Question about LG Refrigerators
LG Frig Model LRSC2692577 is freezing contents at a 46 degree setting
  • 6,826 Answers
Generally,
The thermostat is bad if the contents are below 32 deg. F and the refrigerator is set at 46 deg. F.
If the coils are freezing, though, and it's warm inside the refrigerator's compartment, then the timer for the defrost cycle is off.
Of course, many newer refrigerators are microprocessor controlled, so resetting the refrigerator's power might help.
If not, warranty service is advised if still in the 1 year warranty. I think that it would still be worth it to fix the refrigerator if it is less than 5 years old, as well.
Wish you luck on this one.
Posted on Jul 12, 2010
Kenmore Refrig Model # 75922400 top Freezer. Freezer is freezing really good but frig is around 46 - 48 degrees at coldest setting. We discovered ice on vents in freezer and thawed them out with hair...
Sounds like a defrost failure.
Look on the back wall of the freezer from the inside.
If it is covered in ice your defrost system has failed.
Also check the fan motor in the freezer.
If it is not running it must be replaced.
Feb 24, 2011 | Kenmore 18.9 cu. ft. Top Mount...
Freezing problem in maytag frig
the probe from the temp panel is not sensing correct temp or the panel itself is bad...call a tech to check it out
Feb 04, 2010 | Refrigerators
Our LG LFX25950SB has been freezing all the food in the refer since we purchased it 3 years ago. Had numerous service calls. They tell us we are leaving the door open, we do not have the correct...
Contact LG @ 1 800-243-0000 and let them know what is going on.
This is a known problem and a fix is availiable.
LG may help you out.
Call M-F for the american call center to answer.
If they wont you can fix it real easy.
Pull out bottom crisper dware.
Look on the back wall.
You will see a dime sized hole.
This hole allows cold air from the freezer to cool the crispers.
Cover the hole with a small piece of duct tape.
This should stop the crispers from freezing.
Also on the right wall of the ref. you will see 1 or 2 egg shapped white covers.
Remove the covers carefully so you dont break it.
You will see a 1" white thermister probe.
Pull the probe out of the insulation and clip it on the egg shaped cover and reinstall the cover.
The thermister tells the computer how cold the ref. is.
Jan 12, 2010 | LG LFX25960 Titanium Bottom Freezer French...
Freezer will not freeze solid. contents are cold, but not frozen. all settings are set to coldest setting. compressor will not kick on when freezer door is left open. I think the problem is that the...
Good day,
No real solution except to put it in a warmer location.
Understand, it is a refrigerator with the freezer just going along for the ride.
All manufacturers state the machine must be in an area that is no colder than 55 degrees.
The problem you have, is once the refrigerator section reaches temperature 34 to 39 degrees, it shuts the whole machine off. If the air temp surrounding the machine is near or approaching that temp, it shuts off, and may be off most of the day,
Domestic refrigerators are engineered to operate in area comfortable to people. Normally 70 to 95 degrees. Below that it will begin to unbalance.
Thank for using FixYa
Jan 12, 2010 | Refrigerators
Have set fridge at 46 degrees yet salad veggies still freeze in the compartments. How can I fix this?
Remove the bottom drawers and locate the vent small round hole. cover it with a piece of sturdy tape...problem solved.
Nov 03, 2009 | LG LRFD22850 Bottom Freezer Refrigerator...
LG French Door Model LFX 25960--Freezing in right crisper door
Have person who changed out you controlboard come back and recheck connections and controlboard itself.
Jul 26, 2009 | LG LRFD22850 Bottom Freezer Refrigerator...
We have a LG Two Side Fridge.
Look for the air ciculation regulator sliding vent between frig & freezer section open accordingly. Set both sides to #3 on dials if frig not cooling to less than 40 degrees, might need new cold/temp controller behind frig dial
Apr 30, 2009 | LG LRSC21934 Side by Side Refrigerator
Samsung RS2545SH Freezing Everything
Sounds like a thermostat problem. There will be a thermostat sensor inside the fridge usually inside the interior light housing.
Sep 26, 2007 | Samsung 26.0 Cu. Ft. Side-by-Side...
Refrigerators Logo
Top LG Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
christian nielsen
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
