Logo
Top GE Washing Machines Experts
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
