Question about Gateway 550GR PC Desktop
My cooling fan (not the one with the shroud) makes a lot of noise. Can I get and easily install a replacement.
    Genius:
  • 1,121 Answers
Yes you can replace the all fan inside, except the power supply fan . In these situation is normaly the power supply box is changed.
Posted on Jul 12, 2010
95 buick regal two fans in front , one make clicking noise after vehicle turned off. Its continues to spin and makes a clicking noise after turning off engine
It is normal for the fan to stay on after the engine is off. The clicking is not. Once the negine is cooled down and the fan is not running. check the fan by spinning it and try to locate the clicking noise. Make sure the fan doesn't wobble. If it does then the bearings are going out, replace the fan. The clicking could be something lodged in the shroud, clicking against the fan blade. Like a stick.
Jul 01, 2011 | Buick Regal Cars & Trucks
Tip
How to test and replace radiator cooling fan.
Hi.
Here a tip illustrating steps to test and replace the radiator cooling fan and the parts that may cause cooling fan malfunctioning.
Before replacing the fan, make sure that the fan is really faulty.
Read volts at fan contacts or jump the fan wiring to energize the fan directly.Ensure that fan blades are not blocked.
If the fan is OK, then the faulty part is either thermostat or fan relay.Ensure also that you have tested the 15A fuse in the junction block and the 40A fuse located in the Power distribution Center (PDC).
Here a diagram showing the location of the fan relay:
Finally, here below the steps required to replace the fan. The procedure is quite simple.
  • Disconnect the battery negative cable and set it apart.
  • Disconnect the electrical connector to the radiator fan.
  • Undo the bolts that hold the top fan housing and fan assembly (this is called Radiator Shroud).
  • Remove the Radiator Shroud housing.The radiator shroud will come out with the fan sliding toward the top side.
  • Install the new fan performing the operations in reverse order.
Here a diagram showing radiator shroud and cooling fan assembly:
Regards.
Ginko.
on May 25, 2010 | 2000 Jeep Grand Cherokee
How to remove radiator
  1. Drain the cooling system.
  2. Unfasten the upper fan shroud bolts and remove the upper fan shroud.
  3. If equipped, remove the upper panel fasteners and the panel.
  4. If equipped, remove the upper insulators and brackets.
  5. Disconnect the radiator upper and lower hoses and, if applicable, the transmission coolant lines.
  6. Remove the coolant recovery system line, if so equipped.
  7. Remove the oil coolant lines, if equipped.
  8. Remove the lower fan shroud bolts and the lower fan shroud.
  9. Remove radiator from the lower brackets and insulators.
  10. To install:
    1. Install the radiator on the lower brackets and insulators.
    2. Install the lower fan shroud and its retaining bolts. Tighten the shroud bolts to 71 inch lbs. (9 Nm).
    3. Attach and tighten the engine oil cooler pipe bolts to 18 ft. lbs. (24 Nm) and the transmission oil cooler bolts to 19 ft. lbs. (26 Nm).
    4. Attach the lower and upper radiator hoses..
    5. Install the upper insulators, the upper fan shroud and fan shroud bolts. Tighten the shroud bolts to 71 inch lbs. (9 Nm).
    6. Attach the coolant recovery system line, if so equipped.
    7. If equipped, install the upper panel fasteners.
    8. Refill the cooling system.
Jan 13, 2011 | 2001 Chevrolet Silverado 2500HD
About how long will it take to replace the radiator?
About 2.5 hours
Hope this helps, it it does please leave feedback and vote Thank You and Good Luck
  • Tools Required
  • J 38185 Hose Clamp Pliers
Removal Procedure
110563917
Caution: Before servicing any electrical component, the ignition key must be in the OFF or LOCK position and all electrical loads must be OFF, unless instructed otherwise in these procedures. If a tool or equipment could easily come in contact with a live exposed electrical terminal, also disconnect the negative battery cable. Failure to follow these precautions may cause personal injury and/or damage to the vehicle or its components.
