Question about Kenmore Elite 45986 Front Load Washer
Kenmore washer does not clean the clothes very well ,after the wash still looks dirty
  • 15,935 Answers
For low water volume - or "Trickling" effect...
1. Turn off the water supply to both hoses.
2. Remove hoses (one at a time so you don't get them confused)
3. On the washer side - look for a removeable screen inside wher you just removed the hose.
4. Using a small screwdriver - pop out the screen and reverse-flush it/clean it. It will likely be full of sediment and calcium deposits from your pipes.
5. Replace the inlet screens.
6. Re-fit the hose to the machine.
7. Turn on water supply valves.
8. re-try.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Oct 01, 2010
I wash all my darks together. No fuzzy stuff either with the black items. Don't overload as I am only person doing laundry. Why the lint left on the clothes. Kenmore Elite Series 600. Please help.
Your Kenmore washer does not have a lint filter. Washers manufactured today and in the past few years are not designed with lint filters. The engineers rely on the dryer to remove any lint left on the clothes that doesn't get flushed down the drain.
overload the washer? The wash load must be balanced and not overloaded. Clothes should move freely.
Lint can be trapped in the load if overloaded. Wash smaller loads.
Use the correct water level? The water level should be correct for the load size. Clothes should move freely in the water.
Alsp liquid detergent works better in cold water and has modifiers to keep lint in the water not on the cloths.
Do you line dry your clothing? If so, you can expect some lint on the clothing.
Check the following too
Was paper or tissue left in the pockets?
Use the proper cycle time for the load? Reducing wash time (duration) is another way to reduce lint.
these should help in reducing the amount of lint left on your clothes.
Thank the wonderful engineers for this problem.
There is one other thing you can do. Micro fiber cloths attract lint like nothing else. Inexpensive ones added to a wash load will catch almost all the lint.
found this out the hard way by trying to clean some that I used in auto body seminars for removing polish and waxes when doing detailing demos. they came out full of lint when washed in a mixed load,..looked worse than they did dirty. well sort of..they were still good for what i wanted them to do but looked like heck. :) if rewashed alone they cleaned up.
hope I helped a little.
Dec 31, 2017 | Kenmore Washing Machines
Hi can you tell me which programme is the short wash and spin please
I think I have the same type of washing machine as you do. Wash is when all the clothes get agitated or mixed with soap and water (ever look in there when its washing? the water can get pretty gross looking!) So in my washer, the rinse cycle is when all that gross water is drained, and the washer spins while spraying clean water over the clothes to get rid of the dirty water and soap. I think mine does this 5 or 6 times in the cycle. Next is the spin cycle, which is when the washer spins REALLY fast to **** as much water out of the clothes as possible, so that the clothes aren't sopping wet when you put them in the dryer.
It sounds like your mom has a newer washing machine, probably a front load one, and they do seem to keep using clean water, instead of just agitating the clothes in dirty water.
May 17, 2011 | Electrolux EW1000i Front Load Washer
I am getting stains on my dark clothes that look like oil stains.
Check that the dispenser is clean, it may be gunged up with black gunge, use soda crystals and put machine on hottest wash. If all is clean it could be down to seal gone in drum letting grease into system. Good luck, let me know how it goes.
John
Sep 03, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Rust in Kenmore washed clothes
Sounds like you have a bad drum bearing. I would guess that it's grees rather than rust although it will look like rust.
Please rate solution if helpful
Aug 23, 2009 | Kenmore 24032\24036 Top Load Washer
Washing machine is dispersing oil on the clothing. We have taken it apart and cleaned it and have used the special cleaning solution because we thought it was dirty water being dispersed on the clothes...
Number 1 Cause .... using fabric softner in washer it accumilates around the top of the tub and it gets nasty! it depends on what type of machine you have if it is even possible to leak oil into the wash basket
Jul 05, 2009 | Kenmore Washing Machines
My kenmore washer leaves fleece and dirt on my clothes always
Nwanne,
It truly sounds like you have something in the washer that may be trapped.
I would remove the lint trap and make certain it is cleaned. Then check under the rim of the washer between the upper tub and the upper seal area. And lastly, check between the agitator bottom and the tub.
There really isn't any part of the washing machine that will produce "fleece" so I believe you have an article of clothing that is trapped.
Good luck and let me know.
Regards
May 14, 2009 | Kenmore Washing Machines
Kenmore Calypso Washer is leaving dark brown stains on clothes
hi is the machine noisy on spin cycle if so ur bearings have gone
May 11, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
My Kenmore Elite HE3 washer doesn't get the dirty laundry clean. It redeposits the dirt on the clothes, causing brown stains. I had a Sears rep look at it when it was new (5 years ago), and he said it was...
Brown stains are likely from the felt seal. The adhesive used from the factory disintegrate over time, and when you replace the felt - use some silicone instead.
Apr 08, 2009 | Kenmore Washing Machines
Dirty marks
Your problem is probably a little deeper than that. I would assume the machine is over five years old? I would remove the basket as well to clean out the tub where this problem starts.
Oct 04, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore Elite 45986 Front Load Washer Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
