Wiring for a siemens raa02 thermostat - Heating & Cooling
Why when my siemens RDJ10RF room thermostat has the arrow asking for heat does my boiler not fire up so i don't get any heating.The water heats up ok though?
You have a triple aquastat that maintains a temperature level needed to provide hot water. but you are not getting the thermostat to operate the central heating. The thermostat is a switch that operates by temperature. if you have tried raising the thermostat and the system did nor kick in try jumping the thermostat terminals in the aquastat . if that works then the problem is either in the thermostat or the wiring to the thermostat. also with a electrical tester." while the thermostat is jumped" test the c1 and c2 terminals to see if power is going to the circulator. If not then you need a new aquastat. if you have power and the pump is not moving water replace it.
Oct 11, 2014 | Water Heaters
Why does Siemens KF57U56/16 Freezer works fine, but not fridge?
Check the thermostat adjustment in the fridge section if right up replace the thermostat.
Aug 28, 2014 | Siemens Kitchen Ranges
Need a fault finder for a Siemens thermostat
is that line or low voltage? 240/120 or 24/12v
Jan 23, 2013 | Electrical Supplies
Have siemens washing machine with cold supply in now running the whole cycle on cold is it the thermostat or the element
You must check the continuity of the element , check the wiring to the thermostat and the control panel.
Click on: Element
Jan 23, 2013 | Washing Machines
My raa02 therostat comes on when it cools down not when it heats up as it is suppose to
CHECK THERMOSTATE WIRING.
HEAT (h) AND COLD (C) WIRING MIGHT BE CROSSED.
Jun 16, 2010 | Heating & Cooling
Baseboard electric heater installed properly, yet won't work.
DID YOU CONNECT TO TH SAME END YOU TOOK OUT WHEN PAINTING WE ARE DOWN TO THE CONNECTION @ THE HEATER MAKE SURE THE OTHER END OF TH ELEMENT IS CLOSED WITH WIRE NUTS AND TIGHT , LIKE I SAID WE ARE DOWN TO THE HEATER CONNECTIONS SO LOOK THERE
Nov 22, 2008 | Fahrenheat Electric Convector Baseboard...
How to wire a raa20 siemens thermostat
I have got the diagram for you,but cant send it here,give me a e-mail where i can send it for you.
Waiting your reply
Sep 10, 2008 | Heating & Cooling
Heating & Cooling Logo
573 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
