Question about Gateway GT5220 PC Desktop
Cannot "unmute' -volume control
Trying to "unmute" my computer. No matter where I go to fix volume whether it be from control panel, right clicking the icon, i cannot fix.
    Sergeant:
  • 206 Answers
First, check the connections and make sure you have everything plugged in correctly. Restart the PC...try clicking on the icon again...if that doesn't work, post back and we'll try to figure it out.
Posted on Jul 12, 2010
My sound is muted on my monitor
you should have a button on the monitor to pop up a menu which will let u adjust the volume, also in the lower right hand corner of your computer screen look for an icon that looks like a speaker, right click this and you can adjust volume here or unmute, it maybe hidden and you may need to click the little arrow to reveal the speaker icon. Failing this go to Start Menu, Control Panel, Audio/Sound and find it here.
Dec 23, 2013 | Computers & Internet
How do you unmute Acer Acrcade?
If you're using Windows 7 (it should be similar in any other version) try this:
  1. Go to Control Panel > Sound
  2. Under Playback tab right-click on your device and select Disable
  3. Then right-click on the white space [empty space] in the sane area and select Show disabled devices
  4. Enable you device.
This should do it....Good Luck
May 16, 2013 | Acer Computers & Internet
Volume is mute
There is probably a button or key you can press to unmute the volume. Most times you have to Press and Hold the FN function key at the lower left portion of the keyboard then hit the key that has the megaphone with the x across it.
You could try right clicking on the megaphone at the bottom right near the time and adjust the volume or properties. Remove the check mark from mute.
Or you can look for the Audio Sound properties in the Control Panel. Click Start/Control Panel and look for Audio Sound. Open it and remove the mute check mark if it is on the volume controls.
Apr 29, 2012 | Computers & Internet
My microphone is not working. it is on unmute and i would like to unmute it.
Right click the speaker icon at the bott right of screen and go to volume controls. Make sure the microphone input volume is all the way up.
Mar 06, 2011 | Toshiba Satellite A135-S4527 Notebook
My Compaq Presario CQ60's Speakers Make noise when I mute and unmute it, but I can't get any other sounds to come out of the speakers. What Should I do?
you might have to uninstall then reinstall both the driver and the sound devices
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make the necessary adjustments there or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers or right click select properties to either troubleshoot,uninstall,rollback driver
hope this helps
Dec 25, 2010 | HP Compaq Computer Speakers
How do I unmute my computer?
Go to Start, then select Control Panel. In the Control Panel window, select Sounds and Audio Devices and the option will be under the Volume tab of the Sounds and Audio Devices Properties window that opened. If you're using Category view of Control Panel, click on the Hardware and Sound category and then click on Adjust System Volume under the Sound option.
Hope this helps!
Dec 16, 2010 | Dell Dimension 5100 (D51L1) PC Desktop
No sound in speakers everything is correct
Hi there
You need to update your sound drivers,to do this go to start menu on your computer and type in the word "device manager",select it from a list of options and click on it you will see a list of components/devices that are working with your computer select the "sound" component.
Click on it and you will see your sound driver,right click the sound driver and you will see a list of options select "update driver software" this automatically search for updates,download them and install it in your computer.
You will have to restart your system for the update to work properly.
Sep 02, 2010 | Microsoft Windows XP Professional for PC
Mic not working stilllll!
I'm not certain about yours, but my Acer Aspire 5920 has an audio/volume turn button, just under the lip of the laptop, just to the right of center. Even if you un-mute it, if the volume is turned down all the way - the button revolves, so looking a the front, turning it counter-clockwise will turn the volume down to off, and you won't hear a thing, no matter how much you try to un-mute the thing.
So turn that rotating button to the right, to make it louder, after you have un-muted a control panel volume slider and moved it up, and that just might make it work for you.
Jun 25, 2009 | Acer Aspire One PC Notebook
HP Pavilion Entertainment PC
I was having a similar issue. My volume button worked fine muting and unmuting the volume, the light just stayed red either way.
I went into Device Manager, then expanded the Sound, Video and Game Controller options, I rolled back the driver and it was an instant fix for me :)
Jun 07, 2008 | Microsoft HP Pavilion DV6276US Notebook PC
Gateway GT5220 PC Desktop Logo
242 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
