Question about Belkin Computers & Internet
How can i get my belkin router to come up on my browswer. I want to fix my ps3 since i need upnp - dmz -and nat 2 to be configured, i need to have my router to allow my ps3 to work properly so it can get online work so i can chat on the games etc.
  • wm86more Jul 12, 2010
    like to add ,that belkin - ip address wont show up on my browser? i cant seem to go into belkin configurations ? I just bought the belkin 1 month ago. any help will be appreciated since i cant get belkin to show up on my computer ?
    Sniper:
  • 72 Answers
Hey,
On the computer where you would want to access router do the below.
1. click start and select run
2. On the run window type cmd and click ok
3. A black window should come up. On that window type ipconfig and hit enter
4. Look for the Gateway address.
5. type the gateway address in your browser address bar, and hit enter. You would be prompted for a username and password.
6. type the admin username and password and you are all set to go.
Posted on Jul 12, 2010
  • Xavier Dsouza Jul 12, 2010
    Most belkin routers don't have a password. Try leaving the field blank, with the username as "admin" and try again. If that doesn't work, look for a reset switch on the router, press and hold the switch for 30 to 40 seconds, this would reset the router settings to default. it'll work.
I am trying to games on PS3 and cannot connect with friends. I believe this is because I have NAT Type 3 (closed) and I would like to change it to NAT Type 2 (moderate) but I do not know how.
Hi ..
The PS3 has 3 different NAT types. They are shown below.
Type 1: The PS3 is connected to the Internet without a firewall or router. No NAT issues.Type 2: The PS3 is connected to the Internet through a router which is configured correctly. No NAT issues.Type 3: The PS3 is connected to the Internet through a router that needs configuring.Ideally, you want to have a Type 2 NAT. However, a Type 1 NAT does not affect your game play.
First of all you will have to Disable the firewall in the Router / Modem
If you are using a Router ..
Then
Make sure that UPnP(Universal Plug n Play) is enabled
Enable the IP Address of the PS3 in DMZ
Or Forward the ports
Below are the TCP and UDP ports that need to be forwarded:
TCP: 80, 443, 5223
UDP: 5223, 3478, 3479, 3658
For more details on port forwarding , log on to http://portforward.com/english/routers/port_forwarding/routerindex.htm
Hope it helps
Regards
Tom
Aug 18, 2011 | Computers & Internet
How do i change my nat from type 3 to type 2 with the belkin n600 hd router for ps3
PS3 And XBOX :: BELKIN
Step 1:Connect Modem - Router - Computer (Wired)
Step 2:Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3:On the Left click firewall
Step 4:Leave the Password blank and click submit
Step 5:Disable it and click apply changes
Step 6:Scan and connect in the Xbox/PS3/Wii
Step 7: Get the IP Address of the Xbox/PS3/Wii
Step 8:Open Router Setup in the Computer
Step 9:On the left under Firewall Click DMZ
Step 10:Enable the IP Address of the Xbox/PS3/Wii in it
Step 11:Click Apply Changes
Step 13:On the left Under Utilities click System settings
Step 14:Scroll down to the bottom
Step 15:Enable UPnP
Step 16:Click apply changes
Step 17:Test the connection ,Check the NAT
If working then let me know
If it is still not working
Open Router setup
At the middle Under internet settings check the WAN IP
IF it starts with 192.168. or 172.16 Then you will have to contact your internet service and ask them to bridge the modem
Regards
TOM
Jan 11, 2011 | Belkin Play N600 HD Wireless Dual Band...
Where is your NAT configuration to open and close it for this router? I've watched YOUTUBE videos on where to find the NAT section and I don't have one. Help me I just want my PS3 to have a type 2 NAT so...
Belkin uses the term "Port Forwarding" in the "Firewall" section of the configuration web pages instead of the term "NAT".
For each port that you need to forward to the PS3, create a separate entry in the "Virtual Servers" section.
If that's too much work, then determine the private IP address of your PS3 and add that address to the DMZ for your router. The DMZ settings area is also in the "Firewall" section of your router configuration web pages.
For more information, go to the Belkin support web site and select "G" for "1" and "F5D9231-4" for "2" and the select either V2000 or V1000 depending of your router version (see the bottom of the router) and download the user manual.
While you are there, check whether there is a firmware update for the router available.
Dec 30, 2010 | Belkin F5D9231-4 Router
Hi there! i have a zyxel ph660-f1z and since it doesnt suport dmz i get nat type moderate on my ps3 so it gives a lot of trouble.... i have tried port fordwarding,upnp,default server but nothing seems to...
Sometimes not just the dmz or port configurations cause your nat settings to be other than open, you may not have good internet connection, the better it is the more you will open. Most routers are open by default, and those others need to be forwarded(like you wrote) with the upnp open and specific ports for xbox/ps3 servers opened. You seem to know a little already, maybe time to get a new router?,I recently upgraded myself due to problems with configuration.
Dec 15, 2010 | Zyxel P660HW-D1 Router
Hello FixYa, i've tried to open my nat for Xbox LIVE, by Port Forwarding, DMZ, UPNP, enabling NAT, what can i do to finally fix this problem?, this has been going on for 2 and a half years now.
Step 15:Enable UPnP
Goto : my blog for more information about belkin routers (Page is still under construction )
Open Router setup
Aug 14, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Opening NAT with belkin wireless router xbox360
Step 15:Enable UPnP
Open Router setup
Jul 29, 2010 | Zyxel P660HW-D1 Router
Change nat type
To reduce the NAT
1 ) Disable the firewall in the router
2) Enable the Playstation in the DMZ
3) Make sure UPnP is Enabled
Mar 31, 2010 | Arris WR850G Router (DHWR850G)
Nat problems cant change my nat 3 to nat 2 or 1 on my ps3 1 tried everything i have siemens speedstream 6520 router
To reduce the NAT
Feb 15, 2010 | Sony Playstation 3 (PS3) Console
Getting PS3 NAT Type 2 with Netopia Router ???
I have nat type 1 with this router but no upnp. access your router. click on advanced setup, click on configure, click on connection, choose ppp over ethernet llc/snap scroll down and click on save and restart connection. call your internet provider and get the username and password for your router. you will need it later. on your ps3, go to network settings, select internet connection settings. the ps3 will ask if you want to continue, select yes.select custom, wired connection, auto detect, PPPoE, enter the username and password you got from your isp, select automatic, automatic, do not use, enable, then press the x button to save, press the x button again to test connection
May 05, 2009 | Netopia (3347NWG-VGX) Wireless Router...
Playstation 3 networking problem with belkin n1 router
To REDUCE NAT ON PS3 /Xbox
Step 6:Scan and connect in the PS3/Xbox
Step 7: Get the IP Address of the PS3/Xbox
Step 10:Enable the IP Address of the PS3/Xbox in it
Step 15:Enable UPnP
Open Router setup
Jan 05, 2009 | Belkin (F5D8231-4) Wireless Router...
Computers & Internet Logo
209 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
jason
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
