Question about Radio Communications
My dx 959 recieves rerally good. But when I transmit it jumps. For example when on am I can Rx fine on 27.185 (19) but it'll jump to 27.174 (19) when I key.
  • tiger_talk Jul 12, 2010
    I heared a rattle inside so I opened it up. Vr7 adjustment screw had came off. I'm not able to fix it correctly right now. Is there a way to bypass for the time being?
  • 11,800 Answers
The vr7 is for the gain to the mic, if the adjustable resistor is ok then leave it as is.
Actually when you transmit it changes channel from 19 to 18 - or the indicator falsely thinks that. If this behaviour happens whatever the modulation (AM or SSB) that signals an internal fault - the cb must be inspected by an authorized repairman.
Posted on Jul 12, 2010
  • 6,826 Answers
I think that the cb radio is using its 'clarifier' range of 1Khz to find the right frequency.However, if you disagree and believe it's malfunctioningthere is a 2 year warranty that can be redeemed atGalaxyradios.com. Do you have your receipt? Was it purchased in the last 2 years? I hope this helps.Good luck. DX 959 Specifications:
GENERAL:
Channels
40
Frequency Range
26.965 - 27.405 MHz
Emission
AM/USB/LSB
Frequency Control
Phase-Lock-Loop Synthesizer
Frequency Stability
0.001%
Temperature Range
-30oC to +50oC
Input Voltage
13.8V DC
Antenna Impedance
50 Ohms
Speaker Impedance
8 Ohms
Size
7-7/8"(W) x 9-1/4"(D) x 2-1/8"(H)
Weight
6 lb.
TRANSMITTER:
RF Power Output
AM 4W; USB/LSB 12W PEP
Frequency Response
300 to 2500 Hz
Frequency Tolerance
0.005%
Spurious Emission
Better than -55dB
Unwanted Sideband
Better than -55dB
RECEIVER:
Sensitivity for 10dB S+N/N
AM: 0.5uV; USB/LSB: 0.25uV
Squelch Sensitivity
Less than 0.5uV
Audio Power Output
2W @ 10% distortion
Image Rejection Ratio
-65dB
AGC Figure of Merit
100mV for 10dB Change in Audio Output
Clarifier Range
+1.0 KHz
  • Duane Wong
    Duane Wong Jul 12, 2010
    A loose screw would tell me that it wasn't put together right in the first place.
    Is it within the 2 year warranty period?
    You shouldn't have to mess around with the inside of it.
  • Duane Wong
    You shouldn't have to put a screw in. Let the factory service do it if it's too small to work with.
    Loose screws are not a good sign for electronic equipment.
    Good luck to you.
FC-347 causes radio's transmit frequency to jump around when plugged in.
I don't understand why anyone would want to install one of these when the radio already has one.
Jul 01, 2012 | Galaxy Radios Fc-347 Frequency Counter For...
Tip
Galaxy DX 959 CB radio no transmit or talkback
Hi, I have a problem with this CB radio. The PA works good but after installing the MOSFET kit as mentioned here http://cgi.ebay.com/DUAL-POWER-TRANSISTOR-MOD-KIT-GALAXY-949-959_W0QQitemZ190256621565QQcmdZViewItem?hash=item190256621565&_trkparms=72%3A1205%7C39%3A1%7C66%3A2%7C65%3A12%7C240%3A1318&_trksid=p3286.c0.m14 it wont transmit and I cant hear myself on talkback nor do I hear the roger beep. The PA amp works though.
on Oct 15, 2008 | Galaxy Radios DX-959 40-Channels Base CB...
How to wire a HG M73 mike to a galaxy DX 959
Stock
1- Shield (Ground)
2- Yellow (Audio)
3- Red (Transmit)
4- White (Receive)
Cobra
Stock
1- Audio
2- Transmit
3- N/C
4- Shield
5- Receive
Dec 04, 2011 | Galaxy Radios DX-959 40-Channels Base CB...
Is it best to use in am mode in normal trasmitions on a cb radio dx 959 galaxy?
  • This Galaxy was built as a CB to run on AM (11 Meter). The majority of people on the CB run AM stations. Sideband (upper and lower) is where the carrier is removed and the wave being transmitted on is cut in half. You can do this just fine but mainly if you want to talk to someone and you both know your going to be on Sideband for a little privacy. 38 LSB is a great channel to catch some DX side band on world wide. But yea, AM is the best to find people to chat with.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Oct 01, 2011 | Galaxy Radios DX-959 40-Channels Base CB...
Receive is ok, but when I transmit on SSB the Freq. jumps 10KC. What adjustments can I do to get the transmit back on Freq. without effecting the Receive?
go to you tube and type in your radio make and model and watch the review on that radio there is a freq adjustment pod for ssb adjustment. they might tell you if not take it to a radio tech and he should be able to alighn it. there is more than one pod for ssb transmitt and receive.
Mar 21, 2011 | Galaxy Radios DX-959 40-Channels Base CB...
My galaxy 959 sqeals and does not receive or
mike has wiring problems. Check for breaks in cord and where the plug goes into the unit. If not original mike then has incorrect wiring for the radio and will need to be changed for config
May 01, 2010 | Galaxy Radios DX-959 40-Channels Base CB...
Refurbished dx 959 from galaxy no modulation? no transmitt?
If there is no transmit at all, it sounds like it wasn't fully refurbished. If it is just low modulation then just turn VR16 and VR14 all the way to the left.
If its not working at all, send it back. It hasn't been refurbished.
Apr 24, 2009 | Galaxy Radios DX-959 40-Channels Base CB...
External jack
sounds like you got a good radio to practice on . If it was given to you then you have nothing to loose except what ever you put into it. try hooking the speaker jack back up, see what it does??
Apr 12, 2009 | Galaxy Radios DX-959 40-Channels Base CB...
Galaxy DX 88 HL jumping frequency
sounds to me like a bad PLL chip. but then again, I'm no Master tech myself.
Apr 19, 2008 | Galaxy Radios DX- 88HL Base CB Radio
Radio Communications Logo
Top Radio Communications Experts
eradiostore
eradiostore
Marvin
Marvin
Are you a Radio Communication Expert? Answer questions, earn points and help others
