Question about GE DVL223EBWW Electric Dryer
Why won't my dryer heat up?
We had to tilt our dryer over to put a new floor under in now it won't heat up.
  • 478 Answers
It's very possible that you disconnected one wire or the plug is ajar. Check both. There is plate, upper left back, you can remove with one screw to check the for connections,you should have 230 volts between the two outside wires. If you dont have it here check at plug and breaker.
If you do have it you'll need to remove top and locate a small normally automatic resetting thermal switch mounted on the back top of heating element you can just jumper across the wire are slice the spade terminals together to test or if you have a voltohmeter check to see that it's closed.
Most likely its an incoming power problem.
Posted on Jul 12, 2010
GE GFDS350ELOWW won't power on
your fuseable safety thermostat mounted on the rear inner wall of the unit open,on a GE these fuses open and it kills the whole units power its under the top cover and to the 2:00 position of the heating element,but if its new call for warranty service it shouldn't cost you anything if its under a year old
Dec 10, 2012 | GE GFDN110ELWW Dryer
The heat is working but it won't tumble
tilt it back and see if the belt broke. do you hear the motor runnung?
Dec 31, 2011 | Dryers
I have a 7 cycle ele dryer (roper) my dryer is heating up but won't dry my clothes and.very little heat coming out from vent I had a new heating element put on what can be wrong with my dryer please...
When your dryer heats yet does not dry the clothes its usually always a poor air flow problem. What needs to checked is for lint build up in the blower housing,a chushed and or restricted vent from the rear of the dryer or anywhere to where it exits the house.
GENE
Sep 09, 2011 | Dryers
It dosn't dryer ,it rotates but won't heat up. I cleaned vent and hose
Generally, with a gas dryer, there is an ignition device that heats to a specific temperature and this causes the gas to ignite. When this electric ignition fails to work, the gas will not ignite and there will be no heat. I had this happen and had to call a professional. It was a simple matter of installing a new ignition device and it worked perfectly for years. I hope this helps! If it is a new dryer, check to see if this part might be covered under warranty.
If this helps please come back to Fixya and rate my advice!
Jul 27, 2011 | Estate Dryers
My kenmore top loader always shakes acrosss the floor. I stop it during spin cycle and reujust the load. the machine is level on the floor and the feet are dialed in.
is there rubber on the bottom of the feet?also i've seen in laundry rooms at one time or another the vent line on the dryer popped off or had a hole in it and lint got on the floor and under the washer,it finds it's way under the feet,try tilting the washer back and with a steel brush or sand paper clean off the bottom of the feet and see if that helps,also clean the floor under the washer.you may have to replace the rubbers on the feet.good luck
Mar 28, 2011 | Kenmore 22422 Top Load Washer
No heat on my dryer pull all apart and found no power to ignitor
put in a new installation burner ignitor kit. did like it,s said still won heat up??????
Jan 05, 2010 | Dryers
Dryer won,t heat, put in new element and still won,t heat.
check you thermal fuse for continuity if none change it and the high-imit safety shut-off fuse(closest to heat element)
Apr 08, 2009 | Dryers
I have a kenmore series 80 dryer model 110-70812990 that i heard a bang then the drum stopped turning and i smelled burning rubber. I'm guessing that the drive belt broke. How easy would that be to repair...
Remove back of drier after disconnecting the power cord. Find old belt laying on floor under machine. Obtain new belt and place around drum and motor pulley. done
Dec 26, 2008 | Dryers
Put dryer belt on maytag dryer
generic maytag dryer belt replacement
type 1:older models by Maytag with lintscreen under door
  • unplug dryer
  • remove 2 screws from under front panel
  • tilt front panel up from the bottom and unclip top
  • remove door switch wires
  • set front panel aside
  • remove front drum retainer 2 screws each side
type 2:newer models by whirlpool lint screen in top cover
  • unplug dryer
  • remove lint screen
  • remove 2 screws under lint screen
  • with putty knife or other blunt blade
    unclip spring clips at front corners of top panel
  • remove 1 screw each side of front panel 1/2 way from top
  • remopve door switch wires
  • tilt front panel down and unclip
all
  • withdraw drum forward
  • examine drum rollers for wear
    if worn or locked replace in pairs
  • examine felts and nylon glides(if fitted) for wear
    if worn replace
  • examin case floor for tensioner
    (sometimes broken belt ends pull the tensioner out of place its easy to see the slots on the case floor for the 2 feet and spring, looks like a power socket)
  • loop new belt around drum at wear mark of old belt
  • insert drum
  • loop belt around motor pulley
  • pull tensioner to end of travel against spring
  • loop belt around tensioner
  • relax tensioner
  • rotate drum by hand to make sure belt wont jump off
reassemble in reverse order
Oct 29, 2008 | Maytag Dryers
My kenmore electric dryer wont heat mondel 110.86880100
I know you cleaned the lint filter so I won't even mention it:)
Is it possible that your vent hose runs along the floor (perhaps behind the dryer, or maybe even under a raised floor beneath your dryer - as mine used to) before going up and out to the outside vent? If so it could be that water has seeped in through the vent opening from outside and become trapped in the hose and is acting like a drain trap and blocking moist air from escaping which is causing the clothes not to dry.
This is what happened to mine once anyway. A cracked vent flap was all it took for the water to build up over time. Unfortunately mine ran under the floor and I had to actually tear up my floor in order to remove the water without having it flow all over my house. Fixed the drying problem though (and a new vent flap insured that it didn't happen again).
Jan 05, 2008 | Fisher and Paykel DEGX1 Electric Dryer
GE DVL223EBWW Electric Dryer Logo
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
