Question about HP Compaq dc5700 Microtower - Free Flat Panel until 113007 EW287AV-KIM PC Desktop
How do i scan onto the computer from hp photosmart c4380 . i am using vista
    Genius:
  • 1,121 Answers
Cannot find the driver for my wireless hp c4380 photosmart printer. cannot scan..frustarated
See my published guide entitled How to Install the latest drivers for Hewlett Packard Printer!!!
They may have the drivers for your printer.
Although if I am not mistaken if you disconnect your printer from the computer and the printer is on you should be able to scan documents and print them. All without the need for a computer.
That would be to copy a document.
On the other hard maybe you want to scan to a file onto your computer, yes I think that is what you want to do. Yes you are quite correct, you will need to install the drivers for the printer.
Try and use the USB connection if you are having problem with wireless, it some-times gives problems.
Take care!
damnor01
Apr 20, 2011 | HP Photosmart C3180 All-In-One InkJet...
HP Photosmart C4180 scanner
Unfortunately Vista has problems with many printers. (Or maybe I should say many printers have trouble with Vista.)
HP has a work around that allows you to scan without using the Scan button. Go to:
C4180 Scan Work Around
They give you 2 options to scan using programs on your system
Thanks for using Fixya.
Wayne
Aug 28, 2009 | HP PhotoSmart C4180 All-in-One Color...
Hp solution center 70.0.128.000
welcome to vista some printer software does not work on vista if you are running the 64 bit copy i suguest that you format and burn the copy as most software will not work on it without all new drivers that you must buy from the vendor hope i helped
Jul 04, 2009 | HP Photosmart C3180 All-In-One InkJet...
Can't scan on HP Photosmart C4380 even tho printing works fine
Try scanning without HP imaging software
HP Photosmart C4380 Direct Scan button doesnt function in VISTA
Use the built-in feature of the Windows operating system, called Windows Image Acquisition (WIA), instead of the HP software to scan. Follow these steps to perform a WIA scan.
  1. Make sure that the product is on and that the cable is correctly connected.
  2. Click Start , and then click Control Panel .
  3. Click Printers and Other hardware , and then click Scanners and Cameras .
  4. Look for an icon representing the product, and then review the following information for further instructions:
  5. Double-click the icon to start the Scanner and Camera Wizard . Follow the on-screen instructions to scan images or documents to the computer
  6. If the WIA scan was successful , use the Scanner and Camera Wizard to scan instead of the HP software. To use the HP software, continue to the next step to continue troubleshooting. However, it is not necessary to do so.
  7. If the WIA scan was unsuccessful , continue to the next solution.
  8. Fully uninstall and reinstall the HP software Follow these steps to completely uninstall and then reinstall the HP software. Step one: Uninstall the software Use one of the following methods to uninstall the software. Method one: Uninstall the software using the product CD If the product software CD is available, follow these steps to uninstall the software. Otherwise, skip to the next method.
    1. Insert the software CD into the CD-ROM drive on the computer.
    2. If the Welcome installation screen appears, click Exit to close it.
    3. On the Windows task bar, click Start , and then click Run (c01463550.gif ). The Run dialog box appears. Figure 4: The Run dialog box c01463551.gif
    4. Click Browse . The Browse window appears.
    5. Navigate to the CD-ROM drive that the software CD is in, and then double-click the drive.
    6. From the list of folders and files on the CD, double-click the Util folder.
    7. From the list of folders and files inside the Util folder, double-click the CCC folder.
    8. From the list of folders and files inside the CCC folder, double-click the Uninstall_L3.bat file or Uninstall_L3_64.bat if a 64-bit operating system is installed on the computer. The Browse dialog box closes, and the path to the Uninstall _L3.bat file appears in the Run dialog box. Figure 5: Uninstall file path in the Run dialog box c01463552.gif
    9. Click OK . The software uninstaller opens in a command prompt window.
    10. Press Enter to begin the uninstall.
    Method two: Download and uninstall the software If the software CD is not available, follow these steps to download the software and then uninstall it.
    1. Click here to go to the Software & Driver download page on the HP Web site .
    2. Type the product number in the search field, and then click Submit (c01425574.gif ).
    3. If necessary, click the link for the product model number.
    4. Click the correct operating system.
    5. In the Driver section, click HP Full Feature software/driver , and then click Download only .
    6. When the File Download - Security Warning dialog box appears, click Save .
    7. Save the file in a location that is easy to remember.
    8. When the file finishes downloading, double-click the file to extract it.
    9. Click Exit on the Welcome installation screen.
    10. On the Windows task bar, click Start , and then click Search (c01463553.gif ). The Search Results window appears.
    11. In the Search Results window, click All files and folders .
    12. Click More advanced options , and then select Search hidden files and folders .
    13. In the All or part of the file name: box, type Uninstall_L3 , and then click Search . When the search is complete, the file appears in the Search Results window.
    14. Double-click the Uninstall_L3 file, and then follow the on-screen instructions to complete the uninstall.
Oct 25, 2008 | HP Photosmart C3180 All-In-One InkJet...
I have just bought a hp photosmart c4380 i want to know how to put the cartridges in
You can see how on the following web page:
photosmart c4380
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Aug 14, 2008 | HP Office Equipment & Supplies
Can my HP Photosmart C4380 support Microsoft Office Professional 2007 Fax and Scan? Or must the HP fax and scan only be used?
Sorry, Fax and Scan is part of Windows Vista not MS Office. I have been advised by PC World team that this printer (HP Photosmart C4380) does not have the necessary drivers to support Vista Fax and Scan wirelessly and can only operate with the HP Fax and Scan which is very basic and only seems to function via USB cable, not wirelessly. Update drivers may become available.
Jul 04, 2008 | HP Office Equipment & Supplies
Hp photosmart c4380
well..you'll need a different set of drivers for vista
get them here(make sure to choose vista for operating system)
Mar 23, 2008 | Office Equipment & Supplies
HP Compaq dc5700 Microtower - Free Flat Panel until 113007 EW287AV-KIM PC Desktop Logo
63 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
