Question about Canon Cameras
Hello Digi Cam experts, Model : Canon Powershot S5 IS Problem: Doesn't start. There was NO damages no drop downs. Even I tried to chage the AA bateries to new set of batteris(1.2 v, 2050mAh )2100 series with out luck. I yet to check CR1220 batteries. I appreciate all your suggestions ? BRs/ Aravind Espoo-Finland
  • Canon Master
  • 6,487 Answers
The battery terminals are dirty.
When camera does not operate with a brand-new alkaline battery (for cameras that use AA-size batteries) or with a fully charged rechargeable battery, the terminals may be dirty.
Polish the terminals with a dry cloth and make sure the terminals are clean. If the terminals are covered with oil from your skin or similar matter, this may cause poor contact and power may not be fully supplied to the camera.
Also, polish the battery charger terminals with a dry cloth before charging the battery. If the terminals are covered with oil from your skin or similar matter, this may cause poor contact and the battery may not be fully charged.
Posted on Jul 12, 2010
  • 6 more comments
  • getarvi Jul 12, 2010
    Hi, thanks for the proposal. I already read this solution 1 from Fixya and checked for any such moisture or dirt which protects the proper contact of battery. I have clean battery slots and no dirts or problem seen with contacts. Please advise if CR1220 batteries could be problem ? also any other suggestions ?
  • Mark Gil
    Mark Gil Jul 12, 2010
    Yes there's also a chance that its the battery, so its juts a battery or the contacts that can cause the problem and then the worse part if this is already a hardware problem.
    Hi, I seen there was a Yahoo Q&A for same camara and exactly same problem.
    http://answers.yahoo.com/question/index?...
    How much possibilities I have with CR1220 battery ? one guy said that he had the same problem, and he resolved it by spraying WD-40. What's your advise about it ?
  • Mark Gil
    There's a big chance about the CR1220 battery is the problem and yes using a WD40 can also help with this problem.
    I tried changing CR1220 battery with no success again :-( .. any further advise ?
  • Mark Gil
    Spraying a WD40 to the unit will be a ood thing to do now.
    WD40 spraying done, no help from it aswell.
  • Mark Gil
    That is all that we can do for this problem right now, the next step here is to take the camera apart and check the inside parts and also all the connections.
How i can recharge canon digi cam
The A480 uses two AA batteries. If you want to use rechargeable batteries, you must charge them in a separate charger. The A480 does not include any charging circuitry.
Nov 17, 2010 | Canon PowerShot A480 Digital Camera
Canon PowerShot SD630 turn off itself AND could not turn on again
since its been two years you have bought the cam either your battery is down or you might have dropped your cam down which had damaged the lens array!!!
try replacing the battery and if it works its an happy ending of the problem.but if it still doesn't work then you have to replace the lens array!
any way i suggest you to take your cam to a "pro" since only physical examination has the best analysis of the problem
Sep 13, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
Drooped camer now lens stuck
These cameras are easily broken by dropping them. Try to free it by hitting it easy at first, not too hard, you don't want more damage to it? Option number two is to take it to a camera shop for repair estimate. They will try what I'm telling you and chage you a lot if it works.
May 27, 2009 | Canon PowerShot A470 Digital Camera
Canon PowerShot A85
I decided to send you this from the Canon website to see if this helps:
Issue: What are the specifications for batteries that I can use in my camera?
Solution: Recommended AA batteries for your camera.
What types of AA batteries can I use? Canon rechargeable (NiMH) batteries For the best results, we recommend using Canon rechargeable (NiMH) batteries. Rechargeable batteries provide the best performance and are the most economical choice.
battery_charger_kit_cbk4_300.jpgThe Canon Battery & Charger Kit includes a battery charger and four rechargeable AA-size NiMH (nickel metal hydride) batteries. The battery kit can be purchase from the Canon eStore.
AA alkaline batteries AA alkaline batteries such as those from Energizer or Duracell will provide the best performance for non-rechargeable batteries.
  • ALL AA-based PowerShot digital cameras (including A Series and S5 IS / SX100 IS-type):"Never use manganese (non-alkaline) batteries."
  • Since the performance of alkaline batteries may differ according to brand, the operating time of the batteries you purchase may not be as long as the batteries that came with the camera.
Precautions:
  • Camera operating time may shorten at low temperatures when alkaline batteries are used. Also due to their specifications, alkaline batteries may expire faster than NiMH batteries. If you are using the camera in cold areas or for a long time, we recommend using Canon AA-size NiMH Battery Kit (a four piece set).
  • While it is possible to use AA-size nickel-cadmium rechargeable batteries, performance is unreliable and their use is not recommended.
  • Never mix unused and partially used batteries. Always load two or four (depending on camera model) fresh (or fully recharged) batteries at the same time.
  • Be careful to load the batteries with their positive (+) and negative (-) ends in the right direction.
  • Never mix batteries of different types or from different manufacturers. All batteries should be identical.
  • Before inserting the batteries, wipe the battery terminals well with a dry cloth. Oil from ones skin or other dirt may cause a considerable reduction in the number of recordable images or reduced usage time.
  • Battery performance deteriorates at low temperatures (especially with alkaline batteries). If you are using the camera in cold areas and batteries are running down faster than they should, you may be able to restore performance by placing batteries in an inner pocket to warm them up prior to use. But be careful that you don't put the batteries into a pocket together with a metal key chain or other metallic objects, as these objects may cause batteries to short-circuit.
  • If you do not plan to use the camera for a long time, remove the batteries from the camera and store them in a safe place. Batteries may leak and damage the camera if left installed during prolonged periods of non-use.
WARNING
Never use damaged batteries or batteries whose outer seal is completely or partially missing or peeled off, as there is risk that such batteries may leak, overheat, or burst. Always check the seals on store-bought batteries before loading them, as some batteries may come with defective seals. Do not use batteries with defective seals.
Oct 26, 2008 | Canon PowerShot A85 Digital Camera
Brand new Powershot S5 IS
Have you checked the batteries?
This camera should only use Alkaline AA batteries or NiMH batteries.
Are they flat or the wrong type
Also check that your memory card is installed properly and all covers are closed
Jul 01, 2008 | Canon PowerShot S5 IS Digital Camera
I have lost the ring for my Canon PowerShot S5 camera and can't find a replacement - not even on the Canon site - any suggestions
Im guessing you checked Ebay? I would keep an eye out for i on there. just becasue its not on there this week doesnt mean it wont be next week.
I would call Canon. Even though its not on the WebSite Im sure They can still get one for you.
Jun 26, 2008 | Canon PowerShot S5 IS Digital Camera
No LCD Display
Your LCD is broken.
I'm an Imaging Salesman at Circuit City and I would normally say to get the LCD fixed but that would be a waste of money due to the fact that this model was released in 2004 and you would be better off getting a new camera.
If you are looking for another Canon....
For good quality and "user-friendliness" i would suggest the:
Canon SD1000, SD870, SD750 (Thin, sleek designs that come with rechargable batteries)
For more a more convenient price without loss of quality you might want to check out the Canon PowerShot A560.
(A somewhat large and bulky camera that runs on regular AA batteries)
Good Luck!!
Oct 28, 2007 | Canon PowerShot A410 Digital Camera
Cameras Logo
29 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
