Question about Raypak Rp2100 Pool & Spa Heater Lonox 407k Btu Natural Gas Polymer Header Digital Rp407aenc
Good morning, Recently I purchased a replacement PC Board Control IID unit for my Raypak RP2100 natural gas pool heater. The specs on the heater are: Serial#: 9910074540 Model#: P-R335A-EN BTU: 333,600 The old PC Board part number is 601553 and the replacement PC Board part number is 601769. The pinning doesn't match up and I was wondering if the replacement part is for a propane heater (on the bottom right hand corner of the replacement board it states "Propane 90")? Any help would be deeply appreciated. Thanks...Glenn
  • 6,826 Answers
Yes, I think that you hit ont he fact that the PC Board Part number is 601553 and the replacement PC Board in 601769. Propane and natural gas are different so this is not right.
If the pinning does not match up, that's a red flag as well.
I would call Raypak about the RP2100 natural gas pool heater and have them check their information, and ask that a more suitable replacement PC Board be sent out to you.
This happens at Sears, too.
Posted on Jul 12, 2010
My pool heater will not turn on with clk code
clk is clock mode if no system control put in standard mode if using control unit put in remote
Jul 28, 2014 | Raypak Rp2100 Pr406aen 406k Natural Gas...
Raypak 2100 206A worked 3-4 times after replacing circuit board, now error code GVO, gas valve open, what does this mean and how do I correct it?
check to see if you have proper gas pressure at unit most people think its the unit but mostly it is too small a gas line or too small gas meter call gas company
Jul 07, 2014 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Rp2100 main board has a piggyback circuit board attached to it with 2 relays controlling or wired to 2 jandy actuator valves. I upgraded heater to a new raypak heater & have no clue how to rewire with...
The new board may have the actuator relays and connectors on the main board. If so plug the wires in. If that is not the solution then you can call the Raypak technical support line and they may be able to direct you. Good luck.
Aug 11, 2011 | Raypak RP2100 Heater PC Board Control IID...
I have a RP 2100 Raypak Pool Heater Model number C-R185-EN installed about 1996 and used very little through out the years the front service light is on-- red --the back circuit board fault shows a sensor...
The part number for the thermistor for your heater is 005299B, officially called the temperature sensor IID it is also refered to a temp sensor or temp sensor kit.
John
Jul 09, 2011 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Have a 010253F replcement kit for a Raypak model 335a heater. Need wiring instructions.
Go to the RayPak web site. They have a pdf of the instructions for replacing the board with what you have.
Sep 04, 2009 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Opened the pool for the season but can't get heater to start
the most common problem is pilot light. IF you have electronic ignition, check the electronic starter. You also need to be sure you are getting gas to the unit.
David.
May 25, 2009 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Raypak pool heater piliot light on heat will not turn on
Make sure that gas control knob is set to ON (counterclockwise). Make sure that ON/OFF switch is ON. Check that temperature setting is high enough to call for heat. Make sure pool pump is running and water is flowing to unit.
If not above there is a diagnostic procedure on page 33 of manual at:
http://www.raypak.com/uploads/6000.52AG.pdf
May 24, 2009 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Raypak Rp2100 Pool & Spa Heater Lonox 407k Btu Natural Gas Polymer Header Digital Rp407aenc Logo
321 people viewed this question
Top Raypak Pool & Spa Experts
Bill Jordan
paulcarew
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
