Question about Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model
My lawn tractor just quit running, battery fully charged, won't do anything when switch is turned on. Can the ignition switch be bad?
  • 760 Answers
When you say it quit running, did it stop while you were mowing? Or did it just not start one day. Could be the ignition switch, but not likely. There are several safety switches on your mower. First is the operator present (switch in the seat) then there is the switch on the clutch that requires you to hold the clutch in when you start. Then there is a switch on the PTO for the deck that must be off to start. Without an exact model number, I can't look at the exact wiring schematic, but this is generally how they work. If you have a tester, and know how to use it start at the battery, look for 12 V. Then test from ground to one side of ignition swithch. Then to the other while the key is in start. Then find wires to seat switch. This switch should keep the mower from starting and keeps the pto engaged usually. then find the switch for the clutch/brake. test both sides of that. Finally test the small terminal on the starter solonoid. If you're getting 12V to the solonoid, and you have a good ground on your battery and it still won't start, could be the solonoid. If it actually quit while you were mowing, I'd check the seat switch and pto switch.
Posted on Jul 12, 2010
  • Jr. Wagner
    Jr. Wagner Nov 07, 2010
    check all of ur wireing mine did the same thing here it was a wire that came loose by the fuse i hooked it back up and it stared right up
This is a Craftsman Lawn Tractor 18.5 HP Model # 917.275760
Are you sure the battery is good and fully charged and are the battery cables clean and tight both ends?
Oct 19, 2015 | Craftsman Garden
Why won,t my simplicity lawn tractor hold a charge
check for a bad diode on the alternator
May 31, 2012 | Garden
Is there a fuse on my bob villa 21 hp craftsman lawn tractor? The battery is charged but it won't start, won't even turn over.
Check you safety switches, brake, neutral, seat, blades, and reverse (if equiped). Then if that does not work I check the starting solinoid and the ignition switch.
Aug 08, 2011 | Garden
I need a manual with an electrical diagram.
The fuse is blown under hood behind engine.The coil might be bad at the worst.
Jul 17, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Lawn tractor won't start has charged battery ignition key will not start when fully turned to the right.I have started it by jumping the contacts on the solenoid. but now that won't work
there are several kill switchs one is at the deck lowering handle , others are on the gearshift , you probably burnt out the solinoid using the screwdriver its and easy replace? these are also bad on starters they burn up quick? if you go to searsparts.com type in your model # it will show you expolded veiw of the switchs with a test light and a little mech ability you can fix it ? hope this helps
Aug 27, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Husqvarna yth2448 pto switch kills motor/battery will not charge
you may hav a bad alt. problem with the mower dying when you engage the pto is most likley a bad sensor or wire unplugged on the seat sensor.the way it works is if the blades are turning and it dosent sense you being on the seat the mower shuts down.this has been standard on mowers for quite a few years now. it keeps the blades from cutting you up if you fall off the seat while mowing. as for charging i would try cleaning the battery connections and get the battery checked first.
Jul 16, 2009 | Husqvarna Garden
Cant get my lawn tractor to start
IT COULD BE IGNITION SWITCH IS BAD, I REPLACED ONE ON A CRAFTSMAN THAT DID THIS,BUT ALSO COULD BE A SAFETY SWITCH IS NOT CLOSED PREVENTING STARTER FROM OPERATING,---WITH THE IGNITION SET TO ON CROSS THE TERMINALS ON SOLENOID AND SEE IF IT STARTS THE TRACTOR RUNNING, IF IT FAILS TO RUN ITS PROBALY THE IGNITION SWITCH THEN.
Apr 09, 2009 | Briggs & Stratton Garden
Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model Logo
533 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
