Question about Uniden Cordless Phone
My granddaughter was playing with the phone(ugh) pressing buttons, now the phone doesn't work. When I pick up the handset, I get a dial tone, then when I start to dial a #, the dial tone just comes back. Just now (I'm at work), I tried to call my home phone, but the answering machine picked up right away, as if the telephone is engaged.
    Problem Solver:
  • 11 Answers
Unplug the the power ,,leave for 30 seconds should reset
Posted on Jul 12, 2010
  • carrollk Jul 12, 2010
    I'll give that a whirl - will let you know the outcome:) Thanks
Why has the phone reversed, dial tone works only when phone is hung up why?
If I understand you correctly, when you leave the handset in the cradle and press a line, you can hear the dial tone. But, if you lift the handset and then select a line you don't hear anything through the headset. If this is correct, I suspect the handset is damaged, the cord is damaged, or if you're lucky, the clips may not be plugged all the way in on both sides. If you have another phone that is the same, you can switch handsets to test this theory.
Oct 19, 2014 | NEC 22b Hf Aspirephone-bk Stock No....
No dial tone but dial tone on hands free
The battery in the handset may be faulty/flat. If it does not charge up then replace the battery.
Feb 06, 2012 | Lands Phones
ON PHONE KX-T7420 NEED TO CHANGE HANDSET RINGTONE . WE HAVE FOUR IN ONE OFFICE AND ALL SAQME RINGTONE.
The phone has 8 ring tones. From the idle phone, press PROGRAM and dial 99. Press the intercom or a CO line button TWICE and dial 2-8 on the keypad (1 is already default). When you're satisfied with the tone, press STORE. You have to do this for each line and the intercom you want to change and you need to do this at each phone. Pick up the handset and drop it back down to exit programming.
Carl
Aug 11, 2011 | Panasonic KX-T7420 Corded Phone
How do i call
Hello Tedelen,
Be sure to meet all the requirements of the phone to make calls and to be fully operational. These requirements can be found here (Requires Adobe Acrobat Reader).
To make a phone call follow these instructions:
Making calls with the Handset
1. Pick up the handset and the phone automatically selects the priority line. If the priority line is occupied, it selects an open line.
OR
Pick up the handset and press a LINE button to select a line.
2. Wait for a dial tone, then dial a phone number.
3. Hang up the handset when finished.
Making Calls with the Speakerphone
1. Press the SPEAKER button and the phone automatically selects the priority line. If the priority line is occupied, it selects an open line.
OR
Press a LINE button to select a line.
2. Wait for a dial tone then dial a phone number.
3. Press SPEAKER button when finished.
If you are having problems refer to the given link to the User Guide.
-bsalamakha
Jul 05, 2011 | RCA 25415RE3 Phone
I need to turn of fwd/dnd
Take the handset off the hook, then press the FWD/DND button followed by 0 (zero). When you hear the tone, hang the handset back up. This will work with the PT (Panasonic Proprietary telephone) system. (Alternatively, pick up the handset, press 7 (seven) 1 (one) 0 (zero) 0 (zero) and hang up after the tone. This works for PT and SLT phones (single line telephone))
The same sequence works to cancel call forwarding (except for follow me forwarding). In the Follow me mode, pick up the handset, press FWD/DND or 7 1 0 followed by 8 and the extension number. Then hang up after hearing the tone.
I hope this helps.
Sep 23, 2010 | Panasonic KX-T7130 Corded Phone
How do I program the phone to ring on an incoming call? The ringer is on.
The solution will depend on why the phone is not ringing. Do you have a good cable? (Can you get a dial tone and make outgoing phone calls?) If you don't have a dial tone, use another phone to check if the phone is the problem or if the jack is at fault.
Next is the phone forwarding calls or in the "do not disturb" mode.
If the problem is one of the above, which model of the Main Unit do you have, KX-TA624 or KX-TA1232?
If the unit is in the "do not disturb" mode, to cancel: pick up the handset, press Program then 0 followed by # with the TA624. For the other model, press Program followed by 0 . Then hang up the handset. For this the manual says press the FWD/DND button not the Program button. I'd check both.
To cancel Forwarding, except for Follow Me Forwarding, pick up the handset, press FWD/DND and then 0 and # (TA624) or 0 (TA1232) then hang up the handset. To cancel Follow Me Forwarding: pick up the handset, press FWD/DND then 8 followed by the extension number. Then press # for the TA624 and hang up; just hang up the handset for the TA-1232.
