Question about Poulan "Poulan" Push Mower
The engine is not started
I was lawn mowing and that time the lawn mower hit with a small rock and the engine suddenly stops. After that I cannot start my engine. Can you please tell what should I do now? How can I start the engine? Please give me some guidelines.
Thanks.
  • 755 Answers
Can you still use the pull starter or is acting like its stuck?
If the motor is still turning but not starting and the rock incident was time it did run you most likely have sheared your engines flywheel key. This shearing protects the engine from damage when it stops suddenly. Unfortunately it will need to be replaced and that will take someone with working knowledge of engine repair.
Posted on Jul 22, 2010
  • 43,501 Answers
Hi.
Check the blade... it is bent and causes a vibration. if it is not the blade then the motor shaft is bent and that is terminal...if that happened then the mower is junk...
heatman101
Posted on Jul 12, 2010
While mowing with a brand new craftsman riding mower it sounded like it hit maybe a small rock and quit running. When you go to restart it just has a clicking sound
That sounds like a flat battery, faulty starter solenoid or starter. Hitting a rock would be coincidental to bad starting unless the stone kicked up and damaged a cable, but that should be impossible.
Dec 21, 2016 | Craftsman Garden
Why when I couldn't start my toro 6.5 gts lawn mower with tecumsuh engine,I sprayed carb cleaner into carb and it started but smoked and knocked. what caused this problem?
bob if you spray carb cleaner in and it started that is a sign of not getting fuel. but if it is smoking and knocking you have a bad outlook for that engine. did you hit anything with the blades while mowing that caused it to stop suddenly? did you tip it on its side as the oil may have run in the carburetor. that can cause the smoking. does it have to much oil in it?
Apr 28, 2016 | Toro Garden
22hp.zero turn sometimes smokes then stops.
The smoke could be caused by blowby around the piston rings. Pour a small amount of transmission fluid in the spark plug hole and turn the engine over several times. Check the plug for fouling. Also check the coil wire for spark.
Apr 15, 2013 | Briggs & Stratton Lawn-Boy Insight Series...
Mower worked great then just stopped!
mine did this once i was mowing and hit something and it died and the problem was a key pin broke. if you take off the cover and under the pull cord there is a small key pin that slides down by the shaft
i hope this helps
Dec 18, 2012 | Briggs & Stratton Garden
I ran over a rock mowing the yard. the lawn mower sounds weird
when hitting things the blades get bent as well as the key on the flywheel meets the crankshaft throwing the timing off
Jul 16, 2012 | Garden
I have a 6.5 self propelled Lawnman by MTD . It will start but will not stay running.
is the handle hard to pull?or pull back at times?any way pull the flywheel off and check the key that aligns the crank and flywheel in time they shear when you hit rocks
May 08, 2012 | Mtd Yard - Man 160cc, 21" Self - Propelled...
I hit rocks with my lawn mower on accident, and now it will run for a few seconds and turn off
This happens often. Sometimes your mower will start and run again and sometimes it won't. When it doesn't run it's because your timing is off, caused by a dented or sheared key.
To replace remove top cover to engine, and any other side attachments, this should expose the flywheel. Remove the top bolt and look between flywheel and top of crankshaft, you will see a small square notch. This is where the shear key is placed. Remove the flywheel and replace the shear key. Replace all parts in reverse order and you should be mowing again. GOOD LUCK.
Aug 31, 2011 | Poulan "Poulan" Push Mower
My wife was mowing the lawn and she hit a rock. Since than the lawn mower does not start and when it tries to start a little smoke will come out of the carburator area. The mower is a Sears eager 1...
Unless the blade is belt-driven, like on riding mowers, then the blade is attached directly to the engine crankshaft. Hitting a rock with a mower like this is a very common problem. You probably have a bent crankshaft. In most cases this can be repaired, but may not be worth it, considering the age of the mower. But you should call a local small engine/mower repair shop to ask for an estimate. The repair is not something you would be able to do yourself.
Apr 30, 2010 | Craftsman Garden
Riding lawn mow
give as the model so we can help.
Apr 15, 2008 | Black & Decker 19" Electric Lawnhog...
Poulan "Poulan" Push Mower Logo
323 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
