Question about Hamilton Beach Beach 87108 Microwave Oven
Locating fuse on hamilton beach microwave model 87108
5 Suggested Answers
domotek
  • 591 Answers
SOURCE: I have a Hamilton Beach
maby it's the magnetron, i need more information, a good way to test the magnetron is to put a small HE-NE lamp in a glass filled with water (HE-NE lamps) are found in any radioshack (La source) store, if the lamp glowes orange it meens the magnetron is good, if it is not glowing then the magnetron is dead, (the magnetron is allmost the price of the oven) it could be a fuse but if you have to change the fuse replace it with the same type (normaly ceramic german type) NOT GLASS
Posted on Jan 04, 2011
SOURCE: I have a Hamilton Beach 900 watt microwave...when
how do i set my hamilton beach 900 watt microwave to 50% power
Posted on Jun 22, 2011
  • 6771 Answers
SOURCE: Microwave turntable won't turn.
Return the item to the place of purchase this is a manufacture defect. The problem is caused by a defective turntable motor.
Posted on May 20, 2012
  • 6771 Answers
SOURCE: Hamilton Beach hb-p90d23al-dj keeps blowing fuses
If the microwave oven is less than 7 years old the problem is in the magnetron, " the most expensive part " or the inverter board, either way costly adventure, good for target practice.
Posted on Aug 14, 2012
Testimonial: "Not an expensive oven, good advice that the fix is not worth it. I'll just get another oven."
Makes a loud noise does not heat
Dispose of it, and seek a new one... This one is operating dangerously, please don't try to fix it, they hold enormous amounts of residue charge.
Mar 17, 2014 | Hamilton Beach Beach 87108 Microwave Oven
Microwave doesn work
there is nothing in the manual
http://useandcares.hamiltonbeach.com/files/840203000.pdf
email mnf for advice:
support@hb-microwaves.com
Nov 06, 2013 | Hamilton Beach Beach 87108 Microwave Oven
I just purchased a hamilton beach microwave. The light comes on and all the buttons work but it will not run. What could be the problem?
follow this steps for troubleshooting and fix it. God bless you
  1. Inspect the power cordUnplug the power cord and check for voltage at the outlet. Also inspect for damage, shorts, or burn marks that can be a possible safety hazard.
  2. Bad door switchIf your microwave does not work at all and you know everything is plugged in properly and the outlet is functioning, then also check the door hooks and the door release button. Using a volt-ohm meter on RX1, check your terminals. When your microwave door is closed you should have a reading of zero. Once the door is open the reading should change to infinity. If these readings do not match up, replacement of the door switch is necessary.
  3. Blown fusesTo determine if your fuse has blown out, which may attribute to your microwave not running, you need to pull the fuse out using a pair of fuse pullers. Lay it down and using a volt-ohm meter on RX1, check both ends of the fuse in question. If you do not get a reading of zero, then you will need to replace the fuse.
  4. Bad fan motorLocate the fan and remove the leads. Again using the volt-ohm meter on RX1, check the terminals. If an infinity reading is displayed, it means that the fan has gone bad and requires replacement.
Read more: http://www.appliancepartspros.com/repair-help/microwave-repair-help.html#1#ixzz2gPsWBUo4
Sep 29, 2013 | Hamilton Beach Beach 87108 Microwave Oven
Between 1st and 2nd use the oven stopped working. No power
you will have to remove the case there should be a fuse close to were the power cord comes in check that!
Jul 14, 2011 | Hamilton Beach Beach 87108 Microwave Oven
I just purchased a Hamilton Beach Miicrowave HB P90D23AL-DJ two weeks ago at my local walmart. I have used it mostly to make popcorn for my kids and some nachos. This morning we put one pop tart in it to...
CONTACT HAMILTON BEACH THE UNIT SHOULD HAVE SOME KIND OF REPLACEMENT GUIDE LINES OR SOME TIMES YOU CAN TAKE IT BACK TO WALLMART AND TELL THEM THEY SHOULD REPLACE IT ALSO
Feb 06, 2011 | Hamilton Beach Beach 87108 Microwave Oven
Microwave sparking
Press Ok, Accept or replay
I have a solution for this
Bruce
Jan 14, 2011 | Hamilton Beach Beach 87108 Microwave Oven
Hamilton Beach Beach 87108 Microwave Oven Logo
478 people viewed this question
Top Hamilton Beach Microwave Ovens Experts
iclobster
Are you a Hamilton Beach Microwave Oven Expert? Answer questions, earn points and help others
