Question about Mitsubishi WD-73737 73 in. HD-Ready TV
Wd73737 blinking green power light - Mitsubishi WD-73737 73 in. HD-Ready TV
My tv keeps turning off i have a mitsubishi wd-73737 what can i do to fix it?
Posted on Sep 10, 2010
    New Friend:
Green light flashing. Turned TV model 73737 off, then held down the Activity and Channel down button together for 10 seconds or so, long enough to see the TV flash once than pause, than twice repeating the same pattern twice. What do I do from here to reset the TV?
Posted on Mar 10, 2014
Beeps red light hp pc
The blinking should be in a pattern.
Power Green On (S0) Computer on
Power Green 1 blink every 2 seconds (S1) Suspend Mode
Power Green 1 blink every 2 seconds (S3) Suspend to RAM
Power Green Off (S4) Suspend to Disk (if applicable)
Power Clear Off (S5) Computer off
Power Red 1 blink followed by 2-second
pause - Repeat
Power Supply failure
Power Red* 2 blinks 1 second apart CPU thermal shutdown
Power Red* 3 blinks 1 second apart CPU not installed
Power Red* 4 blinks 1 second apart Power supply overload (crow bar)
Power Red* 5 blinks 1 second apart No memory
Power Red* 6 blinks 1 second apart No graphics
Power Red* 7 blinks 1 second apart System board failure (detected prior to video)
Power Red* 8 blinks 1 second apart Invalid ROM
Hard Drive Green Blinking Hard drive activity
*Blinking
Aug 17, 2013 | HP Computers & Internet
I have a Mitsubishi t.v. model wd73737. When I power on the green light continuous to blink and the blue welcome screen comes up and that's it. T.v. won't shut off I have to hold power button for...
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, [Exclude the model number] in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Aug 27, 2017 | Televison & Video
Tv turns off by itself with an amber or red flashing light. lamp replaced about 6 months ago.
Should be a high voltage or power circuit problem,like transistor too hot,or any component short circuit.
Oct 29, 2012 | Mitsubishi WD73737
I have a Mitsubishi WD-62525 HDTV that suddenly wont turn on. Just has a green blinking light when you hit the power button. Any ideas?
I found this on another website, most likely it is your power supply capacitors.
  1. Press the "reset" button and hold for 10 seconds .... Does TV turn on and blinking green light turn to solid green.
  2. Unplug the TV from it's power source for various times, ranging between 5 minutes and 24 hours..... Does blinking green light continue upon plugging in the TV.
  3. Disconnect ALL devices from the TV; DVD, Tuner, Cable Box, unplug the TV for various duration times .... Does blinking green light continues upon plugging in the TV.
  4. Press Power and Menu buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  5. Press Power and Display buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  6. Insure that no front panel buttons are inadvertently stuck in an "engaged" position.
Diagnosis: If none of the above test resolve the issue, then the failure lies in one of the following:
  1. DM Module Capacitors have FAILED.
  2. DM Module is defective.
  3. EEPROM Board failure
  4. Power Supply failure.
Feb 28, 2011 | Mitsubishi WD-62525 62" Rear Projection...
Tv will not come on. the green light on the front on the tv blinks, the blue screen come on and the tv shuts off. I've tried the reset procedure. I've unplugged the set for a while. Nothing works. The TV...
First the tv cannot be only 3 months old, (needs chassis rebuilt- send to mitsubishi they do it for around $300) and how did we go from DLP to adjusting screen levels and focus adjusment? PLEASE if you have limited knowledge you will be more helpful if you don't share it.Thanks
May 30, 2010 | Mitsubishi WD73727 73" HDTV
Computer will not turn on. green light blinking
Try replacing the power supply, a blinking green light usually means the power supply is missing an output voltage. If you do that and you still get a blinking green light then the motherboard will need to be replaced.
May 01, 2010 | HP Media Center m1080n (PC099A#ABA) PC...
Sony Wega Tv powers on w/ green power light and
need to know how many time the red light is blinking there should be a pause. 4 blinks is a fan, 3 blinks is the lamp door is not closed 6 blinks is thermal sensor.
Apr 22, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
When charging battery green light flashes then red 3 times
KODAK Easyhare digital camera light status
1. Blinking green light(or blinking blue or white light in some models) - Means camera is performing a power up procedure. Note: Wait a few moments to see if the camera displays a solid green (or blue or white) light or a blinking red light.
2. Solid green light(or blinking blue or white light in some models) - Means Camera has sufficient power
3. Blinking red light - Means camera batteries are weak or need replacement; If battery are new and still red light camera needed to be repaired
For futher assistance contact Kodak support line 1 800 235 6325 (23KODAK)
Nov 21, 2009 | Kodak EasyShare M863 Digital Camera
Green light blinking
The green light on the front blinkes and does not stop even after hitting re-set button.
Oct 26, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Power button blinking green
disconnect the power cord overnight try it if ok change power cord cheers
Dec 29, 2007 | Panasonic PT-40LC12 40" Rear Projection...
Mitsubishi WD-73737 73 in. HD-Ready TV Logo
1,780 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
