Question about Craftsman Tools & Hardware - Others
Cannot make debth adjustment on model 315.269210
I have progressive shocks on my 2012 flhr how do I adjust them to keep the bike from bottoming out. There not air shocks
Motorcycle Suspension Adjustments Progressive Shock Adjustments
Here is one YouTube video on adjusting MC shocks. If this isn't the right model, check YouTube for your model. There are more videos on adjusting shocks.
May 05, 2015 | Motorcycles
Whirlpool Vantage dryer lint screen will not slide securely into place. It sticks out about 1/2 an inch. No lint reside is in the bottome of the compartment. What could be the problem?
Check the leading edge of the screen itself to see if it is expanded. Then, once again check the full debth of the slide there must be something all the way at the leading edge that is stopping it, probably compressed lint. You may have to use a flashlight and long thin piece of wire to fish out the glob.
Jan 20, 2013 | Whirlpool WGD7990XG Vantage High...
Wood not feeding and debth gauge not working
check the "bicycle" chain under the hood.there are 4 screws you can take off and you will see the chain. It is probably full of sawdust in the left corner
May 08, 2012 | Dewalt 13 in Planer
Can you get a bigger psu for dell dimension c521 that will fit inside the case
Hello aprilmick
I think you can.
the case dimension for your dell PC is H: 15.8" (40.13 cm) W: 4.5" (11.43 cm) ---> the standard power supplies have a width of less than 10cm.
D: 14.2" (36.07 cm) ---> the standard power supplies have a debth of almost 15cm.
Considering these measurments you can use a standard power supply of whatever rating you want. It may be a little too tight between the power supply and the CD/DVD drive, but it is possible.
Good luck
If you find this helpful please leave comment, vote.
Feb 15, 2011 | Dell Dimension C521 PC Desktop
How can I learn more about using my debth finder. Its new to me . Any video tutorials or materials I can read or watch?
look under support
http://www.lowrance.com/Products/Marine/HDS-High-Definition-System/HDS-5-FishfinderGPS-Chartplotter/
Feb 08, 2011 | Lowrance HDS 5 Fishfinder GPS Chart...
Just bought an canon EOS300n, WHAT IS A-DEP FOR ON THE COMMAND DIAL ?
The Digital Rebel also offers Canon's A-DEP focus option. A-DEP mode attempts to include everything covered by the focus points in the viewfinder within the lens' depth of field when you press the shutter. This is a handy feature for beginning photographers who haven't mastered depth of field control.
useful when you are trying to keep 2 or more objects in focus when debth of field is different.
Feb 14, 2010 | Canon Photography
Dryer wont start
Hello, Not really alot of information on this one but i will have a stab
  1. Check breaker
  2. Check thermal fuse
  3. Check door switch.
If you would like to provide some more information would be glad to get more in debth. Mike
Oct 30, 2009 | Kenmore 62602 Electric Dryer
Not showing debth
You may need to take it to an authorized dealer
http://www.diveaeris.com/dealers.asp
or contact aeris directly for support:
http://www.diveaeris.com/contact.html
Jul 07, 2009 | Aeris Max Depth Analog 2 Gauge Console
Guardian generac 10kw model 5502 does not output correct voltage
the instructions says the voltage regulator is automatic/digital. when you check the voltage is there any load on the generator? if applying load to the generator doesn't help, you can manually change the motor speed where the governor connects to the carborator, but it may change the frequency, but the regulator may fix it
Apr 12, 2009 | Guardian Electrical Supplies
Tools & Hardware - Others Logo
244 people viewed this question
Top Craftsman Tools & Hardware - Others Experts
Dusty Ryan
Level 1 Expert
Mike
John Trevino
Are you a Craftsman Tool and Hardware - Other Expert? Answer questions, earn points and help others