  1. Remove the battery.
  2. Remove the air cleaner assembly.
  3. Drain the cooling system.
  4. Remove the right and the left engine mount struts. Refer to the following procedures:
    • Engine Mount Strut Replacement - Right
    • Engine Mount Strut Replacement - Left
  1. Use J 38185 to remove the inlet hose clamp from the radiator.
  2. Remove the inlet hose from the radiator.
  3. Remove the transmission oil cooler lines from the retainer clip at the bottom of the cooling fan shroud.
110563918
  1. Remove the bolt that connects the fan shroud to the condenser hold down bracket.
110563919
  1. Remove the cooling fan shroud bolts.
  2. Remove the coolant reservoir hose from the radiator overflow neck.
110563920
  1. Remove the radiator upper support brackets and bolts that connect to the fan shroud.
  2. Disconnect the engine cooling fan motors electrical connector.
  3. Remove the cooling fan motors electrical harness from the fan shroud clips.
  4. Remove the cooling fan shroud.
  5. Remove the bolt from the condenser tube support bracket to the radiator.
  6. Use J 38185to remove the outlet hose clamp from the radiator.
  7. Remove the outlet hose from the radiator.
  8. Disconnect the transaxle oil cooler pipes from the radiator.
  9. Tilt the top of the radiator rearward.
110564721
  1. Remove the condenser hold down bracket (1) from the radiator.
  2. Remove the air deflectors from the top of the radiator.
  3. Lift the condenser from the mounting tabs on the radiator (2). Position the condenser aside.
  4. Remove the radiator.
Jan 02, 2011 | 2004 Chevrolet Impala
2005 Jeep Liberty overheats at idle but while in movement temp returns to normal.
Check to see if the fan on the radiator is working at idle.
Here's information on how to change the fan if needed:
Engine Cooling Fan Removal & Installation 2.4L Engine To Remove:
  1. Remove the coolant bottle and set aside.
  2. Remove the power steering reservoir and set aside.
  3. Disconnect the cooling fan connector.
  4. Remove the cooling fan mounting screws and the cooling fan.
To Install:
  1. Install the cooling fan and the mounting screws. Tighten to 50 in-lb (5.5 Nm).
  2. Connect the cooling fan connector.
  3. Install the power steering reservoir.
  4. Install the coolant bottle.
3.7L Engine To Remove:
NOTE: If the fan blade is bent, warped, cracked or damaged in any way, it must be replaced ONLY with a replacement fan blade. DO NOT attempt to repair a damaged fan blade.
NOTE: For 3.7L Heavy Duty/Max Cool/Trailer Tow cooling package, the viscous fan cannot be removed separate from the shroud. Both fan and shroud must be removed together.
  1. Disconnect battery negative cable.
  2. Using special tool #6958 spanner wrench and #8346 adapters, remove the viscous fan from the water pump.
  3. Gently lay fan into shroud.
  4. Disconnect the electrical connector for the electric fan, then disconnect connector from shroud.
  5. Remove the two fan shroud mounting bolts connecting the fan shroud to the radiator.
  6. Remove the shroud and fan from the vehicle.
To Install:
  1. Install fan shroud assembly into the vehicle. Tighten fan shroud to radiator bolts to 50 in-lb (5.5 Nm).
  2. Install shroud mounting bolts tighten bolts to 89 in-lb (10 Nm).
  3. Connect fan motor wire connector to harness connector, and attach connector to shroud.
  4. Connect negative battery cable.
  5. Start engine and check fan operation.
Aug 31, 2010 | 2005 Jeep Liberty
How do I remove the cooling fan shroud from the top of the radiator ? I'm trying to change the cooling fan motor, and I've removed the bolt holding the fan shroud to the radiator, but I can't get the...
I would suggest replacing the cooling fan relay in the fuse compartment under the hood first. Cooling fan motors very, very rarely go bad. You will probably end up having to remove the radiator to remove the shroud. You will save yourself a lot of time and money if you replace the relay first.
Jul 07, 2010 | 1996 Chevrolet Cavalier
I need to reconnect my radiator in my 2000 ls v8
For 2000 Lincoln LS 3.9L SFI DOHC 8cyl...
Radiator - Removal & Installation
  1. Drain the engine cooling system.
  2. Remove the upper radiator sight shield.
  3. Remove the air cleaner outlet tube.
  4. Remove the six bolts and the two radiator upper support brackets.
  5. Remove the upper radiator hose.
  6. Remove the bolt and position the receiver drier aside.
  7. Disconnect the dual flow coolant valve electrical connector and the A/C line from the fan shroud.
  8. 3.0L engines only:
    Disconnect the Throttle Position (TP) sensor and the Idle Air Control (IAC) valve electrical connectors.
  9. Remove the bolts.
  10. Remove the bracket.
  11. 3.9L engines only:
    Remove the bolt and position the electric water pump aside.
  12. Disconnect the high pressure cooling fan bracket and line.
  13. Inspect the seal and install a new seal if necessary.
  14. Disconnect the return hose from the cooling fan and shroud.
  15. Separate the return hose from the fan shroud and position aside.
  16. Remove the two bolts and the fan shroud assembly.
  17. Remove the A/C condenser.
  18. Remove the two bolts and position the multi-cooler assembly aside.
  19. Remove the bolts and the condenser support brackets.
  20. Remove the radiator.
To install:
  1. Install the following:
    Radiator Condenser support brackets Multi-cooler assembly A/C condenser Fan shroud assembly
  2. Connect the return hose to the fan shroud
  3. Connect the high pressure cooling fan bracket and line.
  4. 3.9L engines only:
    Replace the bolt and position the electric water pump aside.
