Question about Samsung SGH-E900 Cellular Phone
Samsung Slider problems :(
I was riding my bike and i dropped my phone, the battery fell out and when i replaced the battery and powered up my phone the screen was blank white. I can still call and text, I just cant see anything. Do you know of anything I could do to fix this?? Any advice is greatly appreciated
  • Anonymous May 17, 2008
    Acontece que o meu monitor do telemovel come├žou por ficar aos riscos depois deixava-se de ver, passado pouco tempo ja estava bem, agora a tele fica em branco nem consigo ver absulutamente nada mas ele funciona o telefone em si. Como resolver este problema? isto acontecia quando deslizava para consultar algo
Buy a new lcd
Posted on Apr 24, 2008
Phone died, now won't power up
the chip inside has fell out. if its a few weeks old then it should be still coverd for a repair, dont say you dropped it.
Nov 07, 2013 | Samsung Galaxy Admire 4G MetroPCS
Tip
Samsung phones
Hello there Samsung slider phones LCD or screen problem. Always you have seen that samsung phone get problem like some phone doesnt have light in LCD and some times they does not turn on. Samsung slider phones like G 600 , U 600 . J 700, E250 ,D800 and D900.Slider phones always has Ribben ( slidr belt ). And this ribben always connect phone upper part ( screen ) to the mother board.when the ribben (slider belt) got damage then it gives you that problem.it happens when you use your phone roughly or when you dropped your phone on concrete or any different floor.Mostly Samsung phone model U600 , G600 AND J700 has this problem.whenever your phone gets this problem firstly check. And Do not try any flashing or any kind of software tools. it easy to change ribben (slider belt ). Just get ribben belt or some tiny screw driver and some slider opener. this tools are easy to get from any tools shop. then mostly phone has screw. firstly open the battery cover and take it out and see two hole under the battery and when you slide up your phone then you can see two screw just under your phone top keypad just hold the slider for while and open those screw and slide up then see two rubber things are both side on camera. Use any flicker type things and take out that rubber top then you can see two screw just under the screw open those screw then use the slider opener if the opener is tight if slider is loose the do not use opener just take it out so softly and remove the one side of the ribben which you can see connected of mother board just take out ribben and put new one ribben the put all things back as a normal then tight the screws and put battery then turn it on your phone will turn on.some phone like U600 ,j600,has touch panel. this type of model slider belt or ribben always comes with touch panel and its quite difficult and quite expensive to change.Samsung U600 has this problem mostly because they are very thin and then slider belt is as well thin and they get this problem so quickly.
thanks
on Jan 08, 2010 | Cell Phones
My samsung impression slider is falling apart, springs falling out and small black rectangular thing-y covering the upper left corner of my keyboard. i do not drop my phone, no water damage, it is in a...
I've seen it in this phone before too. And if you don't fix it soon other parts will start breaking like the flex cable. If you managed to keep everything that fell off, the good news is you can fix it yourself if you are mechanically inclined. The springs just snap in once you get the phone apart. If that doesn't appeal to you, there are some sites you can send it in to for repair, and there are sites like ours where you can trade it in for another phone.
www.usedcellphoneshop.com
May 08, 2010 | Samsung SGH-A877 Impression Cell Phone
Inside of LG Rumor screen is cracked!!
You need a new screen
cnn.cn
They might have it here. give it a try since youve voided your warrently by dropping it unless if youve purchased additional warrenty
Aug 07, 2009 | LG RUMOR Cellular Phone
Samsung S85 problem
I have had similar symptoms that seem to be due to battery power.
Using and OHM meter I find that the Samsung S85 eats batteries. If the charge drops to 1.4 something volts from a 1.5+ volt battery, the camera does not function properly.
The camera is nice an compact ... but I need to carry the same volume in batteries to make sure I can use it.
Jun 17, 2009 | Samsung S850 Digital Camera
A morbike i am buying has been dropped before, what are some cons about buying a bike that has been dropped before?
the frame could be out of line, it all depends on when you say dropped, as in fell over or crashed, but even falling over could damage the frame, depending if it fell awkwardly. i dropped my ninja 600 but it only broke the turn signal lens. so it's difficult to say and see. make sure you ride it before you buy and see if you are happy with how it rides
Apr 19, 2009 | 2005 Honda CBR 125 R
New Slider Does Not Work - key lock too!
I Would send the phone back, you could be damaging it even more.
Sep 21, 2008 | Samsung SGH-D600 Cellular Phone
U600 dropped and in half :S
Simple . . . buy a new phone.
Jul 02, 2008 | Samsung SGH-U600
D807 off track
okay just take the phone to a mobile service center and have them fix the slider back onto the phones for you or a mobile technican.
Dec 19, 2007 | Samsung SGH-d807 Cellular Phone
Samsung SGH-E900 Cellular Phone Logo
461 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
