Question about Craftsman 24 Hp 48" Deck Yard Tractor
How do i change the oil on my craftsman dyt 4000? It has a kohler 24 hp v twin engine. i bought it in 2004
  • 11 Answers
SOURCE: Craftsman mower
charge the battery sometimes they come not fully charged if not push down clutch/parking brake sit on seat becouse of dead man switch and then crank it over
Posted on Sep 26, 2008
chad7houston
  • 62 Answers
SOURCE: replacing the blades on a craftsman dyt 4000
Not a hard job, but you will need a couple of tools. First, you will need a wrench that fits the nut that is holding the blade on. I prefer a closed end wrench, but an open end will do. Second, you will need a blade changing tool. The brand name is called a Blade Hog. It attaches to the deck and holds the blade in place so you can turn the nut. Raise the deck as high as it will go, attach the Blade Hog, and then loosen and remove the nut. Be sure and pay attention to which side is up on the old blade and put the new one on in the same manner.
hope this helps,
c
Posted on Oct 08, 2008
wadembly
  • 513 Answers
SOURCE: craftsman DYT 4000, 24 hp 48
there is a fuse in engine compartment that might have blown causing the engine or blades not to start but what probably happened was something got caught in the blades check under the deck & see if there is & also try spinning blades by hand & see what happens
Posted on Jun 14, 2009
spekgt
  • 60 Answers
SOURCE: what engines will fit craftsman dyt 4000 (18.5 blew w/ 290 hours)
Hi there
The only thing you have to do is have the size (diameter) and lenght (from cranckcase to end of shaft) of the shaft you have on your b&s and just go to your local Honda dealer , give them your shaft size and they should be able to give you all the options for a brand new motor . I really believe you can get a Honda 20hp model GXV620 or a 24hp model GXV670 that will replace your B & S motor .
Hope this help .
Posted on Sep 01, 2009
  • 84 Answers
SOURCE: My Craftsman DYT 4000 keeps popping out of gear.
your trans. is broke, if you can keep using it i would, fixing transmission problems is more often than not more expencive than a new transmission, only the trans. will be effected ( it wont hurt the motor or anything) Six years is a little early to have these problems but seeing how much you use it, im not shocked by it
Posted on Nov 01, 2009
I have a DYT 4000 from 2004. Cutting the lawn today, about half way through something inside the engine popped (sounded like a belt) and the tractor shut off. I tried to restart and the starter was FLYING...
Sounds like an internal engine failure. Take the spark plugs out and stick a screw driver in the the cylinders. Then turn the engine by hand, and see if the pistons move. My guess is one or both won't, but if they do then you'll need to do more testing like a compression test or leak down tests. You may even need a partial tear down to find the problem. Sorry to be the bearer of bad news, but it is possible that it is repairable rather than having to purchase a whole engine.
Oct 03, 2010 | Craftsman 24 Hp 48" Deck Yard Tractor
Craftsman DGS6500 Garden Tractor 24 HP Kohler engine. Messages says CH6 Oil - what does it mean? Oil is full and new.
It means change the oil. It will come on every 50 hours regardless when the oil was last changed, then go off after a few hours.
Aug 28, 2010 | Craftsman 26 Hp 54" Deck Yard Tractor
Engine piston
SOUNDS like you have done a big end and when the oil gets warm the oil gets thinner and so doesent lub the engine so good and what you can hear is the piston either hitting the head or the bigend worn bearings on 1 cylinder banging on the crankshaft as they have to have oil there to lub and to pressure the bearings while running SO WHEN you get it rebuilt change your oil to a 20W40 in winter and 20W50 in summer and change it every 50 hrs for your own sake.
Oct 29, 2009 | Craftsman 24 Hp 48" Deck Yard Tractor
What engines will fit craftsman dyt 4000 (18.5 blew w/ 290 hours)
Hi there
Hope this help .
Sep 01, 2009 | Garden
24 hp intek has no power when under a load mainly when blades are engaged blows smoke like crazy.i pretty sure rings are shot,but the no powers got me stumped. valves are adjusted properly. i thought it...
I have good news for you,well sort of,the rings are probably ok.The intek engine is noted for blown head gaskets.They leak between the cylinder and the push rod chamber.A way to check is to start the engine for a minute,turn it off and pull the dipstick out,if you see vapors coming out of the oil fill tube it has a leaking head gasket.To check to see which cylinder is leaking, check the plugs,there will be a oil residue on one or even a brown crusty build up on the side that has the leaking head gasket.If you remove the head you will probably see a small piece of the gasket is missing on one side of it.
Aug 11, 2009 | Craftsman 24 Hp 48" Deck Yard Tractor
Craftsman DYT 4000, 24 hp 48" deck. While I was mowing, the blades stopped turning, started again, and then stopped. I shut down, all looked OK, tried to start and nothing. No click, nothing. Any ideas?
Jun 12, 2009 | Craftsman 24 Hp 48" Deck Yard Tractor
Craftsman 24 Hp 48" Deck Yard Tractor Logo
221 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
