Question about Honeywell Heating & Cooling
Replace honeywell V8034F1051 zone valve
I want to replace honeywell V8043F1051 zone valve that controls hot water.
I do not want to replace the whole valve with plumbing and all involved or replace the motor or switch only. If I order a new valve, It seems easier and less costly to buy the whole valve than just the replacement head, can I easily remove the part (replacement head) from the valve, unscrew the defective ''head'' from the valve I have and install the new ''head?'' The valve has been in place since 1998 - might it need some lubricant to get it off?
To my surprise, by tracing the wiring, I find that the superstor water tank is wired and powered through the boiler. When I turn off the boiler, the motor of the valve goes cold. I appreciate your input.
  • Monika Schrauder Nov 24, 2010
    Clarifying my previous posting:
    I have a TACO ZVZ404 4-zone control unit which connects 3 heating zone valves and the Honeywell V8043F1051 zone valve for hot water. I recently replaced the head of the V8043F1051 zone valve because it had stopped working and the new head worked for about 3 months.
    I am not sure if the problem has anything to do with another problem that I have with heating zone valve units that has also developed. The lights on the TACO ZVZ404 4-zone control unit when the heating zone valves are calling for the boiler to come on are orange and red (each heating zone). I noticed that the Honeywell V8043F1051 zone valve for hot water shows only one, the orange, light when calling for the boiler to torn on which it does NOT. I also noticed that two of the heating zone valves when calling for the boiler to come on work only intermittently , one (a TACO heating zone valve installed 6 yrs ago, being the newest one) always turns to boiler on. Could there be a problem with the TACO ZVZ404 4-zone control unit ALSO?
    Because I returned the Honeywell V8043F1051 heating zone valve for being defective, I temporarily wired in the old V8043F1051 zone valve I still had. Having taken the wires off on the top two connections all at once, I am not sure if I reconnected them correctly. Should they be white - red (from left to right) on the top as well as white - red which they are on the bottom?
    I want to make sure I reconnect the wires on the replacement unit I ordered correctly.
    So - the questions:
    Could I have a problem with the TACO ZVZ404 4-zone control unit?
    Should the Honeywell V8043F1051 zone valve for hot water show two lights on ZVZ404 when calling for the boiler to come on?
    Did I reconnect the wires correctly on the V8043F1051 hot water zone valve?
    Thank you. ms01007
    Thank you paulcarew; striclty re the Honeywell V8043F1051 heating zone valve f
    Should the wires be white - red (from left to right) on the top wire connectors as well as they are on the botttom white - red (from left to right)? I want to make sure I reconnect the wires on the replacement unit I ordered correctly. thanks.
  • Honeywell Master
  • 3,351 Answers
Why not just but the head or come to that the motor in side , cheaper option
Posted on Jul 13, 2010
Testimonial: "Prompted by your suggestion, I bought only the replacement head for the honeywell valve, saved me money and was so easy to install. Thanks!"
  • 2 more comments
  • Monika Schrauder Nov 20, 2010
    Honeywell V8034F1051 zone valve replacement head only worked for 3 months - There is only one light (orange) that shows on the taco control valve while the heating zone valves display two (orange and red) when calling for the boiler to come on.
    I am returning the unit in the meantime I am not sure if I switched the wire connection to the old valve I am using as a wiring place holder. The bottom two wires are white red (left to right) from directly transferring each of the wires from newer to the old unit BUT when I reconnected the top wires which I had both taken off at once instead of one at a time that I got confused if they also go white red (left to right) to connect to another (heating zone) valve. That is how I currently reconnected them. Just wondering if I mixed them up because when I replace the V8034F1051 I want to make sure I connect the wires right.
    Strange thing that has started to happen, not only did the old and now the new valve (after 3 months) stop working, one of the heating zone valves does not work any more either, and sometimes another doesn't either. The are connected to a 4 zone control valve unit TACO ZVC404. The lights go on (orange and red) from the heating valve, it opens, but does not turn on the boiler. Could it be the 4 zone control valve that is the problem?
