Question about Protron PLTV-32 Television
My TV will not pwer on, I have replaced the ac power cord and made sure the switch was in the on position that is next to where the power cable gets plugged into the tv. The blue led lite in the front is not lit to say its getting power. Its a PLTV-3250, 32" LCD tv.
  • 11,361 Answers
This is common problem with the PLTV-3250, the power supply DC filter caps go bad, 5vdc standby transistor and diode shorted out.
Check the power supply; look for bad caps with leaking/bulging tops, check to see if you have standby +5vdc at the power supply connector, the front red indicator will not be on if you do not have this +5vdc standby voltage due to shorted out Q7 and ZD4.
http://s807.photobucket.com/albums/yy352/budm/Protron%20PLTV%203250/
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Power supply: http://www.google.com/products?rlz=1T4GGIH_enUS282US283&q=pltv+3250+power+supply&um=1&ie=UTF-8&ei=9lIDTL7XO4fcM7HA-Ds&sa=X&oi=product_result_group&ct=title&resnum=1&ved=0CCgQrQQwAA
Posted on Jul 12, 2010
My coby lcd tv won't work for my ps3 what wires would I need to make it work
You will need an HDMI cable. Please follow the below instructions.
Instructions
  1. Before you begin installation:
    • Turn OFF the PS3TM system using the [MAIN POWER] switch (in the back)
    • Unplug the AC power cord from the electrical outlet
    • Turn OFF and unplug the TV
  2. Connect one end of the HDMI cable into the [HDMI OUT] port on the back of the PS3 system. Connect the other end of the HDMI cable into the [HDMI Input] port of the TV or display monitor. ps3_8_hdmiconnecttv.gif
  3. Plug in the AC power cord by connecting one end of the AC power cord into the [AC IN] port on the back of the PS3 system and the other end into an electrical outlet. ps3_11_connectacpower.gif
  4. Press the [MAIN POWER] switch on the rear of the system. A red light should appear on the front of the system indicating power is available.
  5. Turn on the PS3 by pressing the touch-sensitive [On/Off button] on the system front. The red light will turn green, indicating the PS3 is now turned on.
    Note: The blue light will also appear on the front of the system if you have a disc inserted.
  6. Plug in the TV and turn the power on. The PS3 should detect the HDMI display device automatically. When prompted, "Do you want to output video and audio using HDMI?", select YES and press the icn_btnx_color.gifbutton. (You may need to press the PS button on the center of the SIXAXISTM controller to enable the controller first).
  7. The next screen will ask, "Do you want to automatically switch to the optimal setting?" Select YES and press the icn_btnx_color.gifbutton.
  8. On the next screen, the PS3 will display the maximum resolution capable on the display (i.e., 1080p). The screen will display, "Do you accept the setting?" You will have 30 seconds to confirm your answer.2 Select YES and press the icn_btnx_color.gifbutton to save your settings. You have now completed the HDMI installation.
Dec 01, 2014 | Televison & Video
Power Light stays Yellow
sounds like you have a power issue, or maybe the power switch is faulty. check that.
Jul 17, 2008 | Vizio L32 32 in. LCD HDTV
My kirby G6 2000 no pwer
More than likely you have a short in your power cord. however if you want to know for sure take machine apart until you can put an elec meter on switch where cord is attached. plug machine in and test the end of cord that is attached to switch if you have 120volts at that point its your switch thats bad. if you have no voltage or anything less than 110volts at the switch replace cord
Jan 14, 2013 | Kirby Ultimate G Bagged Upright Vacuum
The t.v powers on for just a second and clicks off. I can hear a click from the back and it recycles off/on over and over.
open the set remove all but the ac cord connectors from the power supply; label them first! turn on the tv if the power supply does not recycle turn off the set and, connect and, disconnect each cable one at a time going to the power supply turning the set on and, off each time as you test until the power supply cycles (fails) again then repair or, replace the circuit board that causes the power supply to fail. if the power supply cycles on and, off (fails) with all connectors but, the ac cord disconnected repair or, replace the power supply.
Jul 19, 2010 | LG 42PC3D 42 in. Plasma Television
Where do I get lost cords for this monitor?
are you mention about the AC adapter or just power cords. For pwer cords is everywhere, but ac adapter you have to know the specification for the power input/output and size of plug since I can't tell the model on your description.
Mar 22, 2010 | Samsung SyncMaster 245BW Monitor
JVC AV-48WP55 won't pwer up.
Start at the wall plug. Did a breaker trip for that outlet? Next use a multimeter to check voltage at the power input to the TV where the power cord connects to the mainboard. Be sure you are checking AC voltage. Next check DC voltage at the power switch on the inbound side of the switch. The power switch is usually after the transformer and AC to DC circuit. If you are getting power to all three places, check the other side of the on/off button. This will eliminate most of the power-related circuit. Also, look for blown capacitors, or burned areas around the power circuit.
Nov 28, 2017 | JVC AV-48WP30 48" Rear Projection...
Sound but no picture. menus work.
I had the same problem. In the menu, the image button was grey, and could not be hi-lighted, and the screen stayed blue. I was using the AC power cord. I plugged in the DC power cord instead, and it "woke" the unit up. I switched back to the AC power and it works fine. If you don't hve the DC cord that came with the TV, try andy 12 volt dc output cord with a positive tip.
Jul 12, 2009 | Polaroid 15'' HDTV Monitor FLM-1511
My kid power off tv by power button on tv, next time i could not
switch tv on the switch can not contribute to that. unless the following goes fault
i switch getting fixed on one position(holding)
ii check power on a input of tv and input fuse
iii power supply, i have said that because if a power supply is ok, sound was going to be there.
Nov 22, 2008 | Samsung TXG2547 25" TV
Philips magnavox won't turn off and stay in demontration mode
Hold both volume buttons at the same time for 6-10 seconds and that will reverse it. This has been proven to work!!!! YEAH
Mar 03, 2008 | Philips Magnavox 27MS343S 27" TV
Protron PLTV-32 Television Logo
252 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
