Question about Frigidaire Electric Dryer
Makes a thumping noise when drum goes around, kinda like there was a sneaker in there. how do I open it up to check what the problem? Maybe belt starting to go bad?
  • Frigidaire Master
  • 43,501 Answers
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryermakes a thumping noise when drum goes around, - 2_bing.gif Repair Squeaks, Grinding, Clicking and Knocking Noise
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Posted on Jul 12, 2010
    President:
  • 1,430 Answers
This is usuallay a roller. Here is a link that should be pretty close to your machine. http://appliancehelponline.com/dryerrollers.html
Has a thump thump noise as the drum goes around, no problem drying, just thumps.
The belt might be about to break. Check that. Sometimes it may split and still operate but the dangling piece of belt will hit something inside an make the noise.
Sep 15, 2015 | Dryers
My Kenmore Dryer is making a squeeling noise every time i turn it on. I opened it up and the Belt seems to be fine, just wonder is there anything i can do to make it stop. Maybe spray some DW-40 on the...
Hi macgyver0221...
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers are in need of lubrication.
Open your machine again and be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots they will make a thumping type of noise or if there is too much wear on them replace them.
If the drum rollers don't have flat spots or wear on them and are only squeeling then they probably only need lubrication.
Remove and clean the rollers and shafts, they may have hair,dust,etc. wrapped around the shaft.
Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil and or a light lubricant like Vaseline.
Reassemble the dryer.
Plug back into your electrical receptical.
This should solve your noise problem.
This is a FREE answer, Please take time to rate me
Jul 25, 2011 | Dryers
The dryer was making shrill noises for some time, then a thump noise, now the drum wont turn. I think it is the belt, but the belt is still intact... Where on the drum does the belt go? and what else might...
The belt may have jumped off the tension pulley. Check to make sure the belt is tight around the drum and all pulleys, then check whether all pulleys and rollers turn freely.
Jun 30, 2011 | Dryers
Dryer makes banging sound as drum rotates
The drum rollers are worn out and wobble when moving..it should be more of a thump/thump sound, unless really are almost gone...UNPLUG dryer and raise top...Since no model. i'm going with standard kenmore/whirlpool dryer type. The top has two screws by lint filter..Remove these and raise top...The front can be removed by removing two screws inside each front corner. The door switch must be disconnected at wiring..Remove front and set aside...The drum can be removed after the belt comes off...look down in right rear corner under drum..you will see the belt pulley and you want to see how it goes around pulley to help reinstall..remove belt, there will be tension and make sure you draw yourself a diagram of path of belt to ease install of belt....now once belt is removed, you can pull out drum...there are two drum rollers. They are bad if you roll them and they wobble and make noise. They should be almost quiet when you roll them if they are good..the belt roller can be bad and squeek...check this as well...replace parts and reinstall
Jan 31, 2011 | Dryers
The dryer is making a thump/thud noise as the drum turns. The dryer works fine but the noise sounds like something hitting everytime the drum goes around. Could this be the belt going out?
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker
Jan 02, 2011 | Kenmore 83142 Electric Dryer
Kenmore electric dryer making loud noise when running
It sounds like the belt that goes around the drum. I have a similar Kenmore, and I get that same rotational thumping noise. The belt is probably about to break or come apart. If you take it off and run it trough your hands, I think that you'll find either belt separation, or a bad spot missing a chunk.
Fortunately the belt is a cheap item. I've kept my Kenmore dryer running over 20 years now.
Mar 18, 2017 | Kenmore Dryers
Unexplained dryer noise
I have this same problem, how do I get to the belt to check it out?
Mar 21, 2010 | Amana NED7200TW Electric Dryer
Electric Dryer Thumps
that gap in the drum is most likly hitting a roller in the back of dryer so my best guess is replace drum if you feel it's not that change the felt around door thank you for useing fixya rate me
Apr 01, 2009 | Dryers
Frigidaire  Electric Dryer Logo
348 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