I hope this helps.
Sep 23, 2010 | Panasonic KX-T7730 Corded Phone
I need to know how to program the numbers into the speed dial option. My mother's phone is a table set with large numbers #29267A ... close enough?
Before you store a telephone number in memory, make sure the dialing mode is
correctly set for the type of service you have. The default dialing mode is tone
(touch-tone), so if you have pulse (rotary) service, you must first change the dialing
mode. See “To Set the Dial Mode.” The following buttons can be stored into any
memory location: 0-9.
STORING FREQUENTLY CALLED NUMBERS
1. Pick up the handset.
2.Press the store button.
3. Push the desired memory location button.
4. Press the store button.
5.Use the handset number keys to enter the telephone number (up to 16-digits)
and press the store button.
6.Hang up the handset.
NOTE: If you make a mistake, use the delete button to delete wrong digits.
CHANGING A STORED NUMBER
Repeat the storage sequence above. The new number replaces the old number at
the memory location.
ERASING A STORED NUMBER
3.Press the memory location (0-9) to be erased.
4.Press delete for three seconds until the number in the display is erased.
5.Hang up the handset.
DIALING FREQUENTLY CALLED NUMBERS
1. Pick up the handset and press the mem button.
2. Press 0-9 for the memory location. The number dials automatically.
OR
1. Pick up the handset and press the dial button.
2. Press the review button for the desired memory location.
3. Press the dial button to dial the number.
OR
1. Press dial button while the handset is still in the cradle.
2. Press the review button for the desired memory location, lift the handset and the
Download User Manual
If this information was helpful, please give me a big thumbs-up when you rate my answer. Thank you.
Feb 02, 2010 | GE 29267GE3 Corded Phone
I have a GE phone, mod # 2-9223BKC. I want to program numbers in but i can't find the directions, can you help
MEMORY
Each memory button is capable of storing phone numbers up to 16 digits. Memory
locations 0-9 require you to press the mem button for access.
STORING A NUMBER IN MEMORY
1. Pick up the handset, and press the store button.
2. Dial the number to be stored (up to 16 digits).
3. Press store again.
4. Press a memory location button 0-9, and hang up the handset.
INSERTING A PAUSE IN THE DIALING SEQUENCE
Use the redial button to add pauses to a dialing sequence, for example after you dial
9 for an outside line. A pause is approximately 4 seconds long.
To change a stored number, you just replace it with a different number using the
procedure for storing a number.
DIALING A STORED NUMBER
1. Pick up the handset, and wait for a dial tone.
2. For numbers stored in memory locations 0-9, press the mem button, and then
number of the location in which the desired number is stored
Sep 15, 2009 | Lands Phones
How do i reprogram model ge 2-9267a
pull out the plastic tab that holds the piece of paper with the names of the people you speed dial. the instructions are under there.  pick up handset - ignore dial tone or dial tone going away - press "memory store" button - dial the number - press one of the eight buttons for location - hang up phone. that's it - your new number overwrites any old number that was in there. (then write the name of person on the piece of paper.)
Apr 18, 2009 | GE Lands Phones
Instruction manual for older style corded GE speaker phone
Here are the quick instructions on how to program the phone numbers.
You can also download a copy of the User's Guide from: http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=c96e9c823d0df43989039e5385bef04a&q=GE+29322GE1
Just enter the 4 digit captcha code and you will be able to download the User's Guide.
Please let me know if yo have any questions.
Good Luck!
To program priority keys:
1. Make sure the telephone is properly installed. Pick up the
handset and listen for the dial tone. If you don’t hear the
dial tone, recheck or repeat the installation steps.
2. Press the SPEAKER button or pick up the handset.
3. Press the store button.
4. Dial the number to be stored.
5. Press the store button again.
6. Press the A, B or C button.
7. Press the SPEAKER button or hang up the handset.
To program frequently called numbers:
1. Press the SPEAKER button or pick up the handset.
2. Press the store button.
3. Dial the number to be stored.
4. Press the store button again.
5. Press one of the 10 memory location buttons 0-9.
6. Press the SPEAKER button or hang up the handset.
Aug 11, 2008 | GE 29322GE1 Corded Phone
Uniden Cordless Phone Logo
158 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
