Question about Philips AZ1560 Cassette/CD Boombox
My CD player is broken. Where can I get this part?
My CD player is broken on my Phillips AZ 1560 Cassette/CD Boombox. Where can I get this part?
SOURCE: CD Player stops in middle of songs
sounds like the stop button is getting a crossover signal
the CD player ALWAYS has vibration... (impossible to make a perfect balanced spinning mechanism...) and this could allow a slight vibration to affect the machine... age making it more prominent and thus the delay in occurance
but more likely the Capacitor has gone bad (13 years is a very good life for the small charge holders) allowing the voltage to go where it isn't supposed to go
assuming you are a DIY guy then trace the path for the stop button and check the capacitors and resistors in the area
usually a connection is make or break but it could have a signal pull resistor with a capacitor to stop direct current.. if so, that is the first capacitor to check... also good news in this case... the capacitor that fits with a pull up/down switch isn't very critical in it's specs so a close match should be fine
Posted on Feb 25, 2008
SOURCE: How to preset a radio station on Sony CFD-S200 Cassette/CD boombox
You will need to use the Forward and Reverse buttons on the CD player. Set the station by holding the button you want to set it to until it blinks and shows the station number.
To set more that 10 stations. Press the (>10) button and then enter 11 or 12 or so on and set the stations the same as above.
Posted on Jun 12, 2008
simplemitch
  • 752 Answers
SOURCE: CD player on boombox
The laser is dead or damaged. Try swabbing the laser with rubbing alcohol on a Q-Tip, then IMMEDIATELY blowing dry with canned air. If this fails, the laser is dead. If it is a Sony KSS-2xx series laser (try to peek in the laser slot to see the decal on it) you can get replacements online. If not, it's junk.
Posted on Aug 04, 2008
SOURCE: Product purshase
I have one I'm selling. I live in San Diego, Ca
Posted on Mar 30, 2009
Samyfam
  • 379 Answers
SOURCE: The rubber band driving the Phillips AZ1505
Keep the old belt - measure it's unstretched length so you can calculate it's diameter (most belts are sold by diameter). Diameter = length divided by Pi (3.142).
Maplin shops and mail order carry a few = www.maplin.co.uk
eBay lists quite a few.
Otherwise, a company called GB Audio have a very good range - bit pricey though = www.gbaudio.co.uk
Try Googling for other companies.
Posted on Oct 24, 2009
Rewind button on Coby broken - how to replace
nesecito el picki-up laser lens para un boombox coby modelo mpcd 450blk hern7869@gmail.com
May 22, 2012 | COBY-PERSONAL & PORTABLE Coby Mpcd450...
I KEEP GETTING AN ERROR WHEN I HAVE A CD IN MY PHILLIPS BOOMBOX. the radio works fine but the cd won't start. It looks like it will, the cd moves but then it stops and gives an error
hi
you need to clean the head (eye) of the laser reader
(small glass that moves fromo center - out)
with some alcohol if you have any or better
with isopropil alcohol
Jan 14, 2011 | Philips AZ1145 Cassette/CD Boombox
I'm a dodo, don't know how to use a CD player. Uhg.
maybe there is a switch in the which you can set whether you want to use radio, cassette, or cd
May 05, 2010 | Sony CD Radio Cassette Boombox, CFD-E90...
How to record a cassette from cd on a sony xplod boombox cfd-g505
Insert a tape.
Select the program source you want to listen/record (CD).
Insert a cd, press stop.
Press record on the tape player.
Press play on the CD player.
The volume control or any audio emphasis buttons will not affect the record level.
http://esupport.sony.com/US/perl/model-documents.pl?mdl=CFDG505
Mar 17, 2010 | Sony CFDG505BLACK Xplod CD Radio Cassette...
The rubber band driving the Phillips AZ1505 cassette player has broken - where can I get a replacement from?
Oct 24, 2009 | Philips AZ1505 Cassette/CD Boombox
My philips az 1040 has no sound , how solve this problem?
Maybe the audio amplifier IC are fried and need to be replaced
Jun 30, 2009 | Philips AZ1040 Cassette/CD Boombox
Jul 30, 2008 | Jeep JXBLK Cassette/CD Boombox
Az 1574 Philips radio
Unplug the unit and take out any batteries ( power down the unit completely), Let the unit dry out for a few days or dry with a hair dryer ( low heat ). If the unit still dosn't work I would assume water has damaged the main board ( process board etc. ). If that is infact the sitution, chances are the unit is not worth fixing. Sorry for the bad news. I hope it works out for you.
Ed
NC Electronics
Mills, Wyoming
Jan 06, 2008 | Philips AZ1574 Cassette/CD Boombox
Cassette player eating!
Durabrand is one of walmarts cheap electronics brands.. This boombox probably only costs $15-$20 off the shelf. Id just junk it.
May 07, 2007 | Durabrand CD Player with Cassette...
Philips AZ1560 Cassette/CD Boombox Logo
41 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