    Please let me know 1. if I reconnected the top 2 wires correctly
    2. how to check if the 4 zone control valve is causing the problems.
    Thanks. ms01007
  • Paul Carew Nov 23, 2010
    sorry you lost me on this a bit ?
  • Paul Carew Nov 24, 2010
    Sorry i have never worked on a taco unit I could not tell you anything about it or how it works I cannot give your any info on this that might help infact i would not give you bad advice that would cost you money ,that would be my mistake
    Thanks for your input.
    Strictly re the Honeywell V8034F1051 hot water valve.
    I am returning the defective unit iI had installed that only worked for 3 months and in the meantime I am not sure if I switched the wire connection to the old valve I am using as a wiring place holder. The bottom two wires are white red (left to right) from directly transferring each of the wires from newer to the old unit BUT when I reconnected the top wires which I had both taken off at once instead of one at a time that I got confused if they also go white red (left to right) to connect to another (heating zone) valve. That is how I currently reconnected them. Just wondering if I mixed them up because when I replace the V8034F1051 I want to make sure I connect the wires right.
Diverter valve?
It's likely a zone valve. It may need replacing The actuator may be seized To verify check that it is getting 24 VAC If not then check the transformer that supplies it for 24 VAC.
Dec 05, 2013 | Heating & Cooling
How do l replace the electronic gas control valve on a whirlpool hot water heater tank?
Whirlpool is made by American water heater.
Gas valve is made by Honeywell.
Whirlpool electronic control is version of Honeywell 'Icon' gas valve: There are several versions of this gas valve.
http://waterheatertimer.org/pdf/Bradford-White-service-manual.pdf
Start page 24 shows: Testing, disassembly and replacement of typical Honeywell gas valve.
Whirlpool phone number 1-877-817-6750
Whirlpool manuals:
http://www.whirlpoolwaterheaters.com/support/manuals.aspx
Aug 10, 2011 | Whirlpool Water Heaters
MY APARTMENT HAS ELECTRIC WATER BASEBOARD HEATING SYSTEM, I found out the heat cannot be turned off even I disconnect the honeywell thermostats (only one on the wall for the whole unit - living room and 2...
Okay couple questions here because either you have hot water baseboards or you have electric baseboard heaters.
- if the system is a hydronic baseboard heater fed form main boiler, usually this means your space heat is controlled by a zone valve which the zone valve is controlled by your thermostat.
-if you find the zone is controlled by a zone valve than it is possible the zone valve is defective causing hot water to bleed past the zone valve even though your t-stat is telling it to close.
- first find out what excatly the baseboard is heated by either water or electricity
-next personal message me and I can walk you through it
May 29, 2017 | Honeywell Heating & Cooling
User guide needed for old Honeywell programmable heating control
It depends on your system some will only work with hot water on and heating do you have two zone valves?
Jul 18, 2017 | Honeywell TH4210D1005 Heater
Valve replaced , but 1 zone out of 3 no heat when
Hello. Each zone in you home has one thermostat controlling one zone valve. Generally, when a thermostat is calling for heat the zone valve opens and the circulating pump comes on to move the water around that loop. If your other two zones are both working as they should and you now have a new zone valve on the third loop I would suspect that the thermostat is faulty. Regards, Joe
Dec 12, 2009 | Honeywell Programmable Thermostat Heater
St6400c thermostat wont run the central heating independantly
This does not sound like a thermostat problem. I would be looking for a zone valve or circulator pump problem.
Nov 05, 2009 | Honeywell Programmable Thermostat Heater
Have hot water but no radiators. Checked pilot
sounds like your circulating pump is bad or electronic zone valves
Oct 26, 2009 | Honeywell Programmable Thermostat Heater
One of my 3 zone valves on my hot water base board heatig system
You need to check for power to the zone. If you have power then the valve is bad and needs replacement.
Mar 22, 2009 | Honeywell Heating & Cooling
Heating & Cooling Logo
959 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
