Question about Hitachi Electronics - Others
How do I interupt drive power on a J100-A IGBT
How do I interupt drive power on a J100-A IGBT inverter drive? Is it as easy as interupting the command signal from the control?
  • 760 Answers
That is not a very clear question. When you say interupt drive power,d o you just want to stop the drive? or do you want to render it safe to work on. To stop the drive removing the drive command signal is fine. or look at the wiring diagram and connect some type of stop button. The drive will stop in whatever mode you programmed it for (coast, braking etc) To render it safe for somone to work on it would require a lockable disconnect switch that can be locked in the open position with a padlock (standard fusable or nonfusable disconnect) If you don't have your manual, you can download one here: http://www.inverter.co.uk/applications/hitachi.htm
Posted on Jul 12, 2010
Power interuption to house temp. power came back but tv won't
The real question if model number indicated here is correct is does the green power light on the set come on at all ?
Aug 29, 2012 | Mitsubishi WS-65513 65" Rear Projection...
ERROR CODE H2,HOW TO RESET IT/TO CLEAR
Press Keys : # interupt C interupt....................... then machine will be powered off then press Keys: 1 4 Copy then H2 will be removed. By rehanjoiya74@yahoo.com
Mar 07, 2011 | Sharp AR-5320 Black and White Copier
How do i enter the maintainance codes on the sharp 208d keypad
try c interupt o interupt or # c interupt one of those combinations
Mar 24, 2010 | Sharp Office Equipment & Supplies
Firmware update interupted, server out
If you have jumpered for BIOS recover it should be able to boot from floppy. I think you will have to install a floppy drive, boot from floppy. Jump the MB for BMC update (if ness) and flash the BIOS and BMC that way.
Jan 16, 2010 | IBM x3400 Server
The installation keeps getting interupted because something is not configured correctly. I have tried install from hard drive and same thing happens
try to uninstall or clean all interupted installation of Print shop 23 deluxe by using perfect uninstaller.Then install it again after reboot.
Nov 04, 2009 | Broderbund The Print Shop 23 Deluxe
ERROR H5-01
H5-01 means that you have 5 continous paper jamm in the machine. Try to rest by pressing C INTERUPT 0 INTERUPT 14 START.
If problem still occur, check the paper detection sensor by pressing C INTERUPT 0 INTERUPT 30 START 1 START. and manually activate the sensors and look at the display.
May 27, 2009 | Sharp SF 2540 Copier
Washer interupted while running
Try pressing "end of cycle". Then restart your normal wash.
If helped pl rate me................................
Jan 23, 2008 | Whirlpool GHW9100L Front Load Washer
Electronics - Others Logo
396 people viewed this question
Top Hitachi Electronics - Others Experts
Are you a Hitachi Electronics - Other Expert? Answer questions, earn points and help others
