Question about Maytag MDB9600A Jetclean II Built-in Dishwasher
The door has to be held shut tightly to engage motor . How do I adjust the switch or replace it.? It is a maytag jet clean model number MDB 5000 WW Serial # 18228284WM
    Problem Solver:
  • 5 Answers
Make sure the dishwasher is centerd in hole with nothing obstructing door closure.Make sure the rack is not in backwards
Posted on Jul 21, 2010
Maytag 5000 dryer will not start, flashing F01
Electric dryer no start does nothing
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage.
CHECK THERMAL SHUT OFF THERMOSTAT USUALLY LOCATED ON THE BLOWER. for OHMS or resistance with a meter. Should show a closed circuit. Ohms WHEN THIS FUSE BLOWS IT WILL SHUT DOWN EVERYTHING.
NEXT Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position.
If you hear a humming/clicking sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings or relay/capacitor on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Another thing to check is the belt safety switch. With a multi meter.
Especially if u just replaced the belt. The belt safety switch is attached to the Tensioner and motor. IT LOOKS LIKE A DOOR SWITCH SOMEWHAT a little black pc of plastic with 2 prongs going into it. Sits at bottom of motor. Under the Tensioner. Attach meter clips to the 2 prongs on switch, Then when the little white push button is pressed in it should show continuity and none when released.
Lastly check ur DOOR SWITCH for continuity with a meter when the button is pushed in the (on/Door closed position,) it may have gone bad.
https://www.youtube.com/watch?v=sTRP6kHqAFs
Hey GOD IS GOOD !!!!
Oct 02, 2014 | Dryers
My model # is mdb 5100 aww. Cannot find one. Built in, Maytag Jet clean (Quiet pack) Serial 10071560YY Motor 5.5a 120v 60hz heater 6.0 a Just quit working. Now no power at all
Most likley you have a bad control board. Can you give me anymore details of what exactly is going on with it?
Did you check the breaker and make sure there is power going to it.
Aug 22, 2010 | Maytag Dishwashers
Have a coleman powermate 5000. Won't start. Laid
this model has one fuel shut ff switch it's on the tank.if it's turned on then fuel is reaching the carb.
you should check oil level, and check if there is any spark in it.
Oct 28, 2009 | Coleman Powermate Powermate 5000W...
My bottom freezer door isn't aligned right the
Don't think buildup is the problem. Sometimes the doors become loose and need adjustment.1a4bfab.gif See if you can locate the model serial number so I can help you better, Sea Breeze
Mar 27, 2009 | Maytag MFF2557HE Bottom Freezer French...
Maytag MDB-3 won't start, display flashes
Hold down the lighted "3" for five seconds to unlock the child safety lock
Feb 15, 2009 | Maytag 24 in. MDBH970AWS Built-in...
No power to Maytag Dishwasher MDB-8
no breaker on motor look at door lock ***. for power
Nov 03, 2008 | Maytag 24 in. MDB8600AW Jetclean II...
Door Lock
on your model all wax motor door latch's have to be replaced,go to repair clinic .com and you can order the part or go to ebay,and put in maytag neptune mah5500bww wax motor and it will come up and the guy selling the motors has pictures on how to install,let me know-mike
Jun 25, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washer sticks in cycle; door switch related?
tremendous "ad" for maytags, wait for catriver he knows..good luck
Aug 10, 2006 | GE WSXH208A Front Load Washer
Maytag MDB9600A Jetclean II Built-in Dishwasher Logo
180 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