  5. 3.0L engines only:
    Connect the Throttle Position (TP) sensor and the Idle Air Control (IAC) valve electrical connectors.
  6. Replace the following
    The upper radiator sight shield. The air cleaner outlet tube. The six bolts and the two radiator upper support brackets. The upper radiator hose. The bolt and position the receiver drier aside.
Hope help with this (remember rated and comment this).
Mar 17, 2010 | 2000 Lincoln LS
Want to replace the radiator on my 1997 ford thunderbird
Radiator Aluminum Core, Crossflow — 3.8L (Base) and 4.6L Engines
Removal
  1. Drain engine cooling system as described. Disconnect upper radiator hose (8260) and lower radiator hose (8286) and radiator overflow hose (8075) from the radiator (8005). Disconnect the transmission oil cooler inlet and outlet lines from the radiator.
  1. Remove cooling fan motor,fan blade (8600) and fan shroud (8146) assembly as described.
  1. Remove radiator upper bracket retaining bolts and remove bracket. Lift radiator from vehicle.
Installation
  1. Position the radiator into the vehicle. Install upper brackets and tighten bolts securely.
  1. Connect the transmission oil cooler lines to the transmission oil cooler fittings.
  1. Install cooling fan motor, fan blade and fan shroud assembly as described.
Engine Cooling Fan Motor, Fan Blade and Fan Shroud Assembly, Electrical Removal
  1. Disconnect (pull apart) the male-female cooling fan motor wiring connector at the side of the fan shroud (8146). Remove the male terminal connector retaining clip from the fan shroud mounting tab.
  1. Remove two fan shroud upper retaining bolts at the radiator tanks.
  1. Lift cooling fan motor/fan blade (8600)/fan shroud assembly past radiator (8005), disengaging fan shroud from two lower retaining clips.
Installation
  1. Follow removal procedure in reverse order.
  1. Tighten fan shroud retaining bolts to 5.2-7.2 Nm (46-63 lb-in).
    8d231fe.gif HOPE THIS HELPS.
    Oct 30, 2009 | 1997 Ford Thunderbird LX
    Replace the radiator
    Removal and Installation
    On all engines
    1. Drain the engine cooling system. For additional information, refer to Cooling System Draining, Filling And Bleeding in this section.
    1. Remove the upper radiator sight shield.
    1. Remove the air cleaner outlet tube. For additional information, refer to Section 303-12 .
    1. Remove the six bolts and the two radiator upper support brackets.
    1. NOTE: 3.9L shown; 3.0L similar.
    1. Remove the bolt and position the receiver drier aside.
    1. Disconnect the dual flow coolant valve electrical connector and the A/C line from the fan shroud.
    On 3.0L engines
    1. Disconnect the throttle position (TP) sensor and the idle air control (IAC) valve electrical connectors.
    1. Remove the bracket.
      1. Remove the bolts.
      1. Disconnect the high pressure cooling fan bracket and line.
      1. Using the appropriate special tool, install a new O-ring on the power steering pressure hose fitting.
      1. Separate the return hose from the fan shroud and position aside.
      1. Remove the two bolts and position the fan shroud assembly.
      1. Disconnect the return hose from the cooling fan and shroud and remove the cooling fan and shroud assembly.
      1. Remove the A/C condenser. For additional information, refer to Section 412-03 .
      1. Disconnect the lower radiator hose.
      1. Remove the two bolts and position the multi-cooler assembly aside.
      1. Remove the bolts and the condenser support brackets.
      1. Remove the radiator.
    Apr 29, 2009 | 2002 Lincoln LS
    Code 1481
    SOMETIMES THE WIRING HARNESS GET DAMAGED WHEN FAN REMOVED. GM HAS BULLETIN TO REPLACE COOLING FAN WIRING HARNESS PART# 89024920
    Harness Assembly, Engine Cooling Fan Wiring
    1. Place the cooling fan assembly on a bench.
    2. Disconnect the harness electrical connector from the cooling fan clutch.
    3. Remove the harness from the plastic guide while feeding the wires out of the slot.
    4. Before installing the new harness, wrap the affected area on the wires with electrical tape to keep the protective sleeve in place. Be sure to keep the tape approximately 25 mm (1 in) away from the connector so the wires can be fed into the slot.
    5. Feed the wires into the slot and install the harness to the plastic guide.
    6. Connect the harness electrical connector to the cooling fan clutch.
    7. Install the cooling fan. Refer to the Cooling Fan and Shroud Replacement procedure in the Engine Cooling sub-section of SI.
    Nov 25, 2008 | 2003 Chevrolet TrailBlazer
    Gateway 550GR PC Desktop Logo
    75 people viewed this question
    Top Gateway Computers & Internet Experts
    Prashant M
    Prashant M
    Matthew Spark
    Matthew Spark
    Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
